Topic: ''COM4 already in use. Try quiting other program may be using it'' (Read 997 times) previous topic - next topic
Hassaan
Hello Everyone
When I upload the program, it took long first then it says ''COM4 already in use try quiting other program may be using it''. I checked in Device manager it says under Ports (COM & LPT) that COM4 is assigned to Arduino Mega 2560 (COM4). I reconfirmed it by checking in Arduino IDE in Tools menu which says ''Serial Port -> COM4''.
Thats very annoying.
If somebody know the solution kindly let me know.
Thanks for reading my problem.
Regards
Hassan
Paul__B
Don't know, but a "Standard Windows Corrective Manoeuvre" may help.
vwlowen
Worth a try is:
In Windows, navigate: Start -> Right-click on 'Computer' -> Select 'Properties'.  Then select Device manager.
Right-click on 'Universal Serial Bus Controllers' and select 'Scan for hardware changes'
Right-click on 'USB Virtualization' and select 'Scan for hardware changes'
Still in Device Manager, expand 'Mice and other pointing devices' and check for Microsoft Serial Ballpoint.  Sometimes Windows installs a driver for that when you plug in an unrecognized device and causes all sorts of problems.
John.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
