Topic: How to get around the Delay function (Read 3705 times) previous topic - next topic
lar3ry
Quote
What is wrong with that?
It's not funny ?
But the program seems to be working.
Sure it's funny. I'm a bit of a language junkie (human languages as well as programming ones), so I may be more attuned to slang and/or accents, but it reads like...
"What does a nosy pepper do?"
"It gets all-up-in-yo business."
lar3ry
How about adding a delay(1000) at the very end of your loop, and see if this joke gets printed every second? I'm thinking the random-function is working, but that #joke 2, 3, 4 etc is just not showing. Try with the delay(1000), if your joke just appears randomly at every 1-10 seconds, there is something going on with your mySerial.write-stuff (why not use Serial.println anyway?).
Did you try my variation on the code? All that's done to change the OP's code is to change the output to Serial instead of SoftwareSerial, and to change a few Serial.print() to Serial.println(), and do get rid of the clear(), in order to show what's actually happening in the code.
Result; It DOES output all the jokes, randomly, except that the only joke in there is the jalapeno one. The rest all just say "Joke #...", which is exactly what the code says to do.
JonahStarling
Quote
Believe it or not that was the answer to my problem. The only thing is I changed it from delay(1000) to delay(100) that way you don't have to hold down the button. With the delay(100) at the very end of the loop it allows you to just press, but if you hold down the button it runs through all of the jokes until it reaches the joke with the delay. This problem will be solved when I put in all of the jokes because they will have a delay function and in turn stop it from running through all of the jokes.
Thanks everybody for the help. I will post the final result when it is finished. Hopefully I won't encounter any more problems.
enanthate
JonahStarling
Finally finished the code with all ten jokes. It plays every joke and works great.
Code: [Select]
const int TxPin = 6;
const int button = 5;
int buttonState = 0;
long randNumber;
unsigned long Timer;
#include <SoftwareSerial.h>
SoftwareSerial mySerial = SoftwareSerial(255, TxPin);
  pinMode(button, INPUT);
  pinMode(TxPin, OUTPUT);
  digitalWrite(TxPin, HIGH);
  mySerial.begin(9600);
  delay(100);
  mySerial.write(12);                 // Clear
  mySerial.write(17);                 // Turn backlight on
  delay(5);                           // Required delay
  mySerial.print("Want to hear");  // First line
  mySerial.write(13);                 // Form feed
  mySerial.print("a joke?");   // Second line
  randomSeed(analogRead(0));
  buttonState = digitalRead(button);
  if(buttonState == HIGH) {
    randNumber = random(10);   //prints a random number from 0 to 9
    Serial.println(randNumber);
    if(randNumber == 0) {
      mySerial.write(12);
      delay(5);
      mySerial.print("What does a");
      mySerial.write(13);
      mySerial.print("nosey pepper do?");
      delay(3000);
      mySerial.write(12);
      delay(5);
      mySerial.print("Get jalapeno");
      mySerial.write(13);
      mySerial.print("business.");
    if(randNumber == 1) {
      mySerial.write(12);
      delay(5);
      mySerial.print("The dyslexic");
      mySerial.write(13);
      mySerial.print("devil worshipper");
      delay(2000);
      mySerial.write(12);
      delay(5);
      mySerial.print("sold his soul");
      mySerial.write(13);
      mySerial.print("to Santa.");
    if(randNumber == 2) {
      mySerial.write(12);
      delay(5);
      mySerial.print("Blind man walks");
      mySerial.write(13);
      mySerial.print("into a bar.");
      delay(2000);
      mySerial.write(12);
      delay(5);
      mySerial.print("And a table.");
      delay(2000);
      mySerial.write(12);
      delay(5);
      mySerial.print("And a chair.");
    if(randNumber == 3) {
      mySerial.write(12);
      delay(5);
      mySerial.print("Why don't you");
      mySerial.write(13);
      mySerial.print("ever see");
      delay(2000);
      mySerial.write(12);
      delay(5);
      mySerial.print("hippopotamuses");
      mySerial.write(13);
      mySerial.print("hiding in trees?");
      delay(2000);
      mySerial.write(12);
      delay(5);
      mySerial.print("Because they're");
      mySerial.write(13);
      mySerial.print("good at it.");
    if(randNumber == 4) {
      mySerial.write(12);
      delay(5);
      mySerial.print("What's grey and");
      mySerial.write(13);
      mySerial.print("can't climb?");
      delay(2000);
      mySerial.write(12);
      delay(5);
      mySerial.print("A castle.");
    if(randNumber == 5) {
      mySerial.write(12);
      delay(5);
      mySerial.print("How does NASA");
      mySerial.write(13);
      mySerial.print("organize their");
      delay(2000);
      mySerial.write(12);
      delay(5);
      mySerial.print("company parties?");
      delay(2000);
      mySerial.write(12);
      delay(5);
      mySerial.print("They planet.");
    if(randNumber == 6) {
      mySerial.write(12);
      delay(5);
      mySerial.print("Why can't you");
      mySerial.write(13);
      mySerial.print("hear a");
      delay(2000);
      mySerial.write(12);
      delay(5);
      mySerial.print("pterodactyl go");
      mySerial.write(13);
      mySerial.print("to the bathroom?");
      delay(2000);
      mySerial.write(12);
      delay(5);
      mySerial.print("Because the P");
      mySerial.write(13);
      mySerial.print("is silent.");
    if(randNumber == 7) {
      mySerial.write(12);
      delay(5);
      mySerial.print("What kind of");
      mySerial.write(13);
      mySerial.print("shoes do");
      delay(2000);
      mySerial.write(12);
      delay(5);
      mySerial.print("ninjas wear?");
      delay(2000);
      mySerial.write(12);
      delay(5);
      mySerial.print("Sneakers.");
    if(randNumber == 8) {
      mySerial.write(12);
      delay(5);
      mySerial.print("Why does Snoop");
      mySerial.write(13);
      mySerial.print("Lion carry");
      delay(2000);
      mySerial.write(12);
      delay(5);
      mySerial.print("an umbrella?");
      delay(2000);
      mySerial.write(12);
      delay(5);
      mySerial.print("Fo' drizzle.");
    if(randNumber == 9) {
      mySerial.write(12);
      delay(5);
      mySerial.print("Why was six");
      mySerial.write(13);
      mySerial.print("afraid of seven?");
      delay(2000);
      mySerial.write(12);
      delay(5);
      mySerial.print("Because seven");
      mySerial.write(13);
      mySerial.print("was a well known");
      delay(2000);
      mySerial.write(12);
      delay(5);
      mySerial.print("six offender.");
  delay(100);
One thing I would like to fix but I don't know how to do yet is make it where it won't same the joke twice in a row.
Also I changed the random number code to 10 so it would include all ten jokes. It works by choosing a number 0-9 which is ten numbers. Notice the change below:
Code: [Select]
//Original code
    randNumber = random(9);   //prints a random number from 0 to 8
//I changed it to this to include all 10 jokes.
nickgammon
If the problem is with responding to the button, read:
http://www.gammon.com.au/switches
Please post technical questions on the forum, not by personal message. Thanks!
More info: http://www.gammon.com.au/electronics
lar3ry
Quote
Code: [Select]
long randNumber;
long lastRand = 100;    /Guarantee lastRand will not be chosen with random()
// Then,  to choose a random number
     while (1 ) {
     if (randNumber != lastRand) break;
      lastRand = randNumber;
nickgammon
You can also use a shuffle algorithm. Say you have 20 jokes, you generate the numbers 1 to 20, then shuffle them (like a deck of cards) then pull one out at a time. That way you don't get repeats until all 20 are used up. Then you shuffle them again.
http://en.wikipedia.org/wiki/Fisher%E2%80%93Yates_shuffle
