Loading...
Pages: [1]   Go Down
Author Topic: sensing the speed (noise)  (Read 338 times)
0
Offline Offline
Newbie
Arduino rocks
View Profile
Hi everybody,
i'm sensing the speed of a wheel (bike) with a Dynamo (DC motor) and then i send the data to the serial port, the problem that i have is that the Dynamo(DC motor) is sending a lot of noise and because of that i can't get the correct data of speed.
there is a way with hardware and software to supress that noise?
Logged
0
Offline Offline
Edison Member
Arduino rocks
View Profile
Quote
... is a way with hardware and software to supress that noise?
Yes, it is.
Best you start plotting the signal so we can have a look at the different situations, and explain how you tried to determine the velocity from that signal at the moment.
« Last Edit: August 30, 2010, 11:02:59 pm by mpeuser » Logged
0
Offline Offline
Tesla Member
Arduino rocks
View Profile
You might try some capacitors like below.
http://www.pololu.com/docs/0J15/9
Logged
Why I like my 2005 rio yellow Honda S2000 with the top down, and more!
GOOGLE ADVANCED FORUM SEARCH BELOW!
Go to:  http://www.google.com/advanced_search?hl=en
put in key search words,
use site or domain:  http://arduino.cc/forum
or in a google search box put key words site:http://arduino.cc/forum
0
Offline Offline
Edison Member
Arduino rocks
View Profile
But a dynamo should produce AC not DC...
Looks like another " Guess and fail" game  smiley-wink
« Last Edit: August 30, 2010, 11:22:14 pm by mpeuser » Logged
UK
Offline Offline
Faraday Member
Gorm deficient
View Profile
Quote
Maybe this is a language thing - in English, a dynamo is specifically a DC generator.
Logged
Per Arduino ad Astra
Lancashire, UK
Offline Offline
Edison Member
View Profile
WWW
Bicycle generators are commonly called dynamos (at least in blighty) despite them almost universally producing AC. Its a misnomer, just like central heating calorifiers are almost universally called 'boilers' despite them most definitely not being boilers.
Driving incandescent lamps it makes little difference if they are AC or DC.
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
Problem solved, thanks..
i was a little confuse of the voltage of the dynamo, and it was AC,, so i did a rectifier bridge and a filter, so now works perfectly
Logged
0
Offline Offline
Edison Member
Arduino rocks
View Profile
Quote
Most foreigners - I think - are not aware of this. In the German language the term Dynamo is nearly exclusively used for the thing at bicycles.
In a more technical slang Dynamo would actually describe an AC generator, in contrast to Gleichstrommaschine which is explicitely DC (=Gleichstrom). In English it is vice versa: 'dynamo' is DC and 'alternator' is AC...
The term 'generator' is - in both languages - used unspecifically.
« Last Edit: August 31, 2010, 03:09:58 pm by mpeuser » Logged
Pages: [1]   Go Up
Print
Jump to:
