Topic: Serial.begin messes up my 74HC595 Shifter (Read 484 times) previous topic - next topic
kampsu
I am doing a school project that involves lots of Outputs. I need to use one 7segment display so i decided to use shift register.  Register works fine until the point i type Serial.begin under my setup(){}.
The whole 7 segment goes crazy and random lights starts when booting program. Sometimes all segments are on.
As soon as i remove the Serial.begin line everything works. What to do? Shifter uses same serials that i try to use or what what is happening? I am using Arduino Uno. Thank you.
My main is like this:
Code: [Select]
#include "Display.h"
pinMode(0, OUTPUT); // ClockPin
pinMode(1, OUTPUT); // LatchPin
pinMode(2, OUTPUT); // DataPin
Ykkonen();
And my Display.h follows
Code: [Select]
#include "Arduino.h"
void Ykkonen()
  int ClockPin = 0;
  int LatchPin = 1;
  int DataPin = 2;
  digitalWrite(LatchPin, LOW);
  shiftOut(DataPin, ClockPin, LSBFIRST, B10001001);
  digitalWrite(LatchPin, HIGH);
CrossRoads
  int ClockPin = 0;
  int LatchPin = 1;
These are the Serial lines.  Use other pins.
