Topic: Line out to mic line (Read 1 time) previous topic - next topic
Terrier
hey i need some suggestions to solve a problem with my gsm-playground shield.
The shield has an onboard mic, but what i want is to play an audiofile from my computer.
So when you call the gsm-shield with your mobile phone you should hear music.
Can i get rid of the mic and connect an aux cable to the shield? Or use a digital to analog converter?
I also need a solution for the other way round. I want to record the shields audio output with an computer.
That is the shield that i'm talking about:
http://www.hwkitchen.com/products/gsm-gps-playground-shield-for-arduino/
Thx in advance for any solutions.
DVDdoug
A line-level signal is around 1V and a microphone signal is around 10-100mV (depending on the loudness and how close the line level is to the home audio or pro audio standards, etc.).  Headphone-level is also close to line-level, so you can connect a headphone output to a line-input.      (But, not the other way around...  The voltage is OK, but the  headphone impedance is too low for a line-output.)
So, you can use a voltage divider (2 resistors) to knock-down the signal to somwhere between 1/10th and 1/100th of it's original voltage.   You can experiment, or use a pot to make it adjustable.
But, that shield looks expensive!  I'd be cautious about hacking it up!   :smiley-eek:
Also, since it looks like you'll be transmitting mono you'll need to mix the left & right channels together.   Do NOT hard-wire the channels togther.   You should NEVER connect two outpus together.  (It's usually OK to connect two inputs together.)   Put a resistor (1K - 10K) in series with each output.  (Those resistors can be part of your voltage divider.)
And it's not a big deal in this case, but in-general, you'd like to avoid reducing line-level to mic-level  whenever possible.    All amplifiers add noise so there is added noise when you re-amplify the signal.
Terrier
thanks for your help. it worked quite good, but as you said it's a bit noisy. is there any way to reduce the noise?
