Topic: add 16.2 lcd to display more than just temperature and humidity (Read 2233 times) previous topic - next topic
primo766
I would like to lcd 16.2 shows more than just temperature and humidity.
I would add buttonswitch when pressed for the first time to show you the exact time RTC following pressure on the switch to display the timer settings  ¨T1 on 18.15 off 6.00 & T2 on 18.15 off 6.15¨.
When I press the third time to return to the display of temperature and humidity.
let say  button swich is connected to digital pin 1
#define buttonpin1
but now I do not know how to proceed please help and explain the code
this is working code for now
Code: [Select]
#include "DHT.h"
#include <LiquidCrystal.h>
#include <Wire.h>
#include "RTClib.h"
// these arrays store timer data
// on hour, on minute, off hour, off minute
int t1[4]= {
  18,15,6,00};
int t2[4]= {
  18,15,6,10};
#define DHTPIN 7     // what pin we're connected to
#define tempcontpin 8 // temp output to control
#define humcontpin 9 // humidity output to control
#define timer1pin  6   // timer1 output to control lights
#define timer2pin  10   //timer2 output to control light-hood fan
#define DHTTYPE DHT22   // DHT 22  (AM2302)
RTC_DS1307 RTC; // define the Real Time Clock object
int maxT=0, minT=100;
int maxH=0, minH=100;
LiquidCrystal lcd(12,11,5,4,3,2);
DHT dht(DHTPIN, DHTTYPE);
//here is where the temp and hum setpoints are changed
int tempset=24, tempreset=22;
int humset=60,  humreset=55;
int tmem=0, hmem=0;
   // connect to RTC
  Wire.begin();
  RTC.begin();
  if (!RTC.isrunning()) {
    Serial.println("RTC is not running");
  Serial.println("DHTxx test!");
  dht.begin();
  lcd.begin(16, 2); // Set the display to 16 columns and 2 rows
  lcd.clear();
  //setup LEDs or output
  pinMode(tempcontpin, OUTPUT);
  pinMode(humcontpin, OUTPUT);
  pinMode(timer1pin, OUTPUT);
  pinMode(timer2pin, OUTPUT);
  // Reading temperature or humidity takes about 250 milliseconds!
  // Sensor readings may also be up to 2 seconds 'old' (its a very slow sensor)
  float h = dht.readHumidity();
  float t = dht.readTemperature();
  // check if returns are valid, if they are NaN (not a number) then something went wrong!
  if (isnan(t) || isnan(h)) {
    Serial.println("Failed to read from DHT");
    Serial.print("Humidity: ");
    Serial.print(h);
    Serial.print(" %\t");
    Serial.print("Temperature: ");
    Serial.print(t);
    Serial.println(" *C");
    lcd.setCursor(0,0);
        lcd.print("T");
        lcd.print(t);
      lcd.write(B11011111); // print degree symbol
  lcd.print("C ");
        lcd.setCursor(0,1);
        lcd.print("H");
        lcd.print(h);
        lcd.print("%");
  if (t>maxT) {maxT=t;}  //check for max temp
  if (t<minT) {minT=t;}  //check for min temp
        lcd.setCursor(9,0);
        lcd.print("Max");
        lcd.print(maxT);
        lcd.print("C");
        if (h>maxH)  {maxH=h;}  //check for max hum
        if (h<minH)  {minH=h;}  //check for min hum
        lcd.setCursor(9,1);
  lcd.print("Max");
  lcd.print(maxH);
  lcd.print("%");
  DateTime now = RTC.now();
  //Serial.print(now.unixtime()); // seconds since 1/1/1970
  //Serial.print(", ");
  Serial.print('"');
  Serial.print(now.year(), DEC);
  Serial.print("/");
  Serial.print(now.month(), DEC);
  Serial.print("/");
  Serial.print(now.day(), DEC);
  Serial.print(" ");
  Serial.print(now.hour(), DEC);
  Serial.print(":");
  Serial.print(now.minute(), DEC);
  Serial.print(":");
  Serial.print(now.second(), DEC);
  Serial.print('"');
  // check for timer1 on/off
    if (now.hour()==t1[0] && now.minute()==t1[1])
      digitalWrite (6, HIGH);
    if (now.hour()==t1[2] && now.minute()==t1[3])
      digitalWrite (6, LOW);
  // check for timer2 on/off
    if ((now.hour()==t2[0] && now.minute()==t2[1]))
         digitalWrite (10, HIGH);
    if (now.hour()==t2[2] && now.minute()==t2[3])
      digitalWrite (10, LOW);
   //Here is the section for control with hysterisis
   if (tempreset<=t && t<=tempset && tmem==1) {
     digitalWrite (8, HIGH);
   if (t>=tempset) {
     tmem=1,
   if (t<=tempreset) {
     tmem==0,
     digitalWrite (8,LOW);
   if (humreset<=h && h<=humset && hmem==1) {
     digitalWrite (9, HIGH);
   if (h>humset) {
     hmem==1,
   if (h<humreset) {
     hmem==0;
     digitalWrite (9, LOW);
itsgumby
Hey, I'm assuming you want to display the time and timers/alarms in one screen or page then display temp and humidity in another, sounds like you need some sort of a menu look at the examples & heres one http://forum.arduino.cc/index.php/topic,73119.0.html
Displaying the clock is already in your code just replace serial.print for lcd.print and add positions (set cursor) .
Dont forget about pump timers & mabye bluetooth ,ethernet or wireless so you can see whats going on on your phone and view alarms when your not there or even control stuff.
have fun
