Topic: Mifare RFID-RC522 (Read 9611 times) previous topic - next topic
Oso57
Hi...
I'm newbie to arduino.
I've got a Mifare RFID-RC522 reader -writer.
With some examples I found on the internet I managed to read the serial number of the cards, but ...
Anybody can explain like a fool how I can write and read data on the cards? or Where I can get examples to do?
Thanks in advance.
rena
Check this sketch: https://github.com/rena2019/myarduino/blob/master/RC522DumpMifare.ino
Oso57
#2
Oct 10, 2013, 06:47 pm Last Edit: Oct 10, 2013, 08:24 pm by Oso57 Reason: 1
Thanks Rena...
But this example is more complex for me.
Do not exist any library for read-write data more simple?
Greetings.
Oso57
rena
Greetings.
to complex? The sketch is a one-file-solution: the lib-functions to talk to the board are included, that's why it looks so complex.
You can replace the loop function with the following (untested) code:
    uchar buffer[MAX_LEN];
    int block=0; //TODO: your block number
    if (selectCard(true) &&
         MFRC522_Auth(PICC_AUTHENT1A, block, defaultKeyA, serNum) == MI_OK &&
         MFRC522_Read(block, buffer) == MI_OK)
            //TODO: block buffer contains the read data
if you want to read 1 block only
timiti29
Hi, I've test the code and it's working.
i can read all block of the Token.
So, now the question is : can you explain the use of the function Auth,
we need to send defaultKeyA table, what is the content of the table ? what this table is it?
Thank you.
Timiti29
Oso57
Hello...
Thanks for your kindness
And to write?
I can not find the way
Greetings.
rena
And to write?
Fill the buffer with the data you want to write and then use MFRC522_Write instead of MFRC522_Read from my sample code above (select,auth,write)
Oso57
Thanks again for your kindness.
I am learning.
Greetings
