Topic: Nokia 5110/3310 LCD...? (Read 8616 times) previous topic - next topic
Bugsy_malone_666
Oct 01, 2013, 11:31 pm Last Edit: Oct 01, 2013, 11:37 pm by Bugsy_malone_666 Reason: 1
Ok so I bought a 5110/3310 LCD off ebay with one of the level shifting chips, followed this set of instructions http://learn.adafruit.com/nokia-5110-3310-monochrome-lcd/overview to wire it up and stuff, downloaded arduino IDE software and got it up and running it seemed to upload the sketch but nothing happened, my display didnt do anything other than it was illuminated by the back light.
At one point I noticed a flicker with a few pixels on the display I think, but it only did that once.
Being a noob, I dont really know where to start with this one, whats the best way to test the display? what sort of issues could there be with uploading the code?
I dont know where to start!
Please help  :smiley-red:
Bugsy_malone_666
Bit of an update, tried again tonight just now and its come up with this:
'Adafruit_PCD8544' does not name a type
Quote
pcdtest:30: error: 'Adafruit_PCD8544' does not name a type
pcdtest.pde: In function 'void setup()':
pcdtest:62: error: 'display' was not declared in this scope
pcdtest:74: error: 'BLACK' was not declared in this scope
pcdtest:136: error: 'WHITE' was not declared in this scope
pcdtest.pde: In function 'void testdrawbitmap(const uint8_t*, uint8_t, uint8_t)':
pcdtest:171: error: 'display' was not declared in this scope
pcdtest:186: error: 'display' was not declared in this scope
pcdtest:186: error: 'BLACK' was not declared in this scope
pcdtest:188: error: 'display' was not declared in this scope
pcdtest:193: error: 'WHITE' was not declared in this scope
pcdtest.pde: In function 'void testdrawchar()':
pcdtest:208: error: 'display' was not declared in this scope
pcdtest:209: error: 'BLACK' was not declared in this scope
pcdtest.pde: In function 'void testdrawcircle()':
pcdtest:222: error: 'display' was not declared in this scope
pcdtest:223: error: 'BLACK' was not declared in this scope
pcdtest.pde: In function 'void testfillrect()':
pcdtest:230: error: 'display' was not declared in this scope
pcdtest.pde: In function 'void testdrawtriangle()':
pcdtest:239: error: 'display' was not declared in this scope
pcdtest:242: error: 'BLACK' was not declared in this scope
pcdtest.pde: In function 'void testfilltriangle()':
pcdtest:248: error: 'BLACK' was not declared in this scope
pcdtest:249: error: 'display' was not declared in this scope
pcdtest:253: error: 'WHITE' was not declared in this scope
pcdtest.pde: In function 'void testdrawroundrect()':
pcdtest:260: error: 'display' was not declared in this scope
pcdtest:261: error: 'BLACK' was not declared in this scope
pcdtest.pde: In function 'void testfillroundrect()':
pcdtest:267: error: 'BLACK' was not declared in this scope
pcdtest:268: error: 'display' was not declared in this scope
pcdtest:270: error: 'WHITE' was not declared in this scope
pcdtest.pde: In function 'void testdrawrect()':
pcdtest:277: error: 'display' was not declared in this scope
pcdtest:278: error: 'BLACK' was not declared in this scope
pcdtest.pde: In function 'void testdrawline()':
pcdtest:284: error: 'display' was not declared in this scope
pcdtest:285: error: 'BLACK' was not declared in this scope
pcdtest:288: error: 'display' was not declared in this scope
pcdtest:289: error: 'BLACK' was not declared in this scope
pcdtest:294: error: 'display' was not declared in this scope
pcdtest:296: error: 'BLACK' was not declared in this scope
pcdtest:300: error: 'BLACK' was not declared in this scope
pcdtest:307: error: 'BLACK' was not declared in this scope
pcdtest:311: error: 'BLACK' was not declared in this scope
pcdtest:318: error: 'BLACK' was not declared in this scope
pcdtest:322: error: 'BLACK' was not declared in this scope
TheCoolest
Try out my library, read the post for connection details.
http://forum.arduino.cc/index.php?topic=176794.0
Pedro147
#3
Oct 02, 2013, 03:15 am Last Edit: Oct 02, 2013, 03:27 am by Pedro147 Reason: 1
Also if you would like to try some 5110 code without any libraries this guy has a really good tutorial and a couple of interesting pieces of code. Nice guy too
Pedro XD
http://ianlangelectronic.webeden.co.uk/#/lcd-module-0/4569058582
http://www.pedroduino.com
Nick_Pyner
I suspect you got the display and library from different sources, and you have to be seriously lucky to get it right first time with the 5110 if you do that.
The fundamental problem is that, while all 5110s look more or less the same, they aren't. They use different pins. Even the wiring for the light can be different. The matter is only made worse by having the pin call in the library rather than in the Arduino sketch.
This is probably the time to get a breadboard to help sort things out and none of this is easy, particularly if you are a noob. But it's worth it.
I had a hard time but found the best start for this is
http://blog.stuartlewis.com/2011/02/12/scrolling-text-with-an-arduino-and-nokia-5110-screen/
It is a limited application but gives a result and no library is involved.
More information is here
Ultimately, it makes more sense to use a library. Here is the standard one from Philips. It may be the same as the one you have.
http://code.google.com/p/pcd8544/
I had to edit it for my display. The 1-8 pin order on mine is
RST
CE
DC
DIN
CLK
VCC
LIGHT
GND
If yours is the same, I guess you can use my library and SPI pin arrangement on Arduino.
Bugsy_malone_666
RST
CE
DC
DIN
CLK
VCC
LIGHT
GND
True , I was using the Adafruit stuff but sourced my 5110 display from ebay.
I was thinking however, what impact would the pin numbers actually have if I wire it appropriately? I think if I remember my pinout is the same as what you list above,  but I pinned from a 4050 level shifter so that the output of 'CS' for example went to CE (I think thats the same thing right?) and that Din went to Din, so even though the order may have been marginally different the end result should have it wired correctly?
Arduino.cc was down lastnight till I went to bed pretty much so havent had time to test it but maybe I can sort something tonight, ultimately my goal is to get the display to work then maybe code an OBDuino and also a small weather station project, but the first step is all about getting a component to actually work!
TheCoolest
I sourced my display from ebay as well. But it shouldn't matter where it is from, the controller is the same on all of them.
All that may be different is the pin outs on the breakout board. If you take a look at my library, (and the explanation in the H file about pinouts) you'll see that it isn't very difficult.
Simply wire it up correctly and you're good to go.
Nick_Pyner
If you are aware of the differences, that's OK and all you need to do is know how to fix the problem which, in the case of the Philips PCD8544 library, means that is what you have to edit - the PCD8544 library. This means swallowing deeply and going into uncharted territory, but I guess it's not too bad once you've done it.  Things could get messy if you want to change your mind later.
In my case the pin call in the library is:
class PCD8544: public Print {
    public:
        // All the pins can be changed from the default values...
        PCD8544(unsigned char sclk  = 13,  /* clock       (display pin 5) */
                unsigned char sdin  = 11,   /* data-in    (display pin 4) */
                unsigned char dc    = 5,   /* data select (display pin 3) */
                unsigned char reset = 6,   /* reset       (display pin 1) */
                unsigned char sce   = 7);  /* enable      (display pin 2) */
Quote
No comment, I don't use a level shifter.  Power is from Arduino 3v3 pin, LED display pin 7 is to gnd via 330r and display pin 8 direct to gnd. One of my displays has a blue LED which I find utterly useless and is left disconnected.
Bugsy_malone_666
Ok well really weird but i plugged it in today to try redoing things and it just started working and displaying the sample script!
Confused!
Bugsy_malone_666
Unplugged it, plugged it back in, not working again, now I am really confused!
TheCoolest
You can't randomly plug in/unplug the LCD power pin for example. This can damage the display.
I did that once with mine, and after resetting the Arduino (to reinitialize the display) it took it several hours to get back to normal.
Nick_Pyner
#11
Oct 04, 2013, 02:22 am Last Edit: Oct 04, 2013, 02:29 am by Nick_Pyner Reason: 1
OK. I guess that might end the discussion on pins and libraries....
Your display could be suss.
I understand these are manufacturer's surplus and not necessarily 100% kosher. All of mine are on a shield. One of them never fails to start, or reset, but might die after a few hours - or days. I have never been able to fix this and now I don't know if it's the display or the shield.  There is only so much re-soldering one can do. The other 5110s are just fine.
The reply #10 above reads like nonsense but may not be, for the same reason.
JimboZA
You been watching The IT Crowd?
But seriously, why would the bold below be the case?
I bought 2 of these LCDs, didn't get much chance to play before going out of town on business, but hope to get some time this weekend.
Johannesburg hams call me: ZS6JMB on Highveld rep 145.7875 (-600 & 88.5 tone)
Dr Perry Cox: "Help me to help you, help me to help you...."
Your answer may already be here: https://forum.arduino.cc/index.php?topic=384198.0
Bugsy_malone_666
Ok well I decided to do my typical thing today and take the screen apart (I do this with many things!) I was surprised to find that once you take the metal retainer off the screen that the PCB underneath contains only the LEDs and a couple of resistors and everything that runs the screen is in the screen.
I decided that there wasnt much you can service, but I wiped the Silicone contact that goes between the board and the screen and hey presto, it now works every time! I have plugged and unplugged multiple times and it has booted and run consistently, so looks like it might have been just dirty contacts when it was made!
Nick_Pyner
Very interesting. Maybe my troublesome one has a similar problem.
Thanks
