Topic: Ayuda con tarjeta NRF24L01 (Read 996 times) previous topic - next topic
Saludos, soy nuevo en el foro.
Tengo un problema con la antena NRF24L01
Estoy usando dos Arduino UNO, pero no tengo la comunicación entre los Arduinos.
Estos son los códigos:
transmisor:
Quote
/*              êîä ¹1 äëÿ ïåðåäàò÷èêà transmitter
óðîê îò Äìèòðèÿ Îñèïîâà. http://www.youtube.com/user/d36073?feature=watch
v.02 NRF24L01 if Arduino ¹1 button press-Arduino ¹2 LED on
Version 0.2 2013/07/15
èäåîëîãèÿ;
íà Arduino ¹1 íàæèìàåì êíîïêó, ÏÎÊÀ óäåðæèâàåì êíîïêó íàæàòîé,
íà Arduino ¹2 âÊëþ÷àåòñÿ (ãîðèò) ñâåòîäèîä,
èçìåíåíèÿ;
1. óñòðàíåíà çàäåðæêà â 1.5 ñåêóíäû,
òåïåðü ïðè íàæàòèè êíîïêè Arduino ¹1 ìãíîâåííî îòïðàâëÿåò ñèãíàë
à Arduino ¹2 ìãíîâåííî ïðèíèìàåò ñèãíàë.
2. äîáàâèë âîçìîæíîñòü èçìåíÿòü Ñêîðîñòü ïåðåäà÷è, Íîìåð êàíàëà,
Êîë-âî ïîïûòîê è âðåìÿ ìåæäó ïîïûòêàìè.
ïîäðîáíóþ âèäåî èíñòðóêöèþ âûëîæó çäåñü
https://www.youtube.com/watch?v=iJJVj9kgS-A
êîä ¹2 äëÿ ïðè¸ìíèêà
v.02 receiver NRF24L01 if Arduino ¹1 button press-Arduino ¹2 LED on
v.02 transmitter NRF24L01 if Arduino ¹1 button press-Arduino ¹2 LED on
v.01 NRF24L01 if Arduino ¹1 button press-Arduino ¹2 LED on
https://www.youtube.com/watch?v=aJVSrGwZs2s
Arduino1 NRF24L01 Serial send. - Arduino2 led. LOW HIGH
https://www.youtube.com/watch?v=aHgxXXRwtOE&noredirect=1
Arduino Ðàäèîìîäóëü nRF24L01 -2.4GHz RF24 Libraries. test
https://www.youtube.com/watch?v=B6LHfwisgUQ
NRF24L01+ 2.4GHz Antenna Wireless Transceiver Module For Microcontr
// ýòî ñêà÷àííàÿ áèáëèîòåêàRF 24
//https://github.com/maniacbug/RF24
//https://github.com/maniacbug/RF24/archive/master.zip
//http://yadi.sk/d/ZvMq19fB6lgPs
#include <SPI.h>
#include "RF24.h"
int msg[1];
// Set up nRF24L01 radio on SPI bus plus pins 9 & 10
//Êîíòàêòû îò ðàäèîìîäóëÿ NRF24L01 ïîäêëþ÷àåì ê ïèíàìíàì -> Arduino
//SCK  -> 13
//MISO -> 12
//MOSI -> 11
//CSN  -> 10
//CE   -> 9
RF24 radio(9,10);
// àäðåñà êàíàëîâ ïðèåìà è ïåðåäà÷è
const uint64_t pipes[2] = {
  0xF0F0F0F000LL, 0xF0F0F0F0FFLL};
//êíîïêè ïîäêëþ÷åíû ê ýòèì ïèíàì
int buttonPin1 = 2;
int buttonPin2 = 3;
void setup(void){
  radio.begin();
  radio.setDataRate(RF24_250KBPS); // Ñêîðîñòü ïåðåäà÷è
  radio.setChannel(100); // Íîìåð êàíàëà îò 0 äî 127
  radio.setRetries(15,15); // Êîë-âî ïîïûòîê è âðåìÿ ìåæäó ïîïûòêàìè
  radio.openWritingPipe(pipes[1]);  // Îòêðûâàåì êàíàë ïåðåäà÷è
  radio.openReadingPipe(1, pipes[0]); // Îòêðûâàåì îäèí èç 6-òè êàíàëîâ ïðèåìà
  radio.startListening(); // Íà÷èíàåì ñëóøàòü ýôèð
void loop(void){
  //ïîêà êíîïêà (buttonPin1)íàæàòà îòïðàâëÿåì ïàêåò (111)â Arduino ¹2
  if (digitalRead(buttonPin1) == HIGH){
    msg[0] = 111;
    radio.stopListening();
    radio.write(msg, 1);
  if (digitalRead(buttonPin2) == HIGH){
    msg[0] = 112;
receptor:
Quote
/*              êîä ¹2 äëÿ ïðè¸ìíèêà receiver
èäåîëîãèÿ;
èçìåíåíèÿ;
// ýòî ñêà÷àííàÿ áèáëèîòåêà RF24
#include <SPI.h>
#include "RF24.h"
int msg[1];
//SCK  -> 13
//MISO -> 12
//MOSI -> 11
//CSN  -> 10
//CE   -> 9
RF24 radio(9,10);
//ñâåòîäèîäû ïîäêëþ÷åíû ê ýòèì ïèíàì
int LEDpin1 = 2;
int LEDpin2 = 3;
void setup(void){
  radio.begin();
  radio.openWritingPipe(pipes[0]); // Îòêðûâàåì êàíàë ïåðåäà÷è
  radio.openReadingPipe(1, pipes[1]); // Îòêðûâàåì îäèí èç 6-òè êàíàëîâ ïðèåìà
  pinMode(LEDpin1, OUTPUT);
  pinMode(LEDpin2, OUTPUT);
void loop(void){
  if (radio.available()){
    bool done = false;
    while (!done){
      done = radio.read(msg, 1);
      //åñëè ïðèøåë ïàêåò îò Arduino ¹1 (111) âÊëþ÷àåòñÿ ñâåòîäèîä (ãîðèò)LEDpin1, HIGH
      if (msg[0] == 111){
        delay(10);
        digitalWrite(LEDpin1, HIGH);
      else {
        digitalWrite(LEDpin1, LOW);
      delay(10);
      if (msg[0] == 112){
        delay(10);
        digitalWrite(LEDpin2, HIGH);
      else {
        digitalWrite(LEDpin2, LOW);
      delay(10);
Si alguien puede comprobar este código, por favor.
Me pareció que los códigos en algún foro Ruso, pero no encuentro la velocidad en Baudios????
Las placas si cargan el programa pero al momento de utilizarlo no funciona.
Aclaro el programa en el "receptor" debe encender 2 leds dependiendo del numero (1) o (2) pero solo estoy interesado que esta placa muestre en RX que recive datos.
curro92
#1
Oct 10, 2013, 04:57 am Last Edit: Oct 10, 2013, 04:59 am by curro92 Reason: 1
Hola,
mi consejo: búscate unos ejemplos con código más inteligible; hay muchos,  por ejemplo, estos de acá
http://playground.arduino.cc/InterfacingWithHardware/Nrf24L01
y también estos
http://arduino-info.wikispaces.com/Nrf24L01-2.4GHz-HowTo
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
