Topic: Home wireless sensor nodes connected to a base (Read 943 times) previous topic - next topic
hyp3rkyd
Hi all,
I am trying to create several sensor nodes with wireless communication to the base.
An UNO is used for every node. The UNO is connected to an nRF24L01+, 2 LEDs,a DHT11 sensor to provide thermometer /humidity data and a GAS sensor.
The base is an nano 3.0 which is connected to a DHT11 sensor and an nRF24L01+.
Both of nodes connect successfully and exchange data. The node sends all reading to the base from=>to an array. The base receives the data and displays them to serial.
The problem is that the DHT11 reads and displays successfully when alone (no nRF24 code) so does the nRF24 (no DHT11 code). I can't manage to make them work together. I have tried four DHT11 libraries with no success. The loop hangs.
Any opinions will be strongly appreciated. This is my code for the base (which appears to have the problem):
Code: [Select]
#include <dht11.h>
#include <SPI.h>
#include "nRF24L01.h"
#include "RF24.h"
#include "printf.h"
dht11 DHT11;
#define DHT11PIN 10
RF24 radio(8,7);
int ledPinA = 5;
int ledPinB = 6;
const uint64_t pipes[2] = { 0xF0F0F0F0E1LL, 0xF0F0F0F0D2LL };
  // Role
  pinMode(ledPinA,OUTPUT);
  pinMode(ledPinB,OUTPUT);
  digitalWrite(ledPinA, LOW);
  digitalWrite(ledPinB, LOW);
  printf_begin();
  printf("\nHOME v1.0.1\n");
  printf("\n----------------------------------------\n");
  radio.begin();
  radio.setRetries(15,15);
  radio.setPayloadSize(8);
  radio.setDataRate(RF24_250KBPS);
  radio.openWritingPipe(pipes[1]);
  radio.openReadingPipe(1,pipes[0]);
  radio.startListening();
  radio.printDetails();
  Serial.print("\n*****************************\n");
  Serial.print("Requesting data from sensors...\n");
  Serial.print("DHT: ");
    digitalWrite(ledPinB,HIGH);
    Serial.print("*");
    delay(100);
    DHT11.read(DHT11PIN);
    float t = DHT11.temperature;
    float h = DHT11.humidity;
    Serial.print("\n-------------------------------------\n");
    Serial.print("BASE     : ");
    Serial.print("temp-an: ");
    Serial.print((float)t, 2);
    Serial.print("*C");
    Serial.print(" | ");
    Serial.print("hum-an: ");
    Serial.print((float)h, 2);
    Serial.print("%\n");
    if ( radio.available() )
      int16_t data[10];
      bool done = false;
      delay(100);
      digitalWrite(ledPinB,LOW);
      digitalWrite(ledPinA,HIGH);
      while (!done)
        done = radio.read( data, sizeof(data) );
        Serial.print("NODE (A) : ");
        Serial.print("temp-dig: ");
        float tempD = (float)data[0]/100;
        Serial.print(tempD);
        Serial.print("*C | ");
        Serial.print(data[1]);
        Serial.print("humid-an: ");
        Serial.print(data[2]);
        Serial.print("% \n");
        Serial.print("gas-an: ");
        Serial.print(data[3]);
        delay(100);
        digitalWrite(ledPinA,LOW);
        delay(100);
      radio.stopListening();
JohnHoward
Move your DHT-11 off of pin 10.
http://arduino.cc/en/Reference/SPI
Quote
All AVR based boards have an SS pin that is useful when they act as a slave controlled by an external master. Since this library supports only master mode, this pin should be set always as OUTPUT otherwise the SPI interface could be put automatically into slave mode by hardware, rendering the library inoperative.
That happens to be pin 10 on the Uno
hyp3rkyd
This is nice to know. But actually I made some changes, as moving the sensors reading functions outside the loop and play with different positions of the DHT read function (it appeared to be the problem) and finally it works 100% !
This is my code for reference If someone has the same problem in the future (I've added an LDR sensor and a buzzer too) :
Code: [Select]
#include <dht11.h>
#include <SPI.h>
#include "RF24.h"
#include "printf.h"
dht11 DHT11;
#define DHT11PIN 10
RF24 radio(8,7);
int ledPinA = 5;
int ledPinB = 6;
int ldrPin = 0;
int spkrPin = 9;
int LDRValue = 0;
  pinMode(spkrPin,OUTPUT);
  pinMode(ldrPin, INPUT);
  digitalWrite(spkrPin, LOW);
  printf_begin();
  radio.begin();
  Serial.print("* Setup complete.\n");
  Serial.print("* Loop starting\n");
    Serial.print("#");
    delay(100);
    delay(100);
    delay(100);
    delay(100);
      int16_t data[10];
      bool done = false;
      delay(100);
      while (!done)
        float t = getLocalTemp();
        float h = getLocalHumi();
        int l = getLDRvalue();
        int adjustedLightLevel = 100 - map(l, 50, 1000, 0, 100);
        Serial.print("\n");
        Serial.print("\nBASE (A) : ");
        Serial.print("temp[D]: ");
        Serial.print(t);
        Serial.print("humi[D]: ");
        Serial.print(h);
        Serial.print("% | ");
        Serial.print("phot[A]: ");
        Serial.print(adjustedLightLevel);
        delay(200);
        Serial.print("\nNODE (A) : ");
        Serial.print("temp[A]: ");
        Serial.print((float)data[1],2);
        Serial.print("humi[A]: ");
        Serial.print((float)data[2],2);
        Serial.print("gas [A]: ");
        delay(100);
        //digitalWrite(spkrPin,HIGH);
        delay(2);
        //digitalWrite(spkrPin,LOW);
        delay(98);
float getLocalTemp(){
    return t;
float getLocalHumi(){
    return h;
int getLDRvalue(){
  for(int i=0;i<=25;i++){
    LDRValue = LDRValue + analogRead(ldrPin);
    delay(4);
  LDRValue = LDRValue/25;
  return LDRValue;
hyp3rkyd
The readings were static, so you were absolutely right! I moved it to Digital 4 and everything worked as it should...
This was a really badass piece of knowledge to know...
