Topic: EL Wire Sequencer - Vixen (Read 2410 times) previous topic - next topic
Face_nn
Hi Folks,
I try to run some EL wires with these EL Sequencer (https://www.sparkfun.com/products/11323). When I use the Generic Serial output plugin form Vixen, everything works fine. But I also wanted to run this with the Enttec Open DMX output of Vixen.
I use the DMX Sketch of Akiba (freaklabs), he shares his sketches on his homepage or on youtube.
#define DMX_NUM_CHANNELS 4
enum
  DMX_IDLE,
  DMX_BREAK,
  DMX_START,
  DMX_RUN
volatile unsigned char dmx_state;
int chan_cnt;
unsigned int dmx_start_addr = 1;
unsigned int dmx_addr;
unsigned char dmx_pin[DMX_NUM_CHANNELS] = {2, 4, 6, 8};
unsigned char dmx_data[DMX_NUM_CHANNELS];
volatile unsigned char update;
  update = 0;
  dmx_state = DMX_IDLE;
  for (int i=0; i<DMX_NUM_CHANNELS;i++)
    pinMode(dmx_pin[i], OUTPUT);
    digitalWrite(dmx_pin[i], LOW);
  UCSR0C =(1<<USBS0)|(3<<UCSZ00);
  Serial.begin(250000);
  if (update)
    update = 0;
    for (int i=0; i<DMX_NUM_CHANNELS; i++)
      if (dmx_data[i] != 0)
        digitalWrite(dmx_pin[i], HIGH);
Interrupt service handler for DMX
ISR(USART_RX_vect)
  unsigned char status = UCSR0A;
  unsigned char data = UDR0;
  switch (dmx_state)
    case DMX_IDLE:
      if (status & (1<<FE0))
        dmx_addr = 0;
        dmx_state = DMX_BREAK;
        update = 1;
    break;
    case DMX_BREAK:
    if (data == 0)
      dmx_state = DMX_START;
    break;
    case DMX_START:
      dmx_addr++;
      if(dmx_addr == dmx_start_addr)
        chan_cnt = 0;
        dmx_data[chan_cnt++] = data;
        dmx_state = DMX_RUN;
    break;
    case DMX_RUN:
      if (chan_cnt >= DMX_NUM_CHANNELS)
    break;
    default:
    break;
When I start a sequence in Vixen, the lights will turn on and off like the should do. But after a short time they get out of sync and it seems like the sequencer hung up. Is it possible that there is a problem with the memory, so that there is a shortage of memory after a little while or an memory overlfow?
Cheers
Face_nn
mrburnette
http://playground.arduino.cc/Code/AvailableMemory
Assuming you have available flash for the small routine, put it in your sketch and print the memory out to the console monitor... watch for a while... if there is no change in the free memory, remove the added code as there is no memory leak.
Ray
