Topic: Make code more smaller (Read 977 times) previous topic - next topic
smallpoul
     is there a way to have less code to do this
boolean sensor1_status = false;
boolean sensor2_status = false;
boolean sensor3_status = false;
boolean sensor4_status = false;
boolean sensor5_status = false;
boolean sensor6_status = false;
boolean sensor7_status = false;
boolean sensor8_status = false;
boolean sensor9_status = false;
I want 9 variable with boolean value, is this the best way to declare it or there a better way with less coding and more speed.
Thanks in advance
Mike
michinyon
boolean sensor_status[9]
for ( int j=0 ; j<9 ; j++ ) sensor_status[j]=false ;
KeithRB
If these are globals that are being initialized in init(), than you can simply ignore it since globals are inited to all zeros (false) at program start.
smallpoul
Thanks, understand now. now here a section of my code
// arrays to hold device addresses
DeviceAddress sensor1, sensor2, sensor3, sensor4, sensor5, sensor6, sensor7, sensor8, sensor9;
 mySwitch.enableReceive(0);  // Receiver on inerrupt 0 => that is pin #2
 mySwitch.enableTransmit(4);
 mySwitch.setRepeatTransmit(2);
 sensors.begin();
 if (sensors.getAddress(sensor1, 0)) sensor1_status = true;
 if (sensors.getAddress(sensor2, 1)) sensor2_status = true;
 if (sensors.getAddress(sensor3, 2)) sensor3_status = true;
 if (sensors.getAddress(sensor4, 3)) sensor4_status = true;
 if (sensors.getAddress(sensor5, 4)) sensor5_status = true;
 if (sensors.getAddress(sensor6, 5)) sensor6_status = true;
 if (sensors.getAddress(sensor7, 6)) sensor7_status = true;
 if (sensors.getAddress(sensor8, 7)) sensor8_status = true;
 if (sensors.getAddress(sensor9, 8)) sensor9_status = true;
 // set the resolution to 9 bit
 sensors.setResolution(sensor1, TEMPERATURE_PRECISION);
 sensors.setResolution(sensor2, TEMPERATURE_PRECISION);
 sensors.setResolution(sensor3, TEMPERATURE_PRECISION);
 sensors.setResolution(sensor4, TEMPERATURE_PRECISION);
 sensors.setResolution(sensor5, TEMPERATURE_PRECISION);
 sensors.setResolution(sensor6, TEMPERATURE_PRECISION);
 sensors.setResolution(sensor7, TEMPERATURE_PRECISION);
 sensors.setResolution(sensor8, TEMPERATURE_PRECISION);
 sensors.setResolution(sensor9, TEMPERATURE_PRECISION);
 Serial.println("No RF");
I want to do that in the for loop so there's no need to put all this code. The problem is with the Device address, how could i identify sensor one array with the sensor_statut
AWOL
#4
Oct 24, 2013, 09:16 pm Last Edit: Oct 24, 2013, 09:25 pm by AWOL Reason: 1
The code is at odds with that statement.
If you find you're writing the same code over again with only name suffixes which change, you should almost certainly be using loops and arrays.
smallpoul
Yes i know but since DeviceAddress is declare in the 1-wire library, i could not access it like this
Serial.println(DeviceAddress[1]);
it say
error: expected primary-expression before '[' token
AWOL
That's because the object you tried to subscript is not declared as an array.
Tom Carpenter
Arrays are really very simple. If you want sensor_1, then that would be sensor[0] - (note the zero index).
DeviceAddress sensor[9];
boolean sensor_status[9] = {0};
for (byte i = 0; i < 9; i++){
 if (sensors.getAddress(sensor[i], i)){
   sensor_status[i] = true;
~Tom~
smallpoul
