TB6612FNG motor driver:
http://www.sparkfun.com/commerce/product_info.php?products_id=9457Some code demonstrating how to use this motor driver:
//Configure these to fit your design...
#define out_STBY 5
#define out_B_PWM 3
#define out_A_PWM 11
#define out_A_IN2 9
#define out_A_IN1 10
#define out_B_IN1 8
#define out_B_IN2 7
#define motor_A 0
#define motor_B 1
#define motor_AB 2
pinMode(out_STBY,OUTPUT);
pinMode(out_A_PWM,OUTPUT);
pinMode(out_A_IN1,OUTPUT);
pinMode(out_A_IN2,OUTPUT);
pinMode(out_B_PWM,OUTPUT);
pinMode(out_B_IN1,OUTPUT);
pinMode(out_B_IN2,OUTPUT);
motor_standby(false);
motor_speed2(motor_A,-100);
motor_speed2(motor_B,-100);
delay(2000);
for (int i=-100; i<100; i++) {
motor_speed2(motor_A,i);
motor_speed2(motor_B,i);
delay(50);
delay(2000);
motor_standby(true);
void motor_speed2(boolean motor, char speed) { //speed from -100 to 100
byte PWMvalue=0;
PWMvalue = map(abs(speed),0,100,50,255); //anything below 50 is very weak
if (speed > 0)
motor_speed(motor,0,PWMvalue);
else if (speed < 0)
motor_speed(motor,1,PWMvalue);
else {
motor_coast(motor);
void motor_speed(boolean motor, boolean direction, byte speed) { //speed from 0 to 255
if (motor == motor_A) {
if (direction == 0) {
digitalWrite(out_A_IN1,HIGH);
digitalWrite(out_A_IN2,LOW);
digitalWrite(out_A_IN1,LOW);
digitalWrite(out_A_IN2,HIGH);
analogWrite(out_A_PWM,speed);
digitalWrite(out_B_IN1,HIGH);
digitalWrite(out_B_IN2,LOW);
digitalWrite(out_B_IN1,LOW);
digitalWrite(out_B_IN2,HIGH);
analogWrite(out_B_PWM,speed);
void motor_standby(boolean state) { //low power mode
if (state == true)
digitalWrite(out_STBY,LOW);
digitalWrite(out_STBY,HIGH);
void motor_brake(boolean motor) {
void motor_coast(boolean motor) {
digitalWrite(out_A_PWM,HIGH);
digitalWrite(out_B_PWM,HIGH);
You might wanna change this line depending on your motors:
For "Micro Metal Gearmotor 30:1" 50 is the minimum PWM I wanted to give it, stronger engines can have a value closer to zero though.
Wanna remote control it?Like I do in this video:
http://www.facebook.com/v/295202320029Then get BlueSMiRF or similar and put this in setup():
Then put this in the loop():
byte data, length, motor, command; //0-255
char speed; //-128-128
data = Serial.available();
if (data > 0) {
length = Serial.read();
while (data < length-1) { //wait until we got everything
data = Serial.available(); delay(20); //todo: add timeout
command = Serial.read();
switch (command) {
case 0: //speed
motor = Serial.read();
speed = Serial.read();
if (motor == motor_AB) {
motor_speed2(motor_A,speed);
motor_speed2(motor_B,speed);
motor_speed2(motor,speed);
break;
case 1: //brake
motor_brake(motor_A);
motor_brake(motor_B);
motor_brake(motor);
break;
case 2: //coast
motor_coast(motor_A);
motor_coast(motor_B);
motor_coast(motor);
break;
case 3: //standby
motor_standby(Serial.read());
break;
But how to steer it?Well, use your brain... I'll give a hint though, this is to set motor 1 to max backward speed:
byte1 = 4 //this is the total size of message
byte2 = 0 //this is the command id
byte3 = 1 //motor id, 0 or 1
byte4 = -100 //backward = -value (0 to 100)
