Topic: led brightness (Read 791 times) previous topic - next topic
ecokarl
Hello,
  Blink
  Turns on an LED on for one second, then off for one second, repeatedly.
  This example code is in the public domain.
// Pin 13 has an LED connected on most Arduino boards.
// give it a name:
int led = 13;
int led1 = 12;
// the setup routine runs once when you press reset:
  // initialize the digital pin as an output.
  pinMode(led, OUTPUT);
// the loop routine runs over and over again forever:
  digitalWrite(led, HIGH);   // turn the LED on (HIGH is the voltage level)
digitalWrite(led1, HIGH);
  delay(1000);               // wait for a second
  digitalWrite(led, LOW);
digitalWrite(led1, LOW);  // turn the LED off by making the voltage LOW
this is the normal blink sketch with one led more.
there is in normal blue led connectet from pin 12 to gnd.
When i first put led13 high in the code the blue led is not so bright like when i fist put led12 high.
What is the problem? Why will the LED on pin 12 not have the same brightness?
JimboZA
There's something missing here:
Code: [Select]
Hint: you have two pins.....  8)
Johannesburg hams call me: ZS6JMB on Highveld rep 145.7875 (-600 & 88.5 tone)
Dr Perry Cox: "Help me to help you, help me to help you...."
Your answer may already be here: https://forum.arduino.cc/index.php?topic=384198.0
CrossRoads
Once you fix that, the LED brightness will also vary with the current limit resistor used, and the mcd rating of the LED.
ecokarl
CrossRoads
Sometimes it does come down to that 8)
