Topic: I2C LCD **no data sheet** HOW TO CONNECT (Read 5323 times) previous topic - next topic
latenite
Hi folks,
I have an arduinoboard and would like to connect a LCD Display.
My local electronic parts shop sold me this one:
BUT they had no data sheet at all. I am clueless how to make it work with arduino. I don t even know where to connect the power for the backlight. Nor do I know how to make it work -> display text with the help of the I2C libraries.
The only thing I know is the numbers on the back:
LCM015 R2.1 SN 102 94V
and a "Kl" maybe a vendor??
Any help is greatly appreciated.
cr0sh
Possibly the two pads at the immediate ends/edges/corners of the board are for the backlight...possibly.
MikMo
Check this site:
http://www.oppermann-electronic.de/html/januar_2008.html
It's in german, but the pinout is explained.
It's basically a standard HD44780 display with a PCF8574 I2C interface IC on board.
"Hintergrundbeleuchtung" is german for backlight, the rest of the pinout should be understandable even for the non german speaking.
cr0sh
Based on what I could find, this LCD is likely an HD44780 compatible display, but it has an I2C interface in front of that chipset; without a datasheet (I couldn't find anything - a few people asking about it, though), it would be nearly impossible to figure out.
If I were you, I would return it and get your money back - if you can. If not, put the LCD in your box of "get 'round toit" items, and come back in 6 months or a year, and see if anything pops up searching again.
You may just have to chalk it up as "bad luck" (I have a few LCDs that fall into the category myself)...
cr0sh
Well - MikMo has solved a big part of the mystery; from the datasheet for the PCF8574 (http://www.nxp.com/documents/data_sheet/PCF8574.pdf) it looks like there are 3 address set bit lines from the chip (A0-2, pins 1-3) - so you would either have to figure that out, or program the I2C to do the HD44780 setup, and try the 8 different addresses until one of them works...
I'll have to look at my LCDs I picked up that were I2C (IIRC) - maybe they use the same I2C expander chip...
MikMo
From above link it looks like it uses I2C address  0x4e and it can not be changed.
latenite
Thank you so so much I got the display to light up and with VCC 5v on, it shows black blocks where the letters should be.
Now I don't get the code to run. I use the library:
https://public.me.com/digid
from
http://www.wentztech.com/radio/arduino/files/LCDI2C.html
it has a hello world in its examples.
I am clueless where to copy the "LCDI2C.cpp" and "LCDI2C.h" to!!!
I coped them to :
localhost libraries # pwd
/usr/share/arduino-0017/hardware/libraries
localhost libraries # ls -la
total 52
drwxr-xr-x 13 root uucp 4096 Aug 27 01:31 .
drwxr-xr-x  6 root uucp 4096 Aug 26 17:10 ..
drwxr-xr-x  3 root uucp 4096 Aug 26 17:10 EEPROM
drwxr-xr-x  4 root uucp 4096 Aug 26 17:10 Ethernet
drwxr-xr-x  3 root uucp 4096 Aug 26 17:10 Firmata
drwxr-xr-x  3 root uucp 4096 Aug 27 01:33 LCDi2c
drwxr-xr-x  3 root uucp 4096 Aug 26 17:10 LiquidCrystal
drwxr-xr-x  3 root uucp 4096 Aug 26 17:10 Matrix
drwxr-xr-x  3 root uucp 4096 Aug 26 17:10 Servo
drwxr-xr-x  3 root uucp 4096 Aug 26 17:10 SoftwareSerial
drwxr-xr-x  2 root uucp 4096 Aug 26 17:10 Sprite
drwxr-xr-x  3 root uucp 4096 Aug 26 17:10 Stepper
drwxr-xr-x  4 root uucp 4096 Aug 26 17:10 Wire
localhost libraries # ls -la LCDi2c/
total 68
drwxr-xr-x  3 root uucp  4096 Aug 27 01:33 .
drwxr-xr-x 13 root uucp  4096 Aug 27 01:31 ..
-rwxr-xr-x  1 root uucp  7359 Aug 27 01:33 LCDI2C.cpp
-rwxr-xr-x  1 root uucp  1822 Aug 27 01:33 LCDI2C.h
-rw-r--r--  1 root uucp 33540 Aug 27 01:33 LCDI2C.o
-rw-r--r--  1 root uucp  4500 Aug 27 01:33 README LCDI2C.rtf
drwxr-xr-x  8 root uucp  4096 Aug 27 01:33 examples
but this only get me:
[code]20: error: LCDI2C.h: No such file or directory In function 'void setup()':
Bad error line: -2
on that code
#include <Wire.h>
#include <LCDI2C.h>
LCDI2C lcd = LCDI2C(2,10,0x4E,1);             // Number of lines and i2c address of the display
 lcd.init();
 lcd.print("Hello World!");
So I feel like I have to install this library differntly. But how?
thank you already :=
[/code]
PaulS
Try changing the name of the directory to all upper case, to match the file names.
latenite
I got it to upload correctly. I had to put the libraries into /home/sketchbook/libraries/LCD/
Now I feel like my Display and the libraries don't fit together.
How can I make the Display work? (Do I have to change something in the libraries??)
Thank you
