« on: September 10, 2010, 02:53:39 pm » |
Hello fantastic people.. does anyone know if i caninterface Arduio with 1 or 3 of these? http://uk.farnell.com/jsp/search/productdetail.jsp?SKU=1216698 THANKS!!! ;D ;D ;D ;D ;D ;D ;D ;D ;D
« Last Edit: September 11, 2010, 09:07:25 am by vahakn »
« Reply #1 on: September 10, 2010, 03:17:54 pm » |
Doesn't look to like it would be a problem. Nice to see a short datasheet for a change!
« Reply #2 on: September 10, 2010, 04:23:17 pm » |
any tips? do you know how?
thanks
UK
« Reply #3 on: September 10, 2010, 04:31:29 pm » |
The datasheet shows the interface protocol. It's 8 bit serial, clocked, LSB first.
Don't try powering from the Arduino's 5V.
« Reply #4 on: September 11, 2010, 06:16:20 am » |
cool
i say 'cool' but im not sure how to use 8 bit serial protocol that is clocked or what LSB is.....
do you know how i can hookup 3? I have a mega and a 'classic' at my disposal. Are there any example codes i can start with or libraries i should be using?
« Last Edit: September 11, 2010, 09:08:00 am by vahakn »
SE USA
@ssh0le
« Reply #5 on: September 11, 2010, 06:00:04 pm » |
shiftOut() has a argument that is required for which end to send first
shiftOut(data pin, clock pin, MSBFIRST / LSBFIRST, byte of data);
« Reply #8 on: September 13, 2010, 06:29:14 pm » |
Hi thanks for your suggestions Mitch but i really need to have something a bit gorgeous like these starbursts. I need a certain strictness and purity to the message that these things are gonna say. Richard (or anyone), do you have any idea how i would wire the shift registers to the 4 pins on the back of my display?  And am I supposed to send hex codes to this thingto make it display letters?  AWOL said: The datasheet shows the interface protocol. It's 8 bit serial, clocked, LSB first.Does that mean im sending something like Serial.println ("lorem ipsum bla bla"); or something like that? :-/
« Last Edit: September 13, 2010, 06:30:39 pm by vahakn »
« Reply #9 on: September 14, 2010, 04:49:23 am » |
1. Do I need to connect the GND of my 5v power supply and the GND of the Arduino together? When I measure with my multimeter accross the 5v going into the display and the GND of the Arduino, which is connected to Pin 6 on the Display, I get zilch. 2. im getting error: In function 'void loop()': error: invalid conversion from 'const char*' to 'uint8_t'/Applications/Arduino.app/Contents/Resources/Java/hardware/cores/arduino/wiring.h:125: error: too few arguments to function 'void shiftOut(uint8_t, uint8_t, uint8_t, byte)'
At global scope: when i try to upload: *****
//**************************************************************// // Name : shiftOutCode, Hello World // Author : Carlyn Maw,Tom Igoe, David A. Mellis // Date : 25 Oct, 2006 // Modified: 23 Mar 2010 // Version : 2.0 // Notes : Code for using a 74HC595 Shift Register // // : to count from 0 to 255 //****************************************************************
//Pin connected to ST_CP of 74HC595 int latchPin = 8; //Pin connected to SH_CP of 74HC595 int clockPin = 12; ////Pin connected to DS of 74HC595 int dataPin = 11;
void setup() { //set pins to output so you can control the shift register pinMode(latchPin, OUTPUT); pinMode(clockPin, OUTPUT); pinMode(dataPin, OUTPUT); }
void loop() { digitalWrite(latchPin, 1); // take the reset pin high delay(3); //hold reset high for "long reset" digitalWrite(latchPin, 0); // take the reset pin back low
shiftOut(dataPin, clockPin "H");
« Last Edit: September 14, 2010, 06:30:57 am by vahakn »
Leeds, UK
Online
« Reply #10 on: September 14, 2010, 05:44:12 am » |
This compiles for me - ... shiftOut(dataPin, clockPin, LSBFIRST, 'H'); ... But you'll need to check it on your board. Note the change from the double quotes to single quotes, and the inclusion of LSBFIRST. Also, you have an extraneous } at the end, but that's easy to fix. Let us know if it works!
« Last Edit: September 14, 2010, 05:45:41 am by a.d »
« Reply #11 on: September 14, 2010, 06:07:13 am » |
Yes, this compiles thanks! but my display is doing nothing The data sheet says: At power on reset Display On/Off is set as JP3 link JP3 open - Display Off JP3 closed - Display On are we doing this? Im NOT supposed to be using the shift chip for this test am I? Because right now Im doing exactly what Richard Crowley advises: 1) The data from Ardunio DigitalPin 11 (blue wire in the ShiftOut example) to display pin 4 ("DO") 2) The clock from Ardunio DigitalPin 12 (yellow wire in the ShiftOut example) to display pin 2 ("CLK") 3) Re-purpose the ShiftOut "latch" pin to be "Reset" for this display: Ardunio DigitalPin 8 (green wire) to display pin 5 ("RESET") 4) Ground from Arduino "GND" to display pin 6 ("0V GND")  and my code looks like: //Pin connected to Display PIN 5 RESET int latchPin = 8; //Pin connected to Display PIN 2 CLK int clockPin = 12; ////Pin connected to Display PIN 4 D0 int dataPin = 11;
shiftOut(dataPin, clockPin, LSBFIRST, 'H'); shiftOut(dataPin, clockPin, LSBFIRST, 'E'); shiftOut(dataPin, clockPin, LSBFIRST, 'L'); shiftOut(dataPin, clockPin, LSBFIRST, 'L'); shiftOut(dataPin, clockPin, LSBFIRST, 'O');
« Last Edit: September 14, 2010, 06:29:26 am by vahakn »
Leeds, UK
Online
« Reply #12 on: September 14, 2010, 06:34:03 am » |
Is the display actually turning on?
Maybe try sending the char values from the datasheet as hex? 0x08, 0x05, 0x0C, 0x0C, 0x0F?
« Reply #13 on: September 14, 2010, 08:47:30 am » |
The Display is not showing ANY signs of life whatsoever except that its drawing 250mA and measures 5v accross the + and GND pins. Maybe try sending the char values from the datasheet as hex? 0x08, 0x05, 0x0C, 0x0C, 0x0F? how would i code this? I spoke to a hardware guy at Itron UK (display manufacturers) [who doesnt know what an Arduino is?!?!?!] who said the jumpers a basically for selecting which kind of reset you can have.. BUT the datasheet is wrong and out of date for this device VAF169-233C and I now have the new one http://vahakn.co.uk/x/VAF169-2SSD-02.pdfdoes this shed any light? I have linked LK1 (Sets Display to Full Brightness on Turn ON - default setting) I have linked JP1 pins 2+3 (RESET via RESET line - default setting) If I wanted to send HEX how would I do it AND On the side: Can I use some version of this sketch/library to send print commands: http://github.com/rooreynolds/microprinter/blob/master/Microprinter.javaThanks for everyones help so far..... I really want this to work.
« Last Edit: September 14, 2010, 10:16:27 am by vahakn »
Leeds, UK
Online
« Reply #14 on: September 14, 2010, 10:39:51 am » |
I would try replacing the 'H' in the shiftOut function call with 0x08, 'E' with 0x05 etc.
My reasoning behind this is that it is my understanding that 'H' returns an ASCII code, which is different to the code assigned to H on your screen.
I'm new to all this however, so I'm sure someone will correct me if I'm wrong!
