Pages: [1] 2 3 4   Go Down
Author Topic: n00b SPI problem  (Read 4570 times)
hello! smiley-grin
i have an arduino skinny (made by sparkfun) that i'm trying to get to talk to an scp1000 pressure sensor via spi. this is the first time i've tried to use the spi interface, and have to admit that i'm floundering a bit. here's the code i'm using:
// define spi bus pins
#define SLAVESELECT 10
#define SPICLOCK 13
#define DATAOUT 11      //MOSI
#define DATAIN 12       //MISO
//Addresses
#define REVID 0x00      //ASIC Revision Number
#define OPSTATUS 0x04   //Operation Status
#define STATUS 0x07     //ASIC Status
char lsb_in_byte;           //
  byte clr;
  pinMode(DATAOUT, OUTPUT);
  pinMode(DATAIN, INPUT);
  pinMode(SPICLOCK,OUTPUT);
  pinMode(SLAVESELECT,OUTPUT);
  digitalWrite(SLAVESELECT,HIGH); //disable device
  SPCR = B01010011; //MPIE=0, SPE=1 (on), DORD=0 (MSB first), MSTR=1 (master), CPOL=0 (clock idle when low), CPHA=0 (samples MOSI on rising edge), SPR1=0 & SPR0=0 (500kHz)
//  SPI2X=0; //No clock multiplier
  clr=SPSR;
  clr=SPDR;
  delay(10);
  Serial.begin(9600);                        // Connect to the serial port 9600 bps
  Serial.println("SCP1000 Code v0.01");
  lsb_in_byte = read_register(REVID);
  Serial.print("REVID [");
  Serial.print(lsb_in_byte, HEX);
  Serial.println("]");
  lsb_in_byte = read_register(OPSTATUS);
  Serial.print("OPSTATUS [");
  lsb_in_byte = read_register(STATUS);
  Serial.print("STATUS [");
  delay(5000);
char spi_transfer(volatile char data)
  SPDR = data;                    // Start the transmission
  while (!(SPSR & (1<<SPIF)))     // Wait for the end of the transmission
  return SPDR;                    // return the received byte
//Read 8-bit register
char read_register(char register_name)
    char in_byte;
    register_name |= 128; //Read command
    digitalWrite(SLAVESELECT,LOW); //Select SPI Device
    in_byte = spi_transfer(register_name); //Write byte to device
    //in_byte is nothing, we need to clock in another 8 bits
    in_byte = spi_transfer(0x00); //Send nothing, but we should get back the register value
    return(in_byte);
//Sends a write command to SCP1000
void write_register(char register_name, char register_value)
    char in_byte;
    register_name &= 127; //Write command
    digitalWrite(SLAVESELECT,LOW); //Select SPI device
    in_byte = spi_transfer(register_name); //Send register location
    in_byte = spi_transfer(register_value); //Send value to record into register
and here's the output i'm getting:
SCP1000 Code v0.01
REVID [0]
OPSTATUS [0]
STATUS [0]
REVID [0]
OPSTATUS [0]
STATUS [0]
REVID [0]
OPSTATUS [0]
STATUS [0]
REVID [0]
OPSTATUS [0]
STATUS [0]
REVID [0]
OPSTATUS [0]
STATUS [0]
no matter which register i read from, i just get zero. smiley-sad any help would very much be appreciated! smiley-grin
jules.
« Last Edit: June 11, 2008, 04:13:45 pm by zzpza » Logged
Las Vegas, NV
I've only skimmed your code, but it looks like you're handling the SPI communication correctly.  Do you have access to an oscilloscope?  It would be helpful if you could see what your MOSI, MISO, and SCK lines look like.  Have you verified that you're using an SPI clock speed that your sensor can handle?  Is there anything in the datasheet about a required delay between when you send the register address and when you initiate the junk-byte transmission that will retrieve data from the sensor?
I made a post recently to help someone with an SPI problem here:
http://forum.pololu.com/viewtopic.php?f=1&t=986
My post links to some sample mega644 code for performing SPI communication, but this should be almost identical (if not exactly identical) to what you'd do on the mega168.
- Ben
Lacomb, Oregon
Here is the document from vti that I used to adapt the code to Propeller spin code.
Stephen
Thank you bens and franklin! smiley
It was a timing issue. I added a delay(10); after asserting the slaveselect and the data started to flow. smiley
Can you post the working code?
« Last Edit: July 27, 2008, 08:36:34 pm by zlite » Logged
N. VA
I have completed the code for the SCP and the following should print out temperature in Fahrenheit and pressure in Pascals. The other register are defined if you wanted to return the revision ID or opstatus etc. I think the problem the author had was not timing but never sending a initial command to choose the SCP operation mode. This line is in the setup(). Feel free to ask a question or let me know if you see something inefficient or wrong.
#define SPICLOCK 13
#define UBLB(a,b)  ( ( (a) << 8) | (b) )
#define UBLB19(a,b) ( ( (a) << 16 ) | (b) )
//Addresses
#define START 0x0A      //Constant Readings
#define PRESSURE 0x1F   //Pressure 3 MSB
#define PRESSURE_LSB 0x20 //Pressure 16 LSB
#define TEMP 0x21       //16 bit temp
char rev_in_byte;
int temp_in;
unsigned long pressure_lsb;
unsigned long pressure_msb;
unsigned long temp_pressure;
unsigned long pressure;
  byte clr;
  clr=SPSR;
  clr=SPDR;
  delay(10);
  Serial.println("Initialize High Speed Constant Reading Mode");
  write_register(0x03,0x09);
  rev_in_byte = read_register(REVID);
  pressure_msb = read_register(PRESSURE);
  pressure_msb &= B00000111;
  pressure_lsb = read_register16(PRESSURE_LSB);
  pressure = UBLB19(pressure_msb, pressure_lsb);
  pressure /= 4;
  Serial.print("PRESSURE [");
  Serial.print(pressure, DEC);
  temp_in = read_register16(TEMP);
  temp_in = temp_in / 20;
  temp_in = ((1.8) *temp_in) + 32;
  Serial.print("TEMP F [");
  Serial.print(temp_in , DEC);
  delay(1500);
    char in_byte;
    register_name <<= 2;
    register_name &= B11111100; //Read command
    delay(10);
    return(in_byte);
float read_register16(char register_name)
    byte in_byte1;
    byte in_byte2;
    float in_word;
    in_byte1 = spi_transfer(0x00);
    in_byte2 = spi_transfer(0x00);
    in_word = UBLB(in_byte1,in_byte2);
    return(in_word);
    register_name |= B00000010; //Write command
Hurray! It works great. Thanks SO much for posting that! You saved me hours of frustration ;0)
Lacomb, Oregon
Conor, sorry to bring up an old thread but I tried your code and it worked but I noticed if I had power to the SCP1000 it would heat up and if I removed power it still worked. How did you have yours hooked up to the Arduino? Thanks.
Stephen
N. VA
Franklin,
     I have not noticed any over heating by the SCP. It is a 3.3 V device, so if you are using a 5v arduino to power it that might be the problem. I am using the voltage and ground from a Sparkfun wee (lillypad equivalent). Other than that, pins 10-13 for ss, sck, mosi, miso.
I'm running this code on a Funnel IO from Sparkfun, which is a 3.3v/8MHz Arduino.
I'm getting good serial communications, but all 0's when I run the code.  (Every once in a while, I get random numbers).
Any ideas?
So it's now working (hurray!)
UPDATED: Scratch that, it was actually a bad wiring problem on my part.
UPDATED 2: I'm getting weird readings, like:
MSB = 0x5
LSB = 0xFFFFE6F0
Which means my pressure is 0x5FFFFE6F0, which just seems a bit high for 1000ft above sea level?
My temperature is reasonable (currently 22.8C), and adjusts accordingly, and my Pressure reading has jitter in it of about the right magnitude.
The 0xFFFF in the first half of the LSB is suspicious to me, but I'm running verbatim the code posted above.
« Last Edit: February 11, 2009, 09:57:06 am by bpeoples » Logged
Just as an update, I have it working now!
Here's the code I needed to do to make it work:
pressure_lsb &= 0x0000FFFF;
Does this make any sense at all?
My read_register16 function looks thus:
    byte in_byte1;
    byte in_byte2;
    float in_word;
    return(in_word);
Could this be because of the cast from float to unsigned long?  I'm using Arduino 0013, did the types change between then and now?
Hello,
I'm trying to get Temp and Pressure with a SCP1000 using the code above.
I've got
PRESSURE [123007]
TEMP F [21]
PRESSURE [123007]
TEMP F [21]
Strange values.
Below is the wiring to Arduino Pro Mini
SCK -> pin 13
MISO -> pin 12
MOSI -> pin 11
Now I got a doubt. From the program above :
SLAVESELECT 10
What is SLAVESELECT  from the SCP1000. I'm using Sparkfun breadk out, and got only CSB / DRDY.
How should I connect SLAVESELECT  ?
Thanks for your help.
Mersing.
Is it possible to use 2 scp1000 sensors with a single arduino?  If so, how do you identify which is which?
MOSI, MISO, and SCK are buses, but the chip select is unique for each device.  If the device is a correctly designed SPI device, just wire the second one up identical to the first, except use a different line for chip select.
-j
Pages: [1] 2 3 4   Go Up
