Topic: [SOLVED] TL082 preamp: help please! (Read 32778 times) previous topic - next topic
rlogiacco
Oct 13, 2013, 04:50 pm Last Edit: Dec 01, 2013, 11:02 pm by rlogiacco Reason: 1
Hi, I need your help, please: I don't understand why my pre amp is not working, I've tried many configurations, the one attached being the last one, but I don't get much amplitude boost on the signal detected on the arduino side.
I don't have an oscilloscope and I'm using my laptop/mobile phone to generate a test sinewave.
Please help!
UPDATE
The goal of the project is to have my Arduino Uno identify two sine wave frequencies and amplitudes, separately for left and right channel. Sine wave frequencies are going to be low, something between 50 and 200Hz, even lower if needed due to Arduino processing speed.
Because the source of those waves is going to be a mobile phone (candidates are iPhone/iPod and Android phones) the input should be something around +/-200mV which I wish to boost and shift to 0-5V for the Arduino to correctly process them.
If necessary the sine waves can be changed to chainsaw or square waves to simplify identification.
Please, do not send me personal messages containing forum related questions: I will not answer.
I share my discoveries and thoughts at http://rlogiacco.wordpress.com
retrolefty
Op-amp input connections not correct and there will be no gain as drawn.
You need to connect a ground wire from the external op-amp supply negative to a arduino ground pin.
Lefty
rlogiacco
Hi Lefty,
First of all thanks for your time.
I tried many configurations sharing ground with Arduino, nonetheless I tried what you did suggest in it's simplest form and with the attached configuration I believe I'm raising the midpoint as my A0 measure is raising from 512 to 970 (when connected to audio source, still around 512 when disconnected).
I thought it would be a protection to have the preamp and the arduino on two separate circuits (excluding the opamp obviously). Is it possible my first configuration is wrong because I need to source a negative voltage to the TL082?
Thanks folks, I appreciate your help!
rlogiacco
On top of what I just reported I believe there's something wrong in the capacitors as the circuit looks very slow in response: consider I'm testing it with one single pure sine wave of about 100Hz and looking at the A0 value it seems it gets levelled out.
Once again I'm just guessing as I don't have an oscillator to measure what's going on (I'm tempted to get one!).
May be it will be easier if I just describe what I intend to achieve: I want to process two pure sine or square waves (left & right channel separately) to identify amplitude and frequency of each one. The two waves will have a frequency between 100Hz and 200Hz with an amplitude between -80dB and 0dB.
The two waves gets generated on a stereo audio source and I believe such source are AC between -200mV and 200mV so I need to shift and amplify before process on the arduino side.
Right now I'm just sampling and printing on the serial console the raw 10 bits value to test my pre amp circuit.
Any help is appreciated.
rlogiacco
Ok, I elaborated a new design after googling about the TL082 which seems to require some negative voltage to properly work.
I'm practically applying a voltage divider at my source and grounding my arduino and circuit at it's joint point to produce a +6V and -6V sources for the TL082. With this circuit in place I'm getting some amplification which I'm then able to trim through the potentiometer (may be the potentiometer is wrongly connectetd as I'm getting a non linear amplification).
I've then connected my Uno serial into SerialChart (https://code.google.com/p/serialchart/) to get a plot of my  sampling activity.
After playing a bit with the baud rate and the loop delay I managed to get the attached graph for a chainsaw wave of 20Hz in which I can identify some sort of resonance which I tried to highlight with the red line: what is that and what is causing it?
As usual, I want to thank everybody that will spend some time to have a look at this and double thank those that will provide some help  XD
Grumpy_Mike
Yur op am circuit is still wrong, google for op amp inverting amplifier, look at what you need n the +ve input. You have not got the biasing right.
rlogiacco
@Grumpy_Mike I did Google a lot before posting here Mike, would you please give me directions? I thought this time it was right... I'm so noob that I don't know what biasing is.... and I'm going to Google for that right now, but you might imagine it's not that easy to fix that circuit on my own having so much to learn.
g_u_e_s_t
biasing always confused me when i was first getting started.  im working on an online tool to help out with this:
http://www.openmusiclabs.com/testpage/
it may or may not work, making webpages is not really my thing.  actually, using computers must not be my thing, considering i can no longer view much of anything on this webiste since they updated it.
basically, you take 2 equal value resistors, and connect one to 5V, the other to ground, and the juncture between them goes to the positive input of your amplifier.  the TL082 needs about 3V of headroom, so the +Vcc pin (postive powersupply) wil need more than 8V, and the -Vee pin (negative power supply) will need at least -3V.  otherwise they make different opamps that can go all the way to the rails, so you can just use +5V and ground as your supplies.
cyberteque
This is the circuit for my ultra sonic receiver
Version 1A pretty much what you want to do
the voltage divider is to get around needing a negative supply, both stages have a gain of 100
rlogiacco
Are you using 2 dual op amps and 4 pots?
I'm using a voltage divider to get around the negative voltage as well splitting in 2 a 12V source and using the middle one as gnd
runaway_pancake
#10
Oct 20, 2013, 09:38 pm Last Edit: Oct 20, 2013, 09:40 pm by Runaway Pancake Reason: 1
This preamp design stuff really isn't as trivial as it may seem.
"Who is like unto the beast? who is able to make war with him?"
When all else fails, check your wiring!
rlogiacco
First of all I thought I was using a non-inverting IC (TL082) so I was expecting to build up a non-inverting amplifier, why are you suggesting to google for inverting amplifiers?
Second, I'm trying to build something I've found on Google, so may be I need something different than "google for it" and I know it's my fault, but that sentence honestly doesn't help.
Third, I've now read a lot about biasing, which I probably don't get, but where is my circuit wrongly biased?
Four and last, why am I getting that resonance on the amplified signal trace?
Thanks to everyone willing to help
runaway_pancake
Which version?  The second?
There you have (well... what?):
BAT1 + going to the IC's pin? and BAT1 - going to the top of a pot the other end which is connected to UNKnown and its wiper going to Gnd.
rlogiacco
No, I understand first and second versions cannot work, but I believe I managed to have it working in the third version, apart for the weird resonance in the output I'm concerned about... And there might still be huge errors there I'm unable to see.
I know my questions might be poorly posted and about silly topics, but I'm a Software Developer with no electronics knowledge other than some high school lessons....
Please be patient with me as I am when I try to help electronic engineers regarding programming issues.....
cyberteque
I started of with a QUAD opamp, a TL084, then went to two dual opamps, TLO82's.
At 40Khz I was getting WAY too much cross talk between channels.
For the record it's not trivial, but it really isn't hard.
The main issues here is use multiple stages of gain instead of a single high gain stage.
When using a DUAL SUPPLY opamp you need to remember to supply biasing, thats what I've done with the voltage dividers on the positive input.
Don't try and build a non-inverting amp, go for an inverting amp, you should be able to adjust your biasing with a decent meter.
One thing I can sugest is get an old analog CRO, don't spend hundreds on a DSO, you will learn a lot just messing around with opamps and a decent 10-20Mhz CRO.
