Topic: How to get around the Delay function (Read 3423 times) previous topic - next topic
JonahStarling
Oct 29, 2013, 04:13 am Last Edit: Oct 29, 2013, 04:20 am by JonahStarling Reason: 1
Okay so I am making a random joke teller using a button and an lcd screen. What happens is it says do you want to hear a joke and when you press a button it tells you a random joke. The original code looked like this and worked fine.
Code: [Select]
const int TxPin = 6;
const int button = 5;
int buttonState = 0;
long randNumber;
unsigned long Timer;
#include <SoftwareSerial.h>
SoftwareSerial mySerial = SoftwareSerial(255, TxPin);
 pinMode(button, INPUT);
 pinMode(TxPin, OUTPUT);
 digitalWrite(TxPin, HIGH);
 mySerial.begin(9600);
 delay(100);
 mySerial.write(12);                 // Clear
 mySerial.write(17);                 // Turn backlight on
 delay(5);                           // Required delay
 mySerial.print("Want to hear");  // First line
 mySerial.write(13);                 // Form feed
 mySerial.print("a joke?");   // Second line
 randomSeed(analogRead(0));
 buttonState = digitalRead(button);
 if(buttonState == HIGH) {
   randNumber = random(9); //prints a random number from 0 to 9
   Serial.println(randNumber);
   if(randNumber == 0) {
     mySerial.write(12);
     delay(5);
     mySerial.print("Joke #1");
   if(randNumber == 1) {
     mySerial.write(12);
     delay(5);
     mySerial.print("Joke #2");
   if(randNumber == 2) {
     mySerial.write(12);
     delay(5);
     mySerial.print("Joke #3");
   if(randNumber == 3) {
     mySerial.write(12);
     delay(5);
     mySerial.print("Joke #4");
   if(randNumber == 4) {
     mySerial.write(12);
     delay(5);
     mySerial.print("Joke #5");
   if(randNumber == 5) {
     mySerial.write(12);
     delay(5);
     mySerial.print("Joke #6");
   if(randNumber == 6) {
     mySerial.write(12);
     delay(5);
     mySerial.print("Joke #7");
   if(randNumber == 7) {
     mySerial.write(12);
     delay(5);
     mySerial.print("Joke #8");
   if(randNumber == 8) {
     mySerial.write(12);
     delay(5);
     mySerial.print("Joke #9");
   if(randNumber == 9) {
     mySerial.write(12);
     delay(5);
     mySerial.print("Joke #10");
I went back and added an actual joke to the first one and encountered a problem of it wanting to say that joke over and over again. Kinda like when someone thinks their joke is funny and won't stop saying it. I believe the problem lies within the delay( function. Here is what it looked like with the joke.
Code: [Select]
     mySerial.write(12);
     delay(5);
     mySerial.print("What does a");
     mySerial.write(13);
     mySerial.print("nosey pepper do?");
     delay(3000);
     mySerial.write(12);
     delay(5);
     mySerial.print("Get jalapeno");
     mySerial.write(13);
     mySerial.print("business");
I believe the problem is with the delay(3000);
I know this may be an easy fix to most people but I am still learning. If you could please help me figure out the problem and help me with the code that would be great!
Thanks,
Jonah
lar3ry
No, it's because it's the only joke in there.
It prints either "Joke #..." or the joke you put in.
If you insert the following lines right after the random number statement, you'll see what's going on.
Code: [Select]
    Serial.println("");                                       // insert this line
    Serial.print("Random Number: ");      // and this one too
nickgammon
Could you post your whole sketch with the joke in it? And the whole output you get on the serial monitor?
Please post technical questions on the forum, not by personal message. Thanks!
More info: http://www.gammon.com.au/electronics
JonahStarling
This is the code with the joke in it. It only wants to say that joke. But, if I take it out it will say all of the other ones.
Code: [Select]
long randNumber;
  delay(100);
      mySerial.write(12);
      delay(5);
      mySerial.write(13);
      delay(3000);
      mySerial.write(12);
      delay(5);
      mySerial.write(13);
      mySerial.write(12);
      delay(5);
      mySerial.write(12);
      delay(5);
      mySerial.write(12);
      delay(5);
      mySerial.write(12);
      delay(5);
      mySerial.write(12);
      delay(5);
      mySerial.write(12);
      delay(5);
      mySerial.write(12);
      delay(5);
      mySerial.write(12);
      delay(5);
      mySerial.write(12);
      delay(5);
PaulS
Code: [Select]
And, this shows?
lar3ry
Did you try inserting the lines I showed you? It is working just fine. It selects a joke and prints it. The problem is that all the jokes except the one about the pepper, just say "Joke# 5" or Joke #7", and so on. The other number you see  is the random number. The reason I asked you to put in those lines is that it splits out the "Joke #.." from the random number, and identifies it with the string "Random Number: ", so that you can SEE what is happening.
The other problem you have it that the switch may be bouncing, causing you to generate multiple jokes, most of which are NOT the joke about the pepper.
Try it. Really. How much bother can it be to insert a few lines, compile, upload and try it?
Oh, and the reason you are not seeing the other entries is because you are constantly clearing the display.
It you change all your outputs to Serial.print() or Serial.println(), you'll see all the output.
lar3ry
Oh, what the heck... try this code. It will show you what's happening.
Code: [Select]
long randNumber;
//#include <SoftwareSerial.h>
//SoftwareSerial Serial = SoftwareSerial(255, TxPin);
[quote]
  Serial.begin(19200);
  delay(100);
  Serial.println("a joke?");   // Second line
  if(buttonState == LOW) {
    Serial.println("");
      Serial.write(12);
      delay(5);
      Serial.write(13);
      delay(3000);
      Serial.write(12);
      delay(5);
      Serial.write(13);
      Serial.write(12);
      delay(5);
      Serial.write(12);
      delay(5);
      Serial.write(12);
      delay(5);
      Serial.write(12);
      delay(5);
      Serial.write(12);
      delay(5);
      Serial.write(12);
      delay(5);
      Serial.write(12);
      delay(5);
      Serial.write(12);
      delay(5);
      Serial.write(12);
      delay(5);
JonahStarling
I'll make sure to try all of the suggestions out when I get home and i will post my results.
michinyon
Some random number functions don't work the way you would expect.   You might actually be getting the same random number, every time.
lar3ry
He's not. The random function is working just fine.
nickgammon
It seems to work as expected for me:
Code: [Select]
Want to hear
a joke?6
Joke #76
Joke #78
Joke #94
Joke #54
Joke #54
Joke #58
Joke #93
Joke #43
Joke #40
What does a
nosey pepper do? Get jalapeno
business5
Joke #66
Joke #71
Joke #27
Joke #86
Joke #72
Joke #31
Joke #23
Joke #42
Joke #36
Joke #70
What does a
business3
Joke #41
Joke #28
Joke #91
Joke #20
What does a
business8
Joke #92
Joke #34
Joke #56
Joke #71
Joke #25
Joke #64
Joke #55
Joke #67
Joke #81
Joke #27
Joke #82
Joke #37
Joke #83
Joke #44
Joke #55
Joke #66
Joke #76
Joke #76
Joke #71
Joke #25
Joke #63
Joke #45
Joke #67
Joke #83
Joke #45
Joke #68
Joke #92
Joke #33
Joke #47
Joke #88
Joke #94
Joke #55
Joke #60
What does a
business4
Joke #56
Joke #74
Joke #57
Joke #83
Joke #41
Joke #28
Joke #98
Joke #97
Joke #83
Joke #48
Joke #92
Joke #31
Joke #20
What does a
business8
Joke #95
Joke #64
Joke #57
Joke #86
Joke #72
Joke #32
Joke #30
What does a
business3
Joke #43
Joke #47
Joke #86
Joke #74
Joke #52
Joke #34
Joke #54
Joke #54
Joke #54
Joke #53
Joke #43
Joke #41
Joke #27
Joke #88
Joke #96
Joke #71
Joke #21
Joke #25
Joke #66
Joke #72
Joke #32
Joke #33
Joke #43
Joke #41
Joke #25
Joke #66
Joke #73
Joke #47
Joke #82
Joke #31
Joke #23
Joke #45
Joke #68
Joke #94
Joke #50
What does a
business7
Joke #84
Joke #58
Joke #92
Joke #38
Joke #97
Joke #84
Joke #56
Joke #75
Joke #67
Joke #84
Joke #55
Joke #62
Joke #30
What does a
nosey pepper do?
What is wrong with that?
michinyon
Quote
It's not funny ?
But the program seems to be working.
nickgammon
JonahStarling
So I am still having a very hard time getting it to work. I tried your suggestions and either I did them wrong or they are just not working. Any more suggestions? I am 90% sure that the problem is with the delay function because when I changed this:
Code: [Select]
      mySerial.write(12);
      delay(5);
      mySerial.write(13);
      delay(3000);
      mySerial.write(12);
      delay(5);
      mySerial.write(13);
to this:
Code: [Select]
      mySerial.write(12);
      delay(5);
      mySerial.write(13);
      //delay(3000);
      mySerial.write(12);
      delay(5);
      mySerial.write(13);
it worked. But consequently it only says get jalapeño business. Which is less funny than the actual joke. I looked into the millis( function but don't know how to implement it in my code.
enanthate
That makes absolutely no sense, to me anyway. But then again, I dont know mySerial.write and stuff, I only know Serial.println.
How about adding a delay(1000) at the very end of your loop, and see if this joke gets printed every second? I'm thinking the random-function is working, but that #joke 2, 3, 4 etc is just not showing. Try with the delay(1000), if your joke just appears randomly at every 1-10 seconds, there is something going on with your mySerial.write-stuff (why not use Serial.println anyway?).
Just a thought.
