Topic: Re: Programming Help (Read 5244 times) previous topic - next topic
artixalpha
I need help i am using a max7219 board (Just serach it up on goolgle comes with 8x8 led ) but all the codes i tried need a varible and idk what do do. Can somone give me a code that has all varibles and tell me how to control the animations and where to put pins in from the board to the arduino (arduino uno) please help
artixalpha
What i mean is that i cant get my max7219 chip working with my arduino i can't program my arduino cuz i dont know how to plug in varibles:        #include <FrequencyTimer2.h>
#include "font.h"
#include "figuras.h"
byte col = 0;
byte leds[8][8];
// Pines conectados al Arduino (-1 es un fantasma para que empience en la posicion 1)
int pins[17]= {-1, 5, 4, 3, 2, 14, 15, 16, 17, 13, 12, 11, 10, 18, 8, 7, 6};
// Columnas de leds = Pines de la matriz
int cols[8] = {pins[13], pins[3], pins[4], pins[10], pins[06], pins[11], pins[15], pins[16]};
// Filas de leds = Pines de la matriz
int rows[8] = {pins[9], pins[14], pins[8], pins[12], pins[1], pins[7], pins[2], pins[5]};
const int numPatterns = 22;
byte patterns[numPatterns][8][8] = {
  D,A,V,G,E,E,K,PUNTO,C,O,M,SPACE,CARITA,SPACE,Bike,SPACE,Alto,SPACE,FlechaIzq,SPACE
int pattern = 0;
   // Todos los pines como salidas
   for (int i = 1; i <= 19; i++) {
     pinMode(pins, OUTPUT);
   // Pines en bajo
   for (int i = 1; i <= 8; i++) {
     digitalWrite(cols[i + 1], LOW);
     digitalWrite(rows[i + 1], LOW);
   clearLeds();
   // Turn off toggling of pin 11
   FrequencyTimer2::disable();
   // Set refresh rate (interrupt timeout period)
   FrequencyTimer2::setPeriod(2000);
   // Set interrupt routine to be called
   FrequencyTimer2::setOnOverflow(display);
   setPattern(pattern);
     pattern = ++pattern % numPatterns;
     slidePattern(pattern, 100);
void clearLeds() {
   // Limpiar Display
   for (int i = 0; i < 8; i++) {
     for (int j = 0; j < 8; j++) {
       leds[j] = 0;
void setPattern(int pattern) {
       leds[j] = patterns[pattern][j];
void slidePattern(int pattern, int del) {
   for (int l = 0; l < 8; l++) {
     for (int i = 0; i < 7; i++) {
         leds[j] = leds[j][i+1];
       leds[j][7] = patterns[pattern][j][0 + l];
     delay(del);
// Rutina de interrupciones
void display() {
   digitalWrite(cols[col], LOW);  // Turn whole previous column off
   col++;
   if (col == 8) {
     col = 0;
   for (int row = 0; row < 8; row++) {
     if (leds[col][7 - row] == 1) {
       digitalWrite(rows[row], LOW);  // Turn on this led
     else {
       digitalWrite(rows[row], HIGH); // Turn off this led
   digitalWrite(cols[col], HIGH); // Turn whole column on at once (for equal lighting times)
_8x8.ino:2:18: error: font.h: No such file or directory
_8x8.ino:3:21: error: figuras.h: No such file or directory
_8x8:19: error: 'D' was not declared in this scope
_8x8:19: error: 'A' was not declared in this scope
_8x8:19: error: 'V' was not declared in this scope
_8x8:19: error: 'G' was not declared in this scope
_8x8:19: error: 'E' was not declared in this scope
_8x8:19: error: 'K' was not declared in this scope
_8x8:19: error: 'PUNTO' was not declared in this scope
_8x8:19: error: 'C' was not declared in this scope
_8x8:19: error: 'O' was not declared in this scope
_8x8:19: error: 'M' was not declared in this scope
_8x8:19: error: 'SPACE' was not declared in this scope
_8x8:19: error: 'CARITA' was not declared in this scope
_8x8:19: error: 'Bike' was not declared in this scope
_8x8:19: error: 'Alto' was not declared in this scope
_8x8:19: error: 'FlechaIzq' was not declared in this scope
_8x8.ino: In function 'void setup()':
_8x8:42: error: 'FrequencyTimer2' has not been declared
_8x8:44: error: 'FrequencyTimer2' has not been declared
_8x8:46: error: 'FrequencyTimer2' has not been declared
artixalpha
#include "font.h"
byte col = 0;
byte leds[8][8];
int pattern = 0;
   // Pines en bajo
   clearLeds();
void clearLeds() {
   // Limpiar Display
       leds[j] = 0;
     delay(del);
void display() {
   col++;
   if (col == 8) {
     col = 0;
     else {
I need help with this as i can't declare varibles ( DOnt know how to ) and what pins should i plug data clk etc.
nickgammon
Please do not cross-post. This wastes time and resources as people attempt to answer your question on multiple threads.
Threads merged.
Please use code tags.
Read this before posting a programming question
How to use this forum
- Moderator
Please post technical questions on the forum, not by personal message. Thanks!
More info: http://www.gammon.com.au/electronics
artixalpha
Code: [Select]
Program code
Code: [Select]
#include "font.h"
byte col = 0;
byte leds[8][8];
int pattern = 0;
     pinMode(pins[i], OUTPUT);
   // Pines en bajo
   clearLeds();
void clearLeds() {
   // Limpiar Display
       leds[i][j] = 0;
       leds[i][j] = patterns[pattern][i][j];
         leds[j][i] = leds[j][i+1];
     delay(del);
void display() {
   col++;
   if (col == 8) {
     col = 0;
     else {
I cannot get this running cause of varible argument and i cant fix it help ;/
nickgammon
Fix this first:
Quote
Did you install the library properly?
artixalpha
I do not know also only the on light lights up on my arduino
PaulS
Quote
I do not know
When you do know whether you downloaded the library, come on back.
When you can remember where you installed the library, come on back.
Quote
Since you can't even compile the code for the Arduino, why do you expect other things to happen?
artixalpha
Ok got the library but arduino ran out of space used efprom clear but then this happend
Code: [Select]
* EEPROM Clear
* Sets all of the bytes of the EEPROM to 0.
* This example code is in the public domain.
#include <EEPROM.h>
  // write a 0 to all 512 bytes of the EEPROM
  for (int i = 0; i < 512; i++)
    EEPROM.write(i, 0);
  // turn the LED on when we're done
  digitalWrite(13, HIGH);
Code: [Select]
Binary sketch size: 790 bytes (of a 32,256 byte maximum)
avrdude: stk500_getsync(): not in sync: resp=0x00
nickgammon
Quote
Ok got the library ...
Good.
Quote
... but arduino ran out of space ...
What space?
Quote
... used efprom clear ...
Why?
Quote
... but then this happend ...
Are you able to upload any sketches at all to your Arduino?
artixalpha
Ran out of memory - Solved
Used efprom clear to erase memory
I cant reaaly find a sketch for 8x8 led(prefrably scrolling smiley face) And pretty much idk if it uploads to program or not
PaulS
Quote
Send me your Arduino, and I'll try to upload the blink example sketch.
artixalpha
The blink works it's just that i need to know the pins and where to plug them in on this program
Code: [Select]
#include "font.h"
byte col = 0;
byte leds[8][8];
int pattern = 0;
   // Pines en bajo
   clearLeds();
void clearLeds() {
   // Limpiar Display
       leds[i][j] = 0;
     delay(del);
void display() {
   col++;
   if (col == 8) {
     col = 0;
     else {
If ant of you guys can please declare the varibles for me and tell me where to plug in the DIN,CS and clk
nickgammon
A good starting point would be to stop sending private messages to people who are trying to help you, asking for even more help.
artixalpha
