Topic: Newbee and loads of doubts please see (Read 597 times) previous topic - next topic
Lally
there is scroller attached for which i am using this i am also attaching the schematic design of the circuit
please help
this is the basic program i am using to get the leds glow with the moment of the scroller
the input is more like shown below ( has a small phase difference
pin2 ==> __|-|__
pin4 ==> __|-|__
but using this program i am able to capture the the changes and the leds glows
like if i hav led A and led B
so if i have the above input the pins will glow like
like A first and B
and then A and B both r ON
and then just B is ON
what i want is
for the above input that if i get pin2 i want to ignore pin4 and in case the input is lik ethis one
pin2 ==> __|-|__
pin4 ==> __|-|__
i want to ignore the pin2
and i want to use the counter in the program to count the number of inputs that i am getting from the scroller
please help me put
Code: [Select]
#include <avr/io.h>
int main()
  uint8_t i;
  PORTB= 0x00;
/* PB0, PB1 & PB3 are outputs; PB2 & PB4 are scroller inputs */
  DDRB = (1<<PB3) | (1<<PB1) | (1<<PB0);
  PORTB = 0;
  for(;;) {
     i = PINB;
     if ( (i & (1<<PB2)) != 0) {
        PORTB |= (1<<PB0);
     else {
        PORTB &= ~(1<<PB0);
     if ( (i & (1<<PB4)) != 0) {
        PORTB |= (1<<PB1);
     else {
        PORTB &= ~(1<<PB1);
     _delay_us(100); /* wait for a while */
in my mind i had more like a truth table to work on but not able to impliment it
like the input is more like
up ==> 001100
down=> 000110
and in this case i want to ignore the input at the down and send only one out put
pin2 ==> __|-|__
pin4 ==>  __|-|__ for upward moment
if this is the input more like
01100
00110
pin2 ==>  __|-|__
pin4 ==> __|-|__ for downward moment
00110
01100
i just want to capture the change in the bit at the signal
and which ever changes first i want to pick that one and niglect the other one
it was suggested by Cliff to use ISR
but i am not able to understand how to intiate this interrupt
if someone can help please
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
