Topic: GSM Shield Has Stopped Connecting (Read 3296 times) previous topic - next topic
bfulford
Hi. My Arduino GSM shield was working flawlessly for the first few weeks but then suddenly stopped connecting. I jhave tried it on both an Uno and a Mega 2560. I also tried a different SIM card, but it still won't connect. It is powered via an AC/DC adaptor with max 1 A. The following code hangs on "GSM networks scanner":
Code: [Select]
// import the GSM library
#include <GSM.h>
// PIN Number
#define PINNUMBER ""
// initialize the library instance
GSM gsmAccess(true);     // include a 'true' parameter for debug enabled
GSMScanner scannerNetworks;
GSMModem modemTest;
// Save data variables
String IMEI = "";
// serial monitor result messages
String errortext = "ERROR";
  // initialize serial communications
  Serial.println("GSM networks scanner");
  scannerNetworks.begin();
  // connection state
  boolean notConnected = true;
  // Start GSM shield
  // If your SIM has PIN, pass it as a parameter of begin() in quotes
  while(notConnected)
    if(gsmAccess.begin(PINNUMBER)==GSM_READY)
      notConnected = false;
      Serial.println("Not connected");
  // get modem parameters
  // IMEI, modem unique identifier
  Serial.print("Modem IMEI: ");
  IMEI = modemTest.getIMEI();
  IMEI.replace("\n","");
  if(IMEI != NULL)
    Serial.println(IMEI);
  // currently connected carrier
  Serial.print("Current carrier: ");
  Serial.println(scannerNetworks.getCurrentCarrier());
  // returns strength and ber
  // signal strength in 0-31 scale. 31 means power > 51dBm
  // BER is the Bit Error Rate. 0-7 scale. 99=not detectable
  Serial.print("Signal Strength: ");
  Serial.print(scannerNetworks.getSignalStrength());
  Serial.println(" [0-31]");
  // scan for existing networks, displays a list of networks
  Serial.println("Scanning available networks. May take some seconds.");
  Serial.println(scannerNetworks.readNetworks());
Any advice?
davidgoth
Hi!,
With debug mode activated (GSM gsmAccess(true);). Can you post your serial monitor output, please?.
bfulford
David, as shown in the code, debug mode is activated. The only output I get is "GSM networks scanner".
bfulford
I tried the following debug code...
Code: [Select]
//Debug for Mega2560 with Arduino GSM.
#include <GSM.h>
GSM_SMS sms;
  char code='X';
  while(true)
    Serial.println("try Access");
    code=gsmAccess.begin("",true,false);  // code=gsmAccess.begin("0000",true,false); // my pin is "0000"
    Serial.println("\nAfter Access");
    if(code==GSM_READY)
      Serial.println("code is GSM_READY");
    if(code==CONNECTING)
      Serial.println("code is CONNECTING");
    if(code==ERROR) {Serial.println("code is ERROR");}
    if(code==IDLE) {Serial.println("code is IDLE");}
    if(code==GPRS_READY) {Serial.println("code is GPRS_READY");}
    if(code==TRANSPARENT_CONNECTED) {Serial.println("code is TRANSPARENT_CONNECTED");}
...which gave the following response (repeatedly):
Code: [Select]
try Access
AT%13%
After Access
code is CONNECTING
I also tried sending an AT command using the following code but there was no response.
Code: [Select]
#include <SoftwareSerial.h>
#include <string.h>
char incoming_char = 0;
SoftwareSerial cell(2,3); // check GSM RX and GSM TX matches with digital 2 and digital 3 pin.
  // Initialize serial ports for communication.
  // Reset
  Serial.println("Start Reset");
  pinMode(7, OUTPUT);
  digitalWrite(7, HIGH);
  delay(12000);
  digitalWrite(7, LOW);
  Serial.println("End Reset");
  cell.begin(9600);
  Serial.println("Enter your AT commands (with CR & NL)...");
  if(cell.available() > 0)
    incoming_char = cell.read();
    if((incoming_char >= ' ') && (incoming_char<='z'))
      Serial.print(incoming_char);
      Serial.print("%");
      Serial.print((int) incoming_char);
      Serial.print("%");
      if(incoming_char == 10)
  if(Serial.available() > 0)
    incoming_char = Serial.read();
    cell.print(incoming_char);
Forgot to mention that the power and status light are on and the net light is blinking.
