Topic: How to send command to MP3 Shield? (Read 2656 times) previous topic - next topic
FSUDAL
I am a total newb and need a simple answer since I can't seem to figure this out our unfortunately get any support from the vendor (probably since I am asking such a ridiculous question).  Could someone please stop laughing long enough to point me in the right direction and let me know how I send commands to the mp3 shield from my computer?  Do I open up the serial monitor within the Arduino software and type the commands in the top line then press send?  Could someone take a peek at this guide toward bottom of page 8?  http://www.elechouse.com/elechouse/images/product/Arduino%20MP3%20Shield/Arduino%20MP3%20Shield%20User%20Guide.pdf
For example this is what is in the guide to play a file from the sd card (toward bottom of page eight).  Do I type what's below in the top line of the serial monitor and then press send (it doesn't seem to work)?
0x7E 0x04 0xA0 00 02 0x7E
Thanks for your help.
CrossRoads
So you have some version of their example file running?
Code: [Select]
#include <SoftwareSerial.h>
#include <MP3.h>
/** define mp3 class */
MP3 mp3;
  /** begin function */
  mp3.begin(MP3_SOFTWARE_SERIAL);    // select software serial
//  mp3.begin();                       // select hardware serial(or mp3.begin(MP3_HARDWARE_SERIAL);)
  /** set volum to the MAX */
  mp3.volume(0x1F);
  /** set MP3 Shield CYCLE mode */
  mp3.set_mode(MP3::CYCLE);
  /** play music in sd, '0001' for first music */
  mp3.play_sd(0x0001);
  /** play music in USB-disk */
  //mp3.play_usb_disk(0x0001);
  /** play music in SPI FLASH */
  //mp3.play_spi_flash(0x0001);
/** function code here */
and you've written some code to send the commands you referenced to the board?
FSUDAL
#2
Nov 10, 2013, 07:38 pm Last Edit: Nov 10, 2013, 07:40 pm by FSUDAL Reason: 1
Thanks for the quick reply.  Now that you mention it I was using the example code but it does not look like there's any commands in the example sketch (told you I was a newb!).  I was also trying this other example code below which plays the songs automatically but I was unable to send any "play, pause, next" commands.  Would you know how I could control the mp3 shield from my computer?
Code: [Select]
// Mohannad Rawashdeh
// MP3 1.2V Shield test .
SoftwareSerial Geno(7,8); // Rx , Tx
unsigned char Data[10];
unsigned char i;
  Geno.begin(9600);
  SetVolume(20); // set volume from 0-31
  FileSource('SD_card',0x05);
  SetPlayMode('Single_play');
  delay(5000);
  play_pause();// Pause
  delay(3000);
  FileSource('SD_card',0x01);
  play_pause(); // play
  delay(5000);
  Next();
  delay(5000);
  Next();
  for(int v=15;v>0;v--){
  SetVolume(v); // set volume from 0-31
  for(int j=0;j<15;j++){
  SetVolume(j); // set volume from 0-31
  FileSource('SD_card',0x04);
  delay(5000);
// FileSource('SD_card',0x03);
  //Stop();
// Select File sorce "SD Card, SPI Flash , U Disk "
void FileSource( char type, byte track ){
   Data[0] = 0x7E;
   Data[5] = 0x7E;
  switch (type){
   case 'SD_card':
          // START
    Data[1] = 0x04;          // Length
    Data[2] = 0xA0;          // Command
    Data[3] = 0x00;          // file number high byte
    Data[4] = track;          // file number low byte
    case 'SPI_Flash':
    Data[2] = 0xA1;          // Command spi flash 0XA1
    Data[4] = track;
    case 'U_Disk':
    Data[2] = 0xA2;          // Command
  Command(Data,5);
void SetVolume( int vol){
   Data[0] = 0x7E;          // START
   Data[1] = 0x03;          // Length Not 0x02
   Data[2] = 0xA7;          // Command
   Data[3] = vol;          // new volume
   Data[4] = 0x7E;          // END
   Command(Data,5);
void SetPlayMode(char type){
   Data[4] = 0x7E;          // START
   switch (type){
   case 'Single_play':
   Data[1] = 0x02;          // Length
   Data[2] = 0xA9;          // Command
   Data[3] = 0x00;          //Mode parameter
   case 'Repeat_single':
   Data[3] = 0x01;          //Mode parameter
   case 'Repeat_all':
   Data[3] = 0x02;          //Mode parameter
   case 'Play_Random':
   Data[3] = 0x03;          //Mode parameter
Command(Data,5);
void play_pause(){
  Data[2] = 0xA3;          // Command
  Data[3] = 0x7E;          //Mode parameter
  Command(Data,4);
  void Stop(){
  Data[2] = 0xA4;          // Command
  Command(Data,4);
  void Next(){
  Data[2] = 0xA5;          // Command
  Command(Data,4);
  void Previous(){
  Data[2] = 0xA6;          // Command
  Command(Data,4);
void Command(unsigned char *Data, int length){
    for(int i=0; i<length; i++){
    Geno.write(Data[i]);
CrossRoads
From your computer, you would send the bytes to the arduino.
The arduino would receive them and send them to the shield.
So for this 6 byte command
0x7E 0x04 0xA0 0x00 0x02 0x7E
you might have
Code: [Select]
void loop(){
if (Serial.available()>5){ // 6 or more bytes received?
byte0 = Serial.read(); // read 1st byte
if (byte0 == 0x7E){   // and then the rest if a valid start byte came in
commandArray[0] = byte0
commandArray[1] = Serial.read();
commandArray[2] = Serial.read();
commandArray[3] = Serial.read();
commandArray[4] = Serial.read();
commandArray[5] = Serial.read();
// now send the bytes to the shield using its library commands
// all done, go back to looking for PC commands
} // end loop
FSUDAL
Thanks again for your help!  I am getting the following errors;
     sketch_nov10a.cpp: In function 'void loop()':
     sketch_nov10a:46: error: 'byte0' was not declared in this scope
     sketch_nov10a:48: error: 'commandArray' was not declared in this scope
     sketch_nov10a:56: error: expected primary-expression before '...' token
     sketch_nov10a:56: error: expected `;' before '...' token
Would you know the proper format for declaring the above?
Here's what my code looks like after entering in your suggestion;
Code: [Select]
unsigned char i;
  Geno.begin(9600);
  delay(5000);
  delay(3000);
  delay(5000);
  Next();
  delay(5000);
  Next();
  delay(5000);
  //Stop();
commandArray[0] = byte0;
} // end loop
   Data[0] = 0x7E;
   Data[5] = 0x7E;
  switch (type){
   case 'SD_card':
          // START
    case 'SPI_Flash':
    Data[4] = track;
    case 'U_Disk':
  Command(Data,5);
   Command(Data,5);
   switch (type){
   case 'Single_play':
   case 'Repeat_all':
   case 'Play_Random':
Command(Data,5);
void play_pause(){
  Command(Data,4);
  void Stop(){
  Command(Data,4);
  void Next(){
  Command(Data,4);
  void Previous(){
  Command(Data,4);
