Topic: use arduino to help my daughter (Read 17587 times) previous topic - next topic
rwiens
Back to some of the previous suggestions (this is a very interesting thread, BTW), I think you would want to prototype something with a 3-axis accelerometer, collect data for both 'flat' and 'toe' walking and see if you can find some patterns.  Just trying to visualize it, I can imagine you will get acceleration (in a combination of axes) as the heel comes off the ground that you won't get (or to a lesser degree) if she is always on her toes.
Here is an Instructable for graphing acclerometer/gyro data in real time (uses Processing, a development environment not unlike the Arduino IDE...in fact the Arduino IDE was based on it), which would go a long way towards helping identify patterns (vs. just looking at raw data, which might be near impossible).
http://www.instructables.com/id/Guide-to-gyro-and-accelerometer-with-Arduino-inclu/
Grumpy_Mike
Can you kindly elaborate on the doubts you have on the tilt switch solution? Is it because of the switch's inconsistency for not making contact?
I think Paul__B summed it up correctly.
It would but as I said previously template matching is a difficult and inexact process especially on such a small processor with little memory as an Arduino.
rwiens
I guess I was thinking there might be a few very basic and obvious patterns that you could isolate and simply look for those.  For instance, if heel acceleration was purely in the Z axis, look for that (indicating a heel lift) and if it doesn't happen in the opposite direction within some time period (indicating the heel going back to the floor) then alarm.  I realize that is a gross oversimplification but you get the idea.
Having said that, I have very little experience with accelerometers so I would definitely defer to anyone with more.
odometer
If her walking on toes doesn't bother her, why does it bother you?
If it's only because her peers tease her for it, then by insisting that the way she walks is "wrong", you're really letting those peers make the rules.
When she gets to the age at which she goes out in the world, she can just wear high-heeled shoes. If she doesn't outgrow toe-walking first, that is.
manoktot
Not only teasing. It will also lead to bad posture and back problems if uncorrected.
manoktot
Rwiens - thank you for the link. I'll be looking into it. It's interesting how the author used the accelerometer and gyro functions to calculate degrees/angle.
radman
The objections from Grumpy_Mike and Paul__B to the tilt switch solution are based on the view that the signal from the switch may bounce around too much to give meaningful data.
I admit I am unsure how a tilt switch would perform in this application, but looking at the video I still feel it would work. Basically I think we are in a suck-it-and-see situation and a lot might depend on the actual switch selected.
How about this "change-over make before break" tilt switch?
http://docs-europe.electrocomponents.com/webdocs/107c/0900766b8107c8be.pdf
It might permit easy removal of a lot of spurious vibration contact breaks.
Mike you also mentioned "Force Sensors" do you have any specific devices in mind that might be suitable?
Does everyboy agree that;
  • Zero false positives are requred?
  • A high rate of false negatives, say 75%, is desirable?
Paul__B
Like walking in high heels.
radman
Mike, sorry I had not realised that you had already refreneced a force sensor.
This force sensor is very flat
https://www.sparkfun.com/products/9375
I would still put my money on either the sensors or the switches because I think there is a better chance of being able to make something small that might not need an Arduino.
manoktot
Anyhow, just wanted to inform that I've put in my 1st sparkfun order which consists of an Uno, resistor pack, protoshield with miniboard (so I can mount the whole uno board on the leg for testing)...and the tilt switch. I suppose I'll start it off simple, see how the tilt switch solution works, if not, place another sparkfun order for other sensors (force, flex, etc).... Wish me luck!
radman
That is always the way to go. If you have difficulties post your code and I am sure people will help out. If the film of your daughter is typical (i.e. not exaggerated for the camera) then I am fairly sure a tilt switch will do the job.  I cannot promise to keep up as I have a lot on at the moment but I have ordered a tilt switch myself to mess around with.
Although I have not taken to wearing high heels I have been walking around on tip-toe in different footware. Once I get to boots with ankle support and a steel insole it is not possible. Would a second prong of attack on the problem not be to get your daughter shoes/boots that have very firm soles? Then rather than having to remember not to walk on tip-toe she would have to make an effort to do it. In winter solid shoes/boots would not look out of place.
manoktot
I haven't seen school shoes for little girls that have those solid soles. Also, we live in a tropical country so winter shoes would most probably look out of place :) Thanks for also getting a switch, hopefully you can keep the thread updated with your findings on it too. Mine is due to arrive 2nd week of November, takes a while for online orders to get here.
PeterH
I'm struggling to see how a tilt switch would work on a moving foot - I think you might find it difficult to eliminate all the transients caused by movement of the foot. The pressure based approach would seem inherently much more reliable.
radman
The idea is that 25% of the time when the child walks on her toes she will do so for X seconds or more without generating any spurious transients. I am hoping that X will be 5-10s or more. If she does that she will get a reminder, probably a vibration, to stop the habit.
If transients occur during the other 75% of toe-walking incidents that is fine, no reminder will be given. You don't want to remind the child every time, you just want to give them a nudge now and again, otherwise they will just depend on the system and will not think for themselves.
Of course this theory may well crash and burn when tested.
The pressure based approach is a good one, but I think it would be harder to turn into something small and stand alone (i.e. no Arduino).
radman
Okay, made a bit of progress.
Despite the veils between the realms thinning I was unable to obtain a child on which to experiment  ]:D
As a result I had to conduct a test on myself. There were some strange looks, but no comments, as I padded around barefoot with a buzzing multimeter in my hand and a mercury switch stuck to my heel with a big blob of blu tack.
The results were reasonably encouraging. Unfortunately it was not possible to walk on tip toe without generating transients as I had hoped, however it seemed as if I could obtain two distinct and simple signatures.
For normal walking the multimeter buzzed more or less continuously (i.e. tilt switch contact made) with brief gaps when my foot impacted on the ground.
For walking on toes the inverse appeared to happen. The multimeter was silent more or less continuously (i.e. tilt switch contact broken) with brief buzzes when my foot impacted on the ground.
The mercury switch I managed to get hold of is sensitive in 2D so the 'ball' type switch I have ordered (currently out of stock) may in fact be better.
This was a very quick test and I am not sure how clean the two signatures are but I think it should be possible to tell them apart in software. The results for a child will be different. A child's smaller feet and shorter legs will move with a different rhythm and their lesser weight will result in less jarring on foot impact.
The system will be quite sensitive to getting the angle of the switch correct I think. More experimentation required.
