Topic: 5x5x5 led cube using 74hc595 ...help in programming :( (Read 2149 times) previous topic - next topic
ennair16
Oct 03, 2013, 01:52 pm Last Edit: Oct 03, 2013, 02:33 pm by ennair16 Reason: 1
hello, i am a newbie... i have a project which is called 5x5x5 led cube... and i am having problems in programming since i don't have a background in programming in arduino...then our prof said that it should be passed after 3 days... :( can someone please give me a copy of a code of it? :( the components used is 74hc595... :( it will be very much appreciated. :)
Paul__B
Well if you post the project link, we might be able to point you in the right direction, just out of curiosity.
ennair16
here : http://www.instructables.com/id/5x5x5-LED-cube-run-on-Arduino-Uno/
but in my place, there are no 74hc238 available :( so i have to use 74hc595. but there is no code yet :(
PaulRB
The code is on the last page of the instructable.
The code will not work with 74hc595. It was written for 74hc238.
74hc595 is a shift register and 74hc238 is a decoder. The code would have to be significantly re-written to use 74hc595. I do not think 3 days will be enough, even if you get lots of help here. The only way to change the code in 3 days will be for someone here to re-write the code for you. I do not think your prof would approve.
Suggest you find another led cube design that you have the components for. There must be some that use 74hc595.
Paul
ennair16
i hope someone would help :( any random lights would do...if i only know how to program :(
