Topic: Confusion wrt using an Arduino+Bluetooth Module+Mac (Read 559 times) previous topic - next topic
Latency
I have an Arduino Uno and a Wireless Serial 4 Pin Bluetooth RF Transceiver Module(http://www.buildcircuit.net/product/bluetoothmodule). My goal is to pair the bt module to my Mac (running OS X) and send/receive data wirelessly using the Software Serial library (http://www.arduino.cc/en/Reference/SoftwareSerial).
I can pair the device to the Mac but it doesn't stay paired. Even when it is paired the SoftwareSerial sample doesn't work - I can send/receive data via the normal Serial methods but I never see data on the hardware serial interface.
And yes, I've wired up the BT module correctly and matched the pin definitions in my sketch:
Code: [Select]
const int rxpin = 2; // pin used to receive
const int txpin = 3; // pin used to send to
SoftwareSerial bluetooth( rxpin, txpin);
  Serial.begin( 9600);
  bluetooth.begin( 9600); // initialize the software serial port
  Serial.println(" Serial ready");
  // This is never displayed in the serial monitor window
  bluetooth.println(" Bluetooth ready");
I'd really appreciate any suggestions/advice!
Thanks,
LT
johnwasser
Did you try this experiment?  It uses the hardware serial so that eliminates some variables:
http://www.buildcircuit.com/simple-experiment-with-bluetooth-and-arduino/
Send Bitcoin tips to: 1G2qoGwMRXx8az71DVP1E81jShxtbSh5Hp
Latency
#2
Oct 18, 2013, 02:14 pm Last Edit: Oct 18, 2013, 06:15 pm by Latency Reason: 1
Thank you John!
I don't have an Android device - does anyone know of an iOS/Mac equivalent?
Again, until I understand why the bt module only stays paired (to my Mac) for about 10 seconds I'm not sure moving forward makes a ton of sense.
TIA!
-LT
