Topic: Need Guidance : Arduino and Sleep modes - DIY watch design (Read 3387 times) previous topic - next topic
D4p0up
Oct 23, 2013, 12:57 am Last Edit: Oct 23, 2013, 01:00 am by D4p0up Reason: 1
Hello Guys,
I have been building a DIY Watch project for a while now and now have a brand new prototype to work with
HW details available here : http://www.banson.fr/wiki/doku.php?id=rawlx
This cute LED PCB-based watch is now waiting for its power saving SW to be able to run genuinely on a 3.7V 2450 cell battery.
I'm now struggling with the global SW architecture of the ATMEGA code to be able to run it as long as possible. I've been digging for a while inside the documentation and the tutorials for sleep/idle modes and i'm looking now for advices on the solution chosen.
Here is how I see it now :
By default unit sleeps. Time is stored internally inside a variable which is set at initial startup.
- TIMER1 is the only peripheral activated when sleeping, it counts endlessly.
- When TIMER1 overflow occurs, an ISR is trigged, ATMEGA wakes to update the Time variable according to the elapsed 65536 TIMER1 ticks, and system is put back to sleep, TIMER1 continuing its duty.
- When button is pressed, another ISR is triggered, waking up the ATMEGA. Time variable is updated according to TIMER1 accumulator cournter, and displayed using the leds for a bried amount of time.
Is this approach reasonable? Can I use the Arduino low power library, or do you advise to do it by hand by tweaking ATMEGA registers? I'm still more at ease with Arduino IDE so as far as possible, I'd like to stick to the Arduino world as much as i can.
I'm still not completely sure I can put the whole chip to sleep except the TIMER1 counter, and if everything can be waken up the way I want to do it.
Thanks in advance for your feedback/suggestions,
Vincent
note : I have chosen not to use a RTC for visual aspect reasons, and I'm ready to use low frequency crystal as ATMEGA clock to reduce power consumtion as well. I have a few 32khz and 2Mhz crystals to mess around with.
Blog, DIY Electronics & Stuff - http://www.banson.fr
nickgammon
Which sleep mode did you have in mind, and what is your target power consumption?
http://www.gammon.com.au/power
Please post technical questions on the forum, not by personal message. Thanks!
More info: http://www.gammon.com.au/electronics
D4p0up
Thank you nick for this very complete (and didactic) documentation. I would like to put the device into the lowest consmutpion mode still fitting my needs. I'm going to read in detail your findongs and come back to you.
nickgammon
Thanks!
This might help you too:
http://www.gammon.com.au/forum/?id=11504&reply=10#reply10
With one external crystal (if you can somehow fit that in) you can get the consumption to around 1 µA.
D4p0up
Awesome, is it also the case for Timer1? I could wake the chip every two seconds then.
nickgammon
According to the datasheet, it is Timer 2 that will wake from SLEEP_MODE_PWR_SAVE.
However you could increase the time, change:
Code: [Select]
  OCR2A =  31;              // count to 32 (zero-relative)
to:
Code: [Select]
  OCR2A =  63;              // count to 64 (zero-relative)
Paul__B
Unless you have a crystal running a counter all the time - you do not have a timepiece.
(And even then it has to be a good crystal.)
nickgammon
That reminds me of the day when I was at a "watch vendor" (aka jewellery shop) and I asked about how well the various watches kept time. The salesperson looked confused at the question.
Paul__B
Dare I ask this: ... Female?
nickgammon
I don't want to get into male/female stereotypes. :P
Let me put it this way: a lot of staff in jewellery shops are female.
D4p0up
Got through all of your post, made my Fuse setup and architecture, will be testing soon.
Last question, can I use the Arduino IDE to do it, using my Uno as ISP ? I need to configure the config files I guess, some more reading required.
Again, nick you totally nailed my needs with your post.
Massive Kudos,
Vince
nickgammon
I personally use my hex uploader:
http://www.gammon.com.au/forum/?id=11638
But the Arduino (Uno) as ISP should work, and saves you having to use SD cards.
D4p0up
Working  exactly as intended, many thanks. Here's a short video of current capabilities. Thanks again nick !
http://youtu.be/g2tXVPLfgjk
Vince
nickgammon
