Topic: [FIXED] 3.2" touchscreen strange behaviour, sometimes works, sometimes doesn't (Read 3685 times) previous topic - next topic
Timtomm
Dear Builders,
Recently I've got my SainSmart 2560 Rev 3 board + LCD shield + 3.2" LCD Touch panel from SainSmart. It was a hard work to get it into work properly, and I've reached a good milestone. At this point, I'm a bit frustrated. In short:
-- pinout is good,
-- LCD works good with other (not touch) examples,
-- all libraries are up to date and included (UTFT, UTouch, as well as calibration).
As soon as I plug in the USB cable, and upload a sketch (for example, QuickDraw, as seen on the YouTube vid below), everything is working fine. After I unplug the cable and start use the board with externap power source (or by the same USB cable as I've used to upload the sketch), touch starts to work improperly (see video). 8 out of 10 attempts are bringing into this situation. I found out, that resetting the board may help this (7 out of 10 attempts are going to bring good results). If I upload the sketch again, it's always working fine (10 out of 10 attempts).
Every sketchs are exactly the same as provided in UTouch.rar from http://www.henningkarlsen.com/electronics/ .
See YouTube video:
http://www.youtube.com/watch?v=D40PpzNX5Nc.
How can I fix this problem?
Thanks for all the replies.
Best wishes,
Tamas
eclipsegst
maybe you can solve this with adding some delay to HW_AVR.inc
word UTouch::touch_ReadData()
   word data = 0;
   for(byte count=0; count<12; count++)
      data <<= 1;
      sbi(P_CLK, B_CLK);
      cbi(P_CLK, B_CLK);
               delayMicroseconds(1); //// added to get more stable readings?
      if (rbi(P_DOUT, B_DOUT))
         data++;
   return(data);
Timtomm
Thank you very much for the fast help. I was a chellenging task to find the right file and the right place, but it fixed the issue.
Have a nice day,
Tom
antonius1
Thank you very much. I had the same problem, and this fixed my problems.
antonius
tfuglsang
Thank you!!
I have used the last 3 days trying to solve this problem, but this solution seems solid!
We need to spread this to the forums, we are not the only one who have this issue, and it seems like the support at Sainsmart.com are completely mute on this.
Again, thank you!
cbonsell
en_tarak
hi dear eclipsegst,
my 3.2" UTFT touch sometimes work, sometimes it doesnt work. as u told in your previoue post "adding some delay to HW_AVR.inc".. i couldnt follow this point. can u plz elaborate ho to add this section of code and at what location / where to save.
thanks
ghlawrence2000
thanks
Arduino\Libraries\UTouch\hardware\avr\HW_AVR.inc should look like this :-
Code: [Select]
void UTouch::touch_WriteData(byte data)
byte temp;
temp=data;
cbi(P_CLK, B_CLK);
for(byte count=0; count<8; count++)
if(temp & 0x80)
sbi(P_DIN, B_DIN);
cbi(P_DIN, B_DIN);
temp = temp << 1;
cbi(P_CLK, B_CLK);
sbi(P_CLK, B_CLK);
word data = 0;
data <<= 1;
sbi(P_CLK, B_CLK);
cbi(P_CLK, B_CLK);
data++;
return(data);
Regards,
Graham
UTFT_SdRaw now included in library manager!! ;) High speed image drawing from SD card to UTFT displays for Mega & DUE.
UTFT_GHL - a VASTLY upgraded version of UTFT_CTE. Coming soon to a TFT near you! 8) Shipping April 1 2016!
QB_Doctor
+1 for this fix - had my Sainsmart touch screen kit for 18 months only got it to work after modding HW_AVT.inc
Cheers
Simon
ghlawrence2000
Cheers
Simon
It is not enough to type '+1', you actually need to click [add] at the side of Karma! :P
But thanks for the thought.
Regards,
Graham
QB_Doctor
Regards,
Graham
thank you for helping me with that - having no doubt noticed my post count you must have realised that I needed tuoring in the ways of righteousness  ;)
Cheers
Simon
ghlawrence2000
