Topic: RC Car pins. (Read 3998 times) previous topic - next topic
giotmucdden
i have Radio Shack Hummer RC Car. i wanna control the car over wifi by using wishield + arduino uno. i look around to find out which pin control  forward; backward; stop; left; right. can anyone help me. i found schematic and i took some pics of the board.
thanks a lot.
[img]http://img820.imageshack.us/img820/1203/img0436oe.jpg/img]
schematic:
http://thesciencedude.com/projects/SeniorDesign/TeamStorage/DataSheets/Vehicle/ServiceManual.pdf
CrossRoads
There's no schematic, only a block diagram and a block diagram of the chip.
Not enough to go on.
cr0sh
Unfortunately, that manual seems incomplete; it lists 24 pages (and page 24 with the schematics), but only shows some of the pages - not all (???). Anyhow, the page with the schematics is not there.
That said - there are some interesting things - most notably, that the IC on the PCB (SC-8802) is some kind of microcontroller of some kind (and called the "88RCR1 SAMRI CPU" on one diagram) - not that it matters; I couldn't dig up a datasheet on that particular device. It might be something custom made for Radio Shack, or a house-numbered device, or something.
In this case, though, it is programmed to act - most likely - similar to the RX2/TX2 (and variants) chipset, which is a common radio-control chipset on low-cost radio control toys (most by New Bright toys - but I have seen it on other manufacturer's products). Basically, it takes a signal (likely thru one of the ADC pins) from the tuned radio-receiver, and turns it into outputs to control the motor(s) on the car.
The signal is likely generated by a similar chip in the transmitter - or it may be generated in some other manner.
If it were me (and I had the transmitter), I would first try to reverse engineer the schematic a bit on the receiver, then hang an o-scope (or even a multi-meter set to voltage measurement) off the ADC pins (11-19), and note what they did when I pushed the controls on the transmitter; likely one will change. Others might be set as outputs for the motors; or pins 2-10 might be used instead (???). This would all be a tricky project to reverse engineer, but not impossible. But you'd want to be really careful and understand what you are doing as you are doing it; one slip-up and POOF goes the chip (and possibly other items).
Another way would be (keeping the block diagram in mind - which seems to show some kind of servo-mechanism for the steering motor?) - reverse trace the motor leads back through to the h-bridges involved. Steering is likely (from what I can see) being done via a discrete MOSFET or bipolar transistor h-bridge (relatively low current) - with some kind of discrete feedback driver for the on-board servo system (that would be a fun one to trace).
Now - the h-bridge for the motor that drives the wheels looks like it is using this relay:
http://www.ficrelay.com.hk/details/FRM3W.pdf
It is noted it is an "FRM3W-2A10" relay (5V coil, 10A contacts, 2PDT - aka DPDT) - interesting - so it is using this to control forward and reverse (so look for the diode across the coil, and from there back to the transistor/mosfet driving it to switch it) - but for speed control, I notice a large transistor or mosfet bolted to a heatsink just behind it - but I can't read the model. Most likely, though, this is an NPN or N-channel device, pulling the low-side of the relay h-bridge to ground (the classic implementation of a hybrid relay/mosfet h-bridge - take note, people - this is how you do a fairly high-current, PWM-capable h-bridge easily and cheaply - though it does have drawbacks). Find the base or gate of that device, and the current limiting resistor, and that's your speed control.
This is going to take a ton of patience to reverse engineer - if you had the transmitter, then you could (in effect) have your arduino send the same pulses to whatever it's input is (bypassing the radio receiver portion), and let the CPU do it's thing (without having to chop too much of the circuit out).
Otherwise, you would need to find all the connections to the various driver components, as outlined above, then chop away everything else (ie - by "chop" I mean cutting traces, to leave you with the driver circuitry only). It would be a delicate and painstaking operation, to be sure - one rife with potential complications.
Beyond that - cut the wires to the motors, and build your control system - keeping in mind the currents and voltages needed by the motors, of course.
Lastly - I always post a link back to this R/C car hacking "mega-thread" - though most of it will not apply to you, you may find it helpful in other ways:
http://forum.arduino.cc/index.php/topic,86883.0.html
Good luck!
I will not respond to Arduino help PM's from random forum users; if you have such a question, start a new topic thread.
giotmucdden
Thanks @ Cr0sh and CrossRoads. i don't have transmitter for this car.  i played couple days with this board. I followed circus to find out which pins control motor, servo and receive signal from RF. I see pin 1,2 go to Diot to couple mosfets to big mosfet with heatsink. my servo has 6 wires.Green is GND. Blue and Yellow is left or right controlled by pin 13, 14. Red, Orange, and Brown seem like serve break. when server spin to left or right , brown and red or brown and orange are connected.
can i connect pin 1,2,13,14 as forward; backward; left; right to arduino board? if not, can you advice me some things can run mortor? and use servo that comes with arduino kits.
RS-550 Motor - 12V
Motor Specifications
Performance
Operating v   : 6v - 14.4v
Nominal v   : 12v
No Load RPM   : 19300
No Load A   : 1.2A
Stall Torque   : 70.55 oz-in   498.2 mN-m
Stall Current   : 85A
Kt   : 0.83 oz-in/A   5.9 mN-m/A
Kv   : 1608 rpm/V
Efficiency   : 70%
RPM - Peak Eff   : 17250
Current - Peak Eff   : 10A
Physical
Weight   : 7.7 oz   (218g)
Length - for motor   : 2.24 in   (57mm)
Diameter (with flux ring)   : 1.52 in   (38.5mm)
Diameter (no flux ring)   : 1.41 in   (35.8mm)
ShaftDiameter   : 0.12 in   (3.2mm)
Shaft Length   : 0.3 in   (7.6mm)
Mounting Screws (2)      M3
cr0sh
What I would do then is this: Find the closest solder point away from each pin, and solder a wire to it (label everything, too); then between that solder point and the pin on the IC, use an x-acto knife or something to cut the trace - so that the IC pin is no longer connected to the rest of the circuit.
Then, hook the wire to a digital output pin on the Arduino in series with a resistor - start with about 1 K, then gradually work your way down (no lower than 330 ohm); remember to hook the ground wire to the Arduino's ground. At some value you should get a response from those pins.
Now - that relay is, like I said, likely for direction control - so one of those pins (pin 1 or pin 2) will control that relay, and the big MOSFET is likely controlled by the other pin - for now, you can just switch it on or off, but later, when you find which pin controls which part, you will want to use a PWM pin to control the MOSFET (while the relay control can happen with any digital pin).
Be sure to switch the relay direction ONLY when the PWM pin is LOW (0% PWM) - otherwise magic smoke might get let out.
Again - do the same as above (any digital pin, with the resistor) to those pins (and cutting the trace as noted).
Find which pins these are connected to; or connect brown to ground, and red and orange to digital input pins and activate the internal pull-up resistor on those pins. Then - you can use those pins so that when you see a LOW level in your code, you know the limit has been reached by the motor, and can shut it off to prevent the motor from stripping its gears, or burning the motor out, etc.
I don't know what kit you have, or what the servo is - but if it is a standard sized servo, you could use it in place of the (apparently?) non-servo steering mechanism (what you describe sounds like a "bang-bang" steering system - common in these cheap R/C toys); with a servo you could get more proportional control over the steering, potentially. It would, however, take some mechanical know-how and modding to fit the servo in (providing, again, that the servo is large enough to act as a steering servo).
Or - you could mount a distance sensor of some sort (some kind of Sharp IR or an ultrasonic distance sensor), and "pan" it with the servo to get a 2D representation of what is in front and to the sides of the car.
RS-550 Motor - 12V
Performance
Nominal v   : 12v
No Load RPM   : 19300
No Load A   : 1.2A
Stall Current   : 85A
Kv   : 1608 rpm/V
Efficiency   : 70%
Physical
If that's really the motor in the car, they really undersized the relay for it's stall current (then again, where are you going to find a 75A small PCB mounted relay, anyhow?). The MOSFET might be sized OK for it, though (I can only guess, because there isn't a known number for the MOSFET).
You'll want to find and use the proper battery for the RC car to power the PCB and motors; ideally, you only want to provide power to the motors and support circuitry - not to the rest of the PCB (because you aren't using those parts - and thus it only wastes energy to power them); but for the time being, just getting it to work will be enough (cutting away the traces to isolate the driver parts can be very difficult, but not impossible to do).
Also note that it is very easy to blow the drivers on the board - even with the precautions I gave above using a resistor and such, because you don't know what the output voltage from the pins of the CPU on that PCB actually were (vs the 5V TTL digital voltages from the Arduino); if you wanted to be really careful, you could probe around first using a voltage divider to drop the voltage from the control pin on the Arduino to 3.3V before plugging it in; if it works, leave it.
Again - this is all experimental - you very well could blow the driver, the Arduino, or both. Good luck!
