Topic: Welcome Please help is simple (Read 2678 times) previous topic - next topic
EMAD
Oct 01, 2013, 09:06 pm Last Edit: Oct 01, 2013, 09:14 pm by AWOL Reason: 1
Hello
I'm a new member like Arduino programming, but I want a little help and is only a simple modification to the code
Simple graduation project
On experience Hahz but I want to add a simple matter
CODE is a resistance measurement circuit
But I want to add the code is simple
Is when they exceed the measured resistance value ratio of 300 to 400, it will light the LED on the output pin No. 11 to alert
And when they are valued in a ratio of 260 to 290 LED lights on the way out the pin No. 5 to alert
Thank you
This is the code you want to add the amendment it
:smiley-roll-blue:
This is the code
 Analog input, analog output, serial output
Reads an analog input pin, maps the result to a range from 0 to 255
and uses the result to set the pulsewidth modulation (PWM) of an output pin.
Also prints the results to the serial monitor.
The circuit:
* potentiometer connected to analog pin 0.
  Center pin of the potentiometer goes to the analog pin.
  side pins of the potentiometer go to +5V and ground
* LED connected from digital pin 9 to ground
created 29 Dec. 2008
modified 9 Apr 2012
by Tom Igoe
This example code is in the public domain.
// These constants won't change.  They're used to give names
// to the pins used:
const int analogInPin = A0;  // Analog input pin that the potentiometer is attached to
const int analogOutPin = 9; // Analog output pin that the LED is attached to
int sensorValue = 0;        // value read from the pot
int outputValue = 0;        // value output to the PWM (analog out)
 // initialize serial communications at 9600 bps:
 // read the analog in value:
 sensorValue = analogRead(analogInPin);
 // map it to the range of the analog out:
 outputValue = map(sensorValue, 0, 1023, 0, 255);
 // change the analog out value:
 analogWrite(analogOutPin, outputValue);
 // print the results to the serial monitor:
 Serial.print("sensor = " );
 Serial.print(sensorValue);
 Serial.print("\t output = ");
 Serial.println(outputValue);
 // wait 2 milliseconds before the next loop
 // for the analog-to-digital converter to settle
 // after the last reading:
 delay(2);
This page link for more knowledge
http://arduino.cc/en/Tutorial/AnalogInOutSerial
Moderator edit: Code tags. Again.   AWOL
KeithRB
Use code tags. And do your own homework. Please ask a *specific* question, not just "write this code for me!"
EMAD
Sorry, but I did not understand what you mean  :smiley-roll-blue:
I want to help because I beginner in programming Arduino
Thank you
KeithRB
Your other post got deleted> Read this: http://forum.arduino.cc/index.php?topic=97455.0
And we will not just "ammend" your code to do your assignment for you.
You need to ask a specific question like:
"How do I tell whether a value is between two limits? I tried this...and it does not work."
Where the ... is the code you used in an attempt at solving the problem.
Hint:
you need an if () statement.
EMAD
Yes, I want to if
Yes, I tried to add on to carry out the universe compared to the value of resistance and giving is directed by the pin No. 11
LED to illuminate
If the value is between 300 to 400
And the other case
Director glows 5 Pin number if the resistance value is 260 to 290
The code you want to do is start the process of comparing (resolutions) If
:smiley-roll-blue:Thank you
AWOL
Google translate is clearly struggling - are any of the languages in the international section closer to your native tongue?
EMAD
Sorry for that matter
But I do not speak English well
I speak the German language
Thank you
AWOL
EMAD
Yes, I want to if
LED to illuminate
And the other case
CrossRoads
What you want is pretty simple:
if ((sensorRead >=300 ) && (sensorRead<=400) ){
// do something
if ((sensorRead >=260 ) && (sensorRead<=290) ){
// do something different
nickgammon
Deutsch: http://forum.arduino.cc/index.php?board=31.0
EMAD
#11
Oct 03, 2013, 05:30 am Last Edit: Oct 03, 2013, 05:32 am by EMAD Reason: 1
Code has been copied, but it did not work please help
Thank you
The circuit:
modified 9 Apr 2012
by Tom Igoe
// do something
 delay(2);
AWOL
it did not work
How do you know?
Please use code tags when posting code.
HazardsMind
SensorRead and SensorValue are two different variables.
My GitHub:
https://github.com/AndrewMascolo?tab=repositories
