Topic: Reprogram Arduino's own microcontroller (Read 6565 times) previous topic - next topic
sjheiss
Is it possible to reprogram an Arduino's microcontroller without another chip or Arduino? I realize that if I have to ask this I probably shouldn't be messing with the bootloader, but I'd like to know for future reference, since I can't find an answer to this elsewhere.
JChristensen
The direct and technical answer to your question is no, whether programmed via ICSP or async serial (bootloader) there is bound to be another "chip" somewhere to communicate with the target MCU.
Is that really your question though?  Not sure what else you might be asking so I took the words very literally  :D
sjheiss
No, that answers my question. I was hoping one could edit the source code and easily upload it to the microcontroller, but as I figured, that's not possible. Thanks anyways!
westfw
There is  http://bitlash.net/ which allows you to edit programs (in source form) directly on the arduino, but you still need something with a keyboard/display to do the actual editing.  Since that something is usually a computer, it's usually not a big step toward running the full Arduino IDE.
AMFORTH will also allow this, if you consider Forth to be a usable language.
sjheiss
I'd never heard of Bitlash - that's pretty cool actually. By "source code" in my last post, I meant the source code of the bootloader, not a sketch. Sorry for the confusion.
Bitlash could be useful in the project I'm working on now. I don't consider Forth usable. :D
fungus
No. The bootloader is in protected memory (and for obvious reasons...!)
No, I don't answer questions sent in private messages (but I do accept thank-you notes...)
JChristensen
Using the bootloader or ICSP isn't easy enough?
sjheiss
What I mean, is can I reprogram the microcontroller without a breadboard, second microcontroller, or a dedicated programmer. Just using a computer, the Arduino, and the chip it came with.
JChristensen
Most Arduinos are self-contained in that respect and so only need a computer and a USB cable, so yes. Exceptions that I am aware of include the Arduino Pro and Pro Mini (these require an FTDI cable or equivalent breakout board), there may be a couple others, see http://arduino.cc/en/Main/Products for details. Apologies if I am restating the obvious.
sjheiss
So how exactly would I compile the bootloader source and upload it to my Uno? Avr-gcc and avrdude?
JChristensen
Correct, AVR-GCC, AVRDUDE, plus an ICSP programmer. But Unos come with the bootloader already programmed. Maybe I'm not sure exactly what kind of programming we're discussing.
sjheiss
No, I mean I don't want to use any outside methods to program the chip. Just my computer and the Arduino. By programming I mean using a USBTinyISP or similar method for (re)loading a bootloader onto the chip.
fungus
There's NO WAY to do it without extra hardware (ISP programmer or a second Arduino)
Paul__B
