Pages: [1]   Go Down
Author Topic: FLASH-lib for Arduino  (Read 766 times)
Offline Offline
Newbie
View Profile
hello.
I'm trying to use the flash lib in the code below but I get some errors that I think have to do with the lib.
I downloaded and put in the folder of the Arduino libraries. Added the lib but still got errors.
Can someone tell me how can I solve this?
Code:
#include <Flash.h>
int x = 0;
void setup(){
  FLASH_ARRAY(int, value, 1, 2, 2, 5, 6, 7, 10);
void loop(){
  x = value[1];
ERRORS:
sketch_nov07a.ino: In function 'void setup()':
sketch_nov07a:6: error: expected primary-expression before 'int'
sketch_nov07a:6: error: 'value' was not declared in this scope
sketch_nov07a:6: error: 'FLASH_ARRAY' was not declared in this scope
sketch_nov07a.ino: In function 'void loop()':
sketch_nov07a:10: error: 'value' was not declared in this scope
thank you
Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
Quote
From where? Where did you put it? "In the right place" is the wrong answer.
Logged
Offline Offline
Newbie
View Profile
You can see in the attached image where I put the lib.
I downloaded the lib in http://arduiniana.org/libraries/flash/comment-page-3/#comment-105688
After that did include the lib in the programming window, and when compiling one of the examples of the lib program returns me errors that indicated above.
Thanks
Logged
Denmark
Offline Offline
Edison Member
Happy Hobbyist
View Profile
WWW
The Name of the folder should be Flash , and not Flash4.
http://arduino.cc/en/Guide/Libraries
FLASH_ARRAY should be global (outside setup), take a look at the examples
« Last Edit: November 10, 2013, 10:50:30 am by Erni » Logged
Offline Offline
Newbie
View Profile
Thanks a lot  smiley-wink
It works.
Even noticed that they had the same name and therefore was giving error in compilation.
I made the changes and it is amazing.
Thank you
Logged
Pages: [1]   Go Up
Jump to:
