Topic: Boost-Up Current Limit: L298N ...? (Read 1 time) previous topic - next topic
dgelman
Hello Community,
For my project, I would like to dedicate an L298N for a single motor.
I understand that the L298N has a dual H-bridge at 2A current source.  How would you pin the L298N to dedicate both H-bridges to one motor?
Does it cause any issues to be aware of?
Thank you,
Daniel
Dialup is the future.
johnwasser
See Figure 7 in the datasheet: "Figure 7 : For higher currents, outputs can be paralleled. Take care to parallel channel 1 with channel 4 and channel 2 with channel 3."
dgelman
Yes,
Thank you, how couldve I missed that!
Daniel
cr0sh
Note that when you do this (and actually, any time you go over about 1 amp on the L298) you're going to need a fairly beefy heatsink. The L298 is anything but efficient...
dgelman
cr0sh,
Even with loading, I doubt my motors will exceed 1A, but my board will consist the SMD package with the thermal pad.  I hope have a fairly large ground plane to dissipate heat as well as perhaps attach a small heat sink on top of chip.
Daniel
JimboZA
But why use an old technology like the 298 anyway?
Johannesburg hams call me: ZS6JMB on Highveld rep 145.7875 (-600 & 88.5 tone)
Dr Perry Cox: "Help me to help you, help me to help you...."
Your answer may already be here: https://forum.arduino.cc/index.php?topic=384198.0
terryking228
Can anyone point to a low-cost alternative module that is a good one-for-one replacement for L298N modules like those shown here ? :
http://arduino-info.wikispaces.com/MotorDrivers
Regards, Terry King terry@yourduino.com  - Check great prices, devices and Arduino-related boards at http://YourDuino.com
HOW-TO: http://ArduinoInfo.Info
o_lampe
Use DRV8833 for two dc Motors or pololu A4988 for a stepper motor
jremington
That page really needs updating! The technology has really been moving ahead, and chips like the A4988 offer current control, much higher torque (with higher voltage motor power supplies) than L298-based drivers, as well as microstepping with just two control pins. I'm very happy with the Pololu boards that I've been using, however they are limited to about 1.5 amps/winding without extra cooling. I'm hoping that Pololu comes out with higher current models soon. See http://www.pololu.com/catalog/product/2133
These not a one-for-one replacements for the L298, but the code needed to drive the board is simpler.
