Topic: Code to control TB6612FNG motor driver (Read 18824 times) previous topic - next topic
JoakimCh
Jan 19, 2010, 12:43 am Last Edit: Jan 19, 2010, 01:06 am by JoakimCh Reason: 1
TB6612FNG motor driver:
http://www.sparkfun.com/commerce/product_info.php?products_id=9457
Some code demonstrating how to use this motor driver:
Code: [Select]
//Configure these to fit your design...
#define out_STBY 5
#define out_B_PWM 3
#define out_A_PWM 11
#define out_A_IN2 9
#define out_A_IN1 10
#define out_B_IN1 8
#define out_B_IN2 7
#define motor_A 0
#define motor_B 1
#define motor_AB 2
 pinMode(out_STBY,OUTPUT);
 pinMode(out_A_PWM,OUTPUT);
 pinMode(out_A_IN1,OUTPUT);
 pinMode(out_A_IN2,OUTPUT);
 pinMode(out_B_PWM,OUTPUT);
 pinMode(out_B_IN1,OUTPUT);
 pinMode(out_B_IN2,OUTPUT);
 motor_standby(false);
 motor_speed2(motor_A,-100);
 motor_speed2(motor_B,-100);
 delay(2000);
 for (int i=-100; i<100; i++) {
   motor_speed2(motor_A,i);
   motor_speed2(motor_B,i);
   delay(50);
 delay(2000);
 motor_standby(true);
void motor_speed2(boolean motor, char speed) { //speed from -100 to 100
 byte PWMvalue=0;
 PWMvalue = map(abs(speed),0,100,50,255); //anything below 50 is very weak
 if (speed > 0)
   motor_speed(motor,0,PWMvalue);
 else if (speed < 0)
   motor_speed(motor,1,PWMvalue);
 else {
   motor_coast(motor);
void motor_speed(boolean motor, boolean direction, byte speed) { //speed from 0 to 255
 if (motor == motor_A) {
   if (direction == 0) {
     digitalWrite(out_A_IN1,HIGH);
     digitalWrite(out_A_IN2,LOW);
     digitalWrite(out_A_IN1,LOW);
     digitalWrite(out_A_IN2,HIGH);
   analogWrite(out_A_PWM,speed);
     digitalWrite(out_B_IN1,HIGH);
     digitalWrite(out_B_IN2,LOW);
     digitalWrite(out_B_IN1,LOW);
     digitalWrite(out_B_IN2,HIGH);
   analogWrite(out_B_PWM,speed);
void motor_standby(boolean state) { //low power mode
 if (state == true)
   digitalWrite(out_STBY,LOW);
   digitalWrite(out_STBY,HIGH);
void motor_brake(boolean motor) {
void motor_coast(boolean motor) {
   digitalWrite(out_A_PWM,HIGH);
   digitalWrite(out_B_PWM,HIGH);
You might wanna change this line depending on your motors:
For "Micro Metal Gearmotor 30:1" 50 is the minimum PWM I wanted to give it, stronger engines can have a value closer to zero though.
Wanna remote control it?
Like I do in this video: http://www.facebook.com/v/295202320029
Then get BlueSMiRF or similar and put this in setup():
Code: [Select]
Then put this in the loop():
Code: [Select]
 byte data, length, motor, command; //0-255
 char speed; //-128-128
 data = Serial.available();
 if (data > 0) {
   length = Serial.read();
   while (data < length-1) { //wait until we got everything
     data = Serial.available(); delay(20); //todo: add timeout
   command = Serial.read();
   switch (command) {
     case 0: //speed
       motor = Serial.read();
       speed = Serial.read();
       if (motor == motor_AB) {
         motor_speed2(motor_A,speed);
         motor_speed2(motor_B,speed);
         motor_speed2(motor,speed);
     case 1: //brake
         motor_brake(motor_A);
         motor_brake(motor_B);
         motor_brake(motor);
     case 2: //coast
         motor_coast(motor_A);
         motor_coast(motor_B);
         motor_coast(motor);
     case 3: //standby
       motor_standby(Serial.read());
But how to steer it?
Well, use your brain... I'll give a hint though, this is to set motor 1 to max backward speed:
byte1 = 4 //this is the total size of message
byte2 = 0 //this is the command id
byte3 = 1 //motor id, 0 or 1
byte4 = -100 //backward = -value (0 to 100)
HaydenR
Thanks. This is exactly what i need.  :)
Much appreciated.
HaydenR
Can you share how you hooked up the motor driver to the arduino? Thanks
BrianJHodge
Your code saved my life JoakimCh :D
I was lost trying to figure out how to wire the motor driver to my arduino until I found the pin definitions in your code.
I was happy to credit you on my project page :) (Found on my WWW link below my post. Pictures coming soon!)
OpenSource
#4
Aug 27, 2010, 06:52 pm Last Edit: Aug 27, 2010, 07:28 pm by OpenSource Reason: 1
I have written a library for the motor control:
http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1280519240
I will upload it to the playground if people think it is useful and want to use it.
Cheers.
BTW: JoakimCh, I've seen you video on facebook.
I am actually doing exactly the same, only my car is controlled using a nordic module (from sparkfun) and a GamePad  :)
