Topic: PaulS - 40,000 posts! (Read 3925 times) previous topic - next topic
CrossRoads
Oct 17, 2013, 03:38 pm Last Edit: Oct 17, 2013, 04:26 pm by CrossRoads Reason: 1
Congrats to PaulS. 40,000 posts! Wow.
CrossRoads
PaulS              40003
Grumpy_Mike  27899
AWOL             21325
CrossRoads    19364
leo72             19016
uwefed           17450
nickgammo    17217
retrolefty       15662
menniti          11346
Coding Badly  11008
robtillaart       10641
Just eclipses the other current 5 digit posters ...
retrolefty
PaulS              40003
Grumpy_Mike  27899
AWOL             21325
CrossRoads    19364
leo72             19016
uwefed           17450
nickgammo    17217
retrolefty       15662
menniti          11346
Coding Badly  11008
robtillaart       10641
As if size really matters.   ;)
Lefty
Jantje
Lefty
No but it is worth a congrats.  ]:D
Congratulations Paul on this incredible number of posts.
best regards
Jantje
Do not PM me a question unless you are prepared to pay for consultancy.
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
nickgammon
#4
Oct 17, 2013, 11:01 pm Last Edit: Oct 17, 2013, 11:05 pm by Nick Gammon Reason: 1
Congrats, Paul! I made a special display in honour of your achievement:
Yes, that's blue-tack on the left. My hardware skills aren't that great.
Code to reproduce:
Code: [Select]
#include <SPI.h>
// MAX7219 registers
const byte MAX7219_REG_NOOP        = 0x0;
// codes 1 to 8 are digit positions 1 to 8
const byte MAX7219_REG_DECODEMODE  = 0x9;
const byte MAX7219_REG_INTENSITY   = 0xA;
const byte MAX7219_REG_SCANLIMIT   = 0xB;
const byte MAX7219_REG_SHUTDOWN    = 0xC;
const byte MAX7219_REG_DISPLAYTEST = 0xF;
// 7-segments patterns for digits 0 to 9
const byte digits [10] = {
 0b1111110,  // 0
 0b0110000,  // 1
 0b1101101,  // 2
 0b1111001,  // 3
 0b0110011,  // 4
 0b1011011,  // 5
 0b1011111,  // 6
 0b1110000,  // 7
 0b1111111,  // 8
 0b1111011,  // 9
// send one byte via  SPI to MAX7219
void sendByte (const byte reg, const byte data)
 digitalWrite (SS, LOW);
 SPI.transfer (reg);
 SPI.transfer (data);
 digitalWrite (SS, HIGH);
 }  // end of sendByte
// send one character (data) to position (pos) with or without decimal place
// pos is 0 to 7
// data can be '0' to '9' plus various other things as below
void sendChar (const byte pos, const char data, const bool dp = false)
 byte converted;
 switch (data)
   case '0' ... '9' : converted = digits [data - '0']; break;
   case '-':          converted = 0b0000001;  break;
   case 'A':          converted = 0b1110111;  break;
   case 'b':          converted = 0b0011111;  break;
   case 'c':          converted = 0b0001101;  break;
   case 'C':          converted = 0b1001111;  break;
   case 'd':          converted = 0b0111101;  break;
   case 'E':          converted = 0b1001111;  break;
   case 'F':          converted = 0b1000111;  break;
   case 'h':          converted = 0b0010111;  break;
   case 'H':          converted = 0b0110111;  break;
   case 'L':          converted = 0b0001110;  break;
   case 'o':          converted = 0b0011101;  break;
   case 'P':          converted = 0b1100111;  break;
   case 'r':          converted = 0b0000101;  break;
   case 'S':          converted = 0b1011011;  break;
   case 't':          converted = 0b0000111;  break;
   case 'u':          converted = 0b0011100;  break;
   case 'U':          converted = 0b0111110;  break;
   case ' ':          converted = 0b0000000;  break;
   case 'I':          converted = digits [1]; break;
   default:           converted = 0b0000001;  break;  // -
   } // end of switch
 if (dp)
   converted |= 0b10000000;
 sendByte (8 - pos, converted);
 }  // end of sendChar
// write an entire null-terminated string to the LEDs
void sendString (const char * s)
 byte pos;
 for (pos = 0; pos < 8 && *s; pos++)
   boolean dp = s [1] == '.';
   sendChar (pos, *s++, dp);   // turn decimal place on if next char is a dot
   if (dp)  // skip dot
     s++;
 // space out rest
 while (pos < 8)
   sendChar (pos++, ' ');
}  // end of sendString
 SPI.begin ();
 sendByte (MAX7219_REG_SCANLIMIT, 7);      // show 8 digits
 sendByte (MAX7219_REG_DECODEMODE, 0);     // use bit patterns
 sendByte (MAX7219_REG_DISPLAYTEST, 0);    // no display test
 sendByte (MAX7219_REG_INTENSITY, 7);      // character intensity: range: 0 to 15
 sendByte (MAX7219_REG_SHUTDOWN, 1);       // not in shutdown mode (ie. start it up)
 sendString ("PAULS");
 delay (10000);
 sendString ("40000");
 } // end of setup
void loop () {}
For anyone that wants to make one, the MAX7219 board is available from eBay for around $10.
Please post technical questions on the forum, not by personal message. Thanks!
More info: http://www.gammon.com.au/electronics
Grumpy_Mike
Yes that is some total. Well done Paul, hats off to you.
John_Smith
And on behalf of the recipients of those posts -  thank you for your help .
45 years of editing projects with a knife and soldering iron, then I found Arduino !
Palliser
nickgammon
Wait a minute, he's still a Brattain Member. What do you have to do to advance past that? 50,000 posts?
CrossRoads
#9
Oct 18, 2013, 09:01 am Last Edit: Oct 18, 2013, 09:03 am by CrossRoads Reason: 1
And what's the level called? Curmudgeon? 8)
"a person (especially an old man) who is easily annoyed or angered and who often complains"
Maybe not, that is a bit on the harsh side  :smiley-eek-blue:
JChristensen
Curmudgeon would be a good name for the next level. I made up some "Curmudgeon" certificates at work once and handed a couple out. Kept one for myself of course :D
I was all confused. I was running a recent project that Nick posted, I thought it was a real-time display of Paul's post count. Now that I read closer, I find it's prime numbers or some such thing.
Just the same Paul, WAY TO GO!
John_Smith
That sounds a bit grumpy ?
Palliser
#12
Oct 18, 2013, 06:33 pm Last Edit: Oct 18, 2013, 06:35 pm by Palliser Reason: 1
Given that this theme (50K Member level) has been touched, I'd honor a living Italian genius of our time: Federico Faggin. Regards!
CrossRoads
http://www.computerhistory.org/fellowawards/hall/bios/Federico,Faggin/
Nope, he's still alive! Gotta be somebody older, like Shockley
http://www.nytimes.com/learning/general/onthisday/bday/0213.html
"Trial and Error
The team of Dr. Shockley, Dr. Brattain and Dr. Bardeen started out with the concept of the tubeless radio and proceeded from there by trial and error or, as Dr. Shockley later put it, by ''creative-failure methodology.''
''A basic truth that the history of the creation of the transistor reveals,'' he said, ''is that the foundations of transistor electronics were created by making errors and following hunches that failed to give what was expected.''
The team eventually chose silicon and germanium for their semiconductor and, in a rush of discoveries, reached the breakthroughs and successes that produced Dr. Shockley's ''magic month'' of 1947.
The devices, called transistors because they transferred current across a resistor, were built into a telephone, a radio and a television unit that Bell used in making the public introduction at a press conference in June 1948."
CrossRoads
Sounds like my programming style  8)
