Loading...
Pages: [1] 2 3 ... 7   Go Down
Author Topic: Nokia 6100 LCD Display - Arduino Playground  (Read 8471 times)
Denmark (Europe)
Offline Offline
Full Member
Electronics Designer & Consultant
View Profile
WWW
Hi.
I've finally got the Nokia LCD i've ordered from Sparkfun: http://www.sparkfun.com/commerce/product_info.php?products_id=8600
Then i followed the guide on Arduino Playground: http://www.arduino.cc/playground/S1D15G10NokiaLCD/S1D15G10NokiaLCD and made the transistor voltage divider using
  • 4 BC547
  • 4 470Ohm Resistors
  • 4 4.7K Resistors
Then i used the 3V3 pin on the Arduino to get the 3.3V, and then i connected everything as shown.
Then i programmed the Arduino using the example code, and when it was programmed nothing happend!
The LCD was only Purple and hummed very much (caused by the backlight StepUp converter)
I have tried to find the problem, but I can't!
If i disconnect the LCD and the I/O lines from the Arduino, and then connect to test the voltage deviders, the output is 3.25-3.27V when I apply 5V - so no problem there!
Best Regards
Thomas Jespersen
« Last Edit: March 14, 2009, 06:01:46 pm by tkj » Logged
Need any help with your electronics projects?
TKJ Electronics, a consultancy company located in Denmark (Europe), has the required expertice, knowlegde and development tools, to do the development for you.
Do not hesitate contacting us by visiting our website: http://www.tkjelectronics.dk
Denmark (Europe)
Offline Offline
Full Member
View Profile
WWW
Have anyone worked with this board and display from Sparkfun?
Have anyone worked with the sample code from Arduino Playground?
Have anyone got it working (Board connected to Arduino as shown)?
Logged
United States (Texas)
Offline Offline
God Member
Arduino socks
View Profile
the lcd draws around 324 milliamps at 3.3 volts. the 3.3v pin can only supply 50 milliamps, you might need some external voltage regulator to power it.
Logged
Denmark (Europe)
Offline Offline
Full Member
View Profile
WWW
You think that could cause the problem?
How much can the 5V then sink, because i have an LD33V (3V3 Voltage Converter)
« Last Edit: March 19, 2009, 04:51:22 pm by tkj » Logged
Denmark (Europe)
Offline Offline
Full Member
View Profile
WWW
Now i've tried with an LD33V and it still doesn't work smiley-sad
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
You'd still be at 214 milliamps right?
Logged
Denmark (Europe)
Offline Offline
Full Member
View Profile
WWW
214 milliamps, 324 milliamps - now I'm confused!
I don't know how much it draws, but I'm using an external power supply, an LD33V for the 3.3V, and the 5V on the Arduino for the Backlight.
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
I've only had a quick read and it's hard to grasp from your words what you've done already so I may be wrong here; as you're now using two separate power supplies (the external 3V3 and the Arduino's 5V) in the same circuit have you connected both of their GND (0V) rails together?
Logged
Denmark (Europe)
Offline Offline
Full Member
View Profile
WWW
Yes I have.
You know, the 5V and ground from the Arduino is going into the LD33V, which then produces a 3.3V signal!
Logged
Offline Offline
God Member
Arduino socks
View Profile
is it still purple and humming?
Logged
Denmark (Europe)
Offline Offline
Full Member
View Profile
WWW
Purple/Blue, yes, it's the startup color.
And it's still humming, as it's the backlight voltage converter!
Logged
Denmark (Europe)
Offline Offline
Full Member
View Profile
WWW
Aren't there anybody on this forum who have connected the Nokia LCD Board from Sparkfun to the Arduino, and then got it showing something?
Logged
Denmark (Europe)
Offline Offline
Full Member
View Profile
WWW
Help please!!
Logged
Denmark (Europe)
Offline Offline
Full Member
View Profile
WWW
Please, if anyone have got it working, please tell me/us how!
Logged
Switzerland
Offline Offline
Newbie
Arduino rocks
View Profile
I've got the Nokia 6610 LCD Display from http://www.nuelectronics.com and it works pretty well for me.
Same as http://www.sparkfun.com/commerce/product_info.php?products_id=8683
Even though my application uses a slightly different LCD Module, nevertheless I thought I give you this hint - it might get you a step further.
The Nokia 6610 (from nuelectronics.com) works only with the ARDUINO IDE 0011.
More details about this project here at:http://www.halo-photographs.com/remote-shutter-release-timer/.
For my part, when going through the menu-pages ARDUINO resets itself. Probably an issue with variables - don't know yet. Hints are highly appreciated.
Please let me know if this helped you to get a step further.
Rgds, Hans.
Logged
Dig-IT-all
Pages: [1] 2 3 ... 7   Go Up
Print
Jump to:
