Topic: simple XMLwriter library for Arduino (Read 15491 times) previous topic - next topic
robtillaart
Nov 07, 2013, 08:11 pm Last Edit: Nov 07, 2013, 08:15 pm by robtillaart Reason: 1
Triggered by a post of Crossroads - http://forum.arduino.cc/index.php?topic=197251.0 - I wrote a simple library/class that helps to write XML output. Although still work in progress it seemed to me mature enough to post here so I can get feedback about all that is wrong.
Of course an example script to show how it can be used and its output.
Note that the data is made up or quite trivial.
Note the constructor can use any Print derived class, including Stream, Serial, etc (only tested Serial BTW).
XMLWriter XML(&Serial);
Code: (c++) [Select]
//    FILE: XMLWriterTest.ino
//  AUTHOR: Rob Tillaart
// VERSION: 0.1.01
// PURPOSE: make a simple XML generating lib
//    DATE: 2013-11-06
//     URL:
// Released to the public domain
#include <XMLWriter.h>
char buffer[24];
 XML.header();
 XML.comment("XMLWriterTest.ino\nThis is a demo of a simple XML lib for Arduino", true); // true means multi line here
 XML.tagOpen("Arduino", "42");
 XML.tagOpen("Ports");
 AnalogPorts("before");
 DigitalPorts();
 AnalogPorts("after");
 XML.tagClose();
 Weather();
 Weather2();
 XML.tagClose();
void Weather2()
 XML.comment("The weather in South Africa");
 for (int i=0; i<10; i++)
   XML.tagStart("Weather");
   XML.tagField("Date", "20131106");
   XML.tagField("Time", "1:42");
   XML.tagField("Temp", "23.4");
   XML.tagField("Humi", "50%");
   XML.tagField("Rain", "10mm");
   XML.tagField("Sun", "40");
   XML.tagEnd();
void Weather()
 XML.comment("The weather in Nebraska");
 XML.tagOpen("Weather");
 XML.writeNode("Date", "20131106");
 XML.writeNode("Time", "11:42");
 XML.writeNode("Temp", "23.4");
 XML.writeNode("Humi", "50%");
 XML.writeNode("Rain", "10mm");
 XML.writeNode("Sun", "40");
 XML.tagClose();
void AnalogPorts(char* name)
 XML.comment("The analog ports are multiplexed");
 XML.tagOpen("Analog", name);
 XML.writeNode("Analog0", itoa(analogRead(A0), buffer, 10));
 XML.writeNode("Analog1", analogRead(A1));
 XML.writeNode("Analog2", (5.0*analogRead(A2))/1023);      // default nr decimals float = 2
 XML.writeNode("Analog2", (5.0*analogRead(A2))/1023, 3);
 XML.tagClose();
void DigitalPorts()
 XML.comment("The digital ports are not multiplexed");
 XML.tagOpen("Digital");
 XML.writeNode("D1", itoa(digitalRead(1), buffer, 10));
 XML.writeNode("D13", digitalRead(13));
 XML.tagClose();
The output looks as follows:
Code: (xml) [Select]
<?xml version="1.0" encoding="UTF-8"?>
XMLWriterTest.ino
<Arduino name="42">
 <Ports>
   <!-- The analog ports are multiplexed -->
   <Analog name="before">
     <Analog0>448</Analog0>
     <Analog1>362</Analog1>
     <Analog2>1.52</Analog2>
     <Analog2>1.584</Analog2>
   </Analog>
   <!-- The digital ports are not multiplexed -->
   <Digital>
     <D1>0</D1>
     <D13>0</D13>
   </Digital>
   <Analog name="after">
     <Analog0>393</Analog0>
     <Analog1>428</Analog1>
     <Analog2>2.08</Analog2>
     <Analog2>1.994</Analog2>
   </Analog>
 </Ports>
 <!-- The weather in Nebraska -->
 <Weather>
   <Date>20131106</Date>
   <Time>11:42</Time>
   <Temp>23.4</Temp>
   <Humi>50%</Humi>
   <Rain>10mm</Rain>
   <Sun>40</Sun>
 </Weather>
 <!-- The weather in South Africa -->
 <Weather Date="20131106" Time="1:42" Temp="23.4" Humi="50%" Rain="10mm" Sun="40"/>
</Arduino>
Source see - https://github.com/RobTillaart/Arduino/tree/master/libraries/XMLWriter -
As always comments and remarks and improvements and ... are welcome.
(and no an XMLreader is not yet in the planning ;)
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
RbSCR
Nice !
Library is at your github-site I suppose ?
doughboy
How about adding check to escape the following characters
"   &quot;
'   &apos;
<   &lt;
>   &gt;
&   &amp;
or if not, to warn not to use those characters.
robtillaart
Nice !
yep I added the link in the first post.
Rob Tillaart
robtillaart
"   &quot;
'   &apos;
<   &lt;
>   &gt;
&   &amp;
Good point, might make the footprint larger, added to TODO
Rob Tillaart
robtillaart
handling escapes looks quit good
- need more testing
- refactor code
- performance?
Code: (code/output) [Select]
void testEscapes()
  XML.comment("Test escape chars");
  XML.tagOpen("char");
  XML.writeNode("quote", "\"hello\"");
  XML.writeNode("apos", "\'hello\'");
  XML.writeNode("less", "5 < 33");
  XML.writeNode("great", "Peter > John");
  XML.writeNode("amp", " &array[0] ");
  XML.tagClose();
  <!-- Test escape chars -->
  <char>
    <quote>&quot;hello&quot;</quote>
    <apos>&apos;hello&apos;</apos>
    <less>5 &lt; 33</less>
    <great>Peter &gt; John</great>
    <amp> &amp;array[0] </amp>
  </char>
Rob Tillaart
robtillaart
#6
Nov 08, 2013, 05:12 pm Last Edit: Nov 09, 2013, 12:28 pm by robtillaart Reason: 1
upgraded to 0.1.02 - https://github.com/RobTillaart/Arduino/tree/master/libraries/XMLWriter -
+ added setIndentSize(uint8_t n);   0 = no indent, 2 = default; 4 looks OK too (spaces, no tabs)
+ corrected history
+ added escape() for special chars. - tip doughboy
+ added comments in the form of 'example' output in .h file
+ added some #defines to make code more readable.
as always comments remarks welcome.
Rob Tillaart
SamsGuamejy
hello guys,
I am not an expert in programming in arduino but I would like to make a log as XML stored on an SD card.
This is why I come to you to find out which parameter set instead of (&Serial) on line 14.
Otherwise if you have other ideas to parse XML,I'm interested.
The aim being to insert tags into an existing XML.
Example:
Code: [Select]
<Log>
<element id="1" year="2014" month="1" day="1" hour="00" min="00" sec="00">
<sensor id="T1">20.0</sensor>
<sensor id="T2">20.0</sensor>
<sensor id="T3">20.0</sensor>
<sensor id="T4">20.0</sensor>
</element>
</Log>
To :
Code: [Select]
<Log>
</element>
<element id="2" year="2014" month="1" day="1" hour="00" min="01" sec="00">
</element>
</Log>
robtillaart
Quote
Should be something that implements the Print class,
The File Class is derived from the Stream Class which is derived from the Print class so that should work (to certain level)
The XML writer class does not support appending directly. What I would try is the following. Let your application go to the end of the of the file on SD card, do a reverse search for the last </log> entry and start writing from that point. MIght work or ... not :)
Give it a try.
Rob Tillaart
robtillaart
#9
Mar 08, 2015, 12:25 am Last Edit: Mar 08, 2015, 12:25 am by robtillaart
upgraded to 0.1.03 - https://github.com/RobTillaart/Arduino/tree/master/libraries/XMLWriter -
+ re-factored for smaller footprint (- ~60)
+ added support for more datatypes
+ extended example sketch
as always comments & remarks are welcome.
Rob Tillaart
federll
Hi there,
  Thank you very much for your XML Support.  Is there  anyway to read MusicXML wth an Arduino or Processing?
  Thank you very much for your support.
Best Regards,
Federico
robtillaart
In theory it should be possible to parse specific XML format's, but in practice the resources of an UNO are limited.
Can you post a (small) example and/or provide a link to the specification of MusicXML?
Rob Tillaart
nikalashatiko
Hello...
First of all sorry for my English...
my question is:
is it possible save XML Data directly in File on SD CARD??
I mean is it possible use some how XMLWriter XML(&Serial) with file output intead of &Serial??? ;
please help
robtillaart
#13
Apr 20, 2015, 09:56 pm Last Edit: Apr 20, 2015, 10:24 pm by robtillaart
yes, the FILE class is derived from print and can be used as parameter.
The sketch below is not tested but it compiles so please give it a try
Code: (not tested!!!) [Select]
//    FILE: .ino
// VERSION: 0.1.00
// PURPOSE: quick and dirty demo of xmlwriter to file
//    DATE:
//     URL:
int x;
#include <SPI.h>
#include <SD.h>
const int chipSelect = 4;
File dataFile;
char buffer[24]; // for analogreads
  Serial.println("Start ");
  Serial.print("Initializing SD card...");
  pinMode(10, OUTPUT);
  if (!SD.begin(chipSelect)) {
    Serial.println("Card failed, or not present");
    while (1); // block;
  Serial.println("card initialized.");
  dataFile = SD.open("datalog.txt", FILE_WRITE);
  if (dataFile)
    XMLWriter XML(&dataFile);
    XML.header();
    XML.tagOpen("Analog", "testing123");
    XML.writeNode("Analog2", (5.0 * analogRead(A2)) / 1023); // default nr decimals = 2
    XML.writeNode("Analog2", (5.0 * analogRead(A2)) / 1023, 3);
    XML.tagClose();
    XML.tagClose();
    XML.tagClose();
    XML.tagClose();
    dataFile.close();
Rob Tillaart
popescu_eduard
hey,
what if I want to do KML files?
