Oliver,
Thanks... worked like a charm...
#include "U8glib.h"
#include "M2tk.h"
#include "utility/m2ghu8g.h"
#include "images.h"
//U8GLIB( d0, d1, d2, d3, d4, d5, d6, d7, en, cs1, cs2, di, rw, reset)
U8GLIB_KS0108_128 u8g(22, 23, 24, 25, 26, 27, 28, 29, 37, 33, 34, 36, 35, 30);
uint32_t global_value_1 = 0;
uint32_t global_value_2 = 0;
uint32_t global_value_3 = 0;
uint8_t update_required = 0;
uint8_t timeout = 50; // 60 seconds (approx)
M2_EXTERN_ALIGN(el_m01);
M2_EXTERN_ALIGN(el_m02);
M2_EXTERN_ALIGN(el_m03);
uint32_t u32_cb_1(m2_rom_void_p el_u32_cb, uint8_t msg, uint32_t val)
// if ( msg == M2_U32_MSG_GET_VALUE ){
// wrong place to increment, do this in loop()
// global_value ++;
// Serial.println(global_value);
return global_value_1;
uint32_t u32_cb_2(m2_rom_void_p el_u32_cb, uint8_t msg, uint32_t val)
return global_value_2;
M2_LABEL(el_m00_label, "b0", "-= Main Menu =-" );
M2_LABEL(el_underline, "b0", "---------------------" );
M2_ROOT(el_m00_submenu1, "f0", "Menu 1", &el_m01 );
M2_ROOT(el_m00_submenu2, "f0", "Menu 2", &el_m02 );
M2_ROOT(el_m00_submenu3, "f0", "Menu 3", &el_m03 );
M2_LIST(el_m00_l1) = { &el_m00_label, &el_underline, &el_m00_submenu1, &el_m00_submenu2, &el_m00_submenu3 };
M2_VLIST(el_m00_vl, NULL, el_m00_l1);
M2_ALIGN(el_m00, "-0|2W128H64", &el_m00_vl);
M2_U32NUMFN(el_u32_cb_1, "r1c4", u32_cb_1);
M2_LABEL(el_space1, "b1", " ");
M2_BUTTON(el_m01_ok, NULL, " ok ", fn_ok1);
M2_LIST(el_l1) = { &el_u32_cb_1, &el_space1, &el_space1, &el_m01_ok };
M2_VLIST( el_v1, NULL, el_l1);
M2_ALIGN(el_m01, "-0|2W128H64", &el_v1);
M2_U32NUMFN(el_u32_cb_2, "r1c4", u32_cb_2);
//M2_LABEL(el_space1, "b1", " ");
M2_BUTTON(el_m02_ok, NULL, " ok ", fn_ok2);
M2_LIST(el_l2) = { &el_u32_cb_2, &el_space1, &el_space1, &el_m02_ok };
M2_VLIST( el_v2, NULL, el_l2);
M2_ALIGN(el_m02, "-0|2W128H64", &el_v2);
M2_U32NUM(el_u32_cb_3, "r1c4", &global_value_3);
M2_BUTTON(el_m03_ok, NULL, " ok ", fn_ok3);
M2_LIST(el_l3) = { &el_u32_cb_3, &el_space1, &el_space1, &el_m03_ok };
M2_VLIST( el_v3, NULL, el_l3);
M2_ALIGN(el_m03, "-0|2W128H64", &el_v3);
// m2 object and constructor
//M2tk m2(&el_m00, m2_es_arduino_serial, m2_eh_4bs, m2_gh_u8g_bf);
M2tk m2(&m2_null_element, m2_es_arduino_serial, m2_eh_4bs, m2_gh_u8g_bf);
void fn_ok1(m2_el_fnarg_p fnarg) {
m2.setRoot(&el_m00, 0);
void fn_ok2(m2_el_fnarg_p fnarg) {
m2.setRoot(&el_m00, 1);
void fn_ok3(m2_el_fnarg_p fnarg) {
m2.setRoot(&el_m00, 2);
void draw(void) {
if ( m2.getRoot() == &m2_null_element ) {
// draw splash screen
u8g.drawXBM( 0, 0, 128, 64, myimage);
else {
// draw the menu...
m2.draw();
Serial.println("Setup1");
m2_SetU8g(u8g.getU8g(), m2_u8g_box_icon);
m2.setFont(0, u8g_font_6x10 );
Serial.println("Setup2");
Serial.println("Loop");
m2.checkKey();
if ( m2.handleKey() != 0 ) {
// key pressed so reset the 'timer'
timeout = 50;
Serial.println("reset timer...");
// introduce a new variable "update_required"
if ( m2.handleKey() != 0 || update_required != 0 ) {
u8g.firstPage();
do {
m2.checkKey();
draw();
} while( u8g.nextPage() );
delay(100);
timeout--;
if ( timeout == 0 ) {
// change to home menu...
m2.setRoot(&el_m00);
global_value_1 ++;
global_value_2 += 2;
global_value_3 = global_value_1;
if ( m2.getRoot() == &el_m03 ) {
// no updates...
updating_time = 1;
else {
// force redraw
update_required = 1;
Michael
