Topic: Calling php process from sketch (Read 1 time) previous topic - next topic
takissd
Hello all, i have a php file that i would like to run as a process from my sketch.
I have seen the process command with a lot of examples like :
void runCpuInfo() {
  Process p;
  p.begin("cat");
  p.addParameter("/proc/cpuinfo");
  p.run();
but i am not sure hot to run a php file from linux and if process is the right command to use from sketch cause something like this will not work:
void runphpfile() {
  Process p;
  p.begin("myfile.php");
  p.run();
even from command line i cannot run it. I know if i try to hit the php file from the browser it runs fine.
Any pointers? thanks
Erni
I have not tried with php, but with python this work:
p.runShellCommand("python /usr/bin/test.py 2>&1");
or this
  Process p;
  p.begin("python");
  p.addParameter("/usr/bin/test.py");
  p.run();
takissd
Thanks for the reply. I know the python way, i am still trying to figure the php way.
the part: p.begin("php5");   doesnt seem to work for me...
Any other thoughts?
federicofissore
I think the command line program for php is php5-cli not just php5. Take a look at http://playground.arduino.cc/Hardware/Yun#installing_php
Erni
Actually it is php-cli
When I type php-cli -v on the commandline I get this response:
PHP 5.4.17 (cli) (built: Sep 12 2013 18:54:21)
Copyright (c) 1997-2013 The PHP Group
Zend Engine v2.4.0, Copyright (c) 1998-2013 Zend Technologies
It also gives some warnings:
PHP Warning:  PHP Startup: Unable to load dynamic library '/usr/lib/php/pdo_sqlite.so' - Fil        e not found in Unknown on line 0
PHP Warning:  PHP Startup: Unable to load dynamic library '/usr/lib/php/sqlite.so' - File no        t found in Unknown on line 0
I will try to figure out what to do about these
Erni
Ok, the errors was due to a misconfigured php.ini file.
Now I am able to use it like this:
p.runShellCommand("php-cli /usr/bin/hello.php  2>&1");
takissd
Thank you , i will give it a try at home!
