Topic: Burning bootloader to atmega8 using arduino UNO (v3) (Read 937 times) previous topic - next topic
harshvardhan
i bought an atmega8 from the shop(its totally blank)
i want to write some arduino codes in that.
how do i do it?
(i have made the circuit using 2 capacitors and a 16mhz crystal. )
mrburnette
Start here:
http://arduino.cc/en/Hacking/Bootloader?from=Main.Bootloader
You will use the Arduino UNO as an ISP programmer, sketch ArduinoISP
You will need the bootloader code for the Atmega8 ...  try this reference:
Here is a good overview:
http://www.gammon.com.au/forum/?id=11637
Good luck.  You may need to do some googlin' to fill in your knowledge.
Ray
