Topic: (solved) problem reading data from rc receiver (Read 5590 times) previous topic - next topic
groundFungus
I cleaned it up a bit.  This should work.
Code: [Select]
const byte ch1 = 3;
const byte led = 13;
  pinMode(ch1, INPUT);
  pinMode(led, OUTPUT);
  int width = pulseIn(ch1, HIGH, 30000);
  Serial.print("Channel 1:  ");
  Serial.println(width);
  if(width > 1800) {
     digitalWrite(led, HIGH);
delay(100);
jeremybgilbert
#16
Oct 25, 2013, 03:27 am Last Edit: Oct 25, 2013, 03:31 am by jeremybgilbert Reason: 1
thank you!!!! but i did have to make a change. i changed it to pin 11 as the led output and it works! maybe something is wrong with pin 13 on my board here is the finished code i added a line to turn the led back off
Code: [Select]
const byte ch1 = 3;
const byte led = 11;
  if(width > 1990) {
     if(width < 1800) {
     digitalWrite(led, LOW);
groundFungus
Yeah, I realized that as soon as you said the led wasn't coming on.  Congrats.
jeremybgilbert
thank you so much for your help! you are awesome lol now im going to edit it to have three channels since i have three spare channels on my receiver.
