Topic: Android controlled arduino (ethernet) (Read 24161 times) previous topic - next topic
kerimil
Nov 11, 2013, 05:37 am Last Edit: Nov 11, 2013, 05:49 am by kerimil Reason: 1
A simple example on how to control an arduino board from a smartphone, this time using ethernet NOT bluetooth. The app was created using MIT's app inventor. The module used here is based on the ENC28J60 chip (~$5 on fleabay  )
enjoy
http://www.youtube.com/watch?v=vKE8SHywZmo
Arduino sketch
Code: [Select]
// A simple web server that shows temperature and controlls an LED
#include "etherShield.h"
#include "ETHER_28J60.h"
#include <OneWire.h>
OneWire  ds(A3);  // on pin A3
int celsius,celsiusF;
int outputPin = 3; //the LED pin
static uint8_t mac[6] = {
 0x54, 0x55, 0x58, 0x10, 0x00, 0x24};   // this just needs to be unique for your network,
// so unless you have more than one of these boards
// connected, you should be fine with this value.
static uint8_t ip[4] = {
 192, 168, 1, 15};                       // the IP address for your board. Check your home hub
// to find an IP address not in use and pick that
// this or 10.0.0.15 are likely formats for an address
// that will work.
static uint16_t port = 80;                                      // Use port 80 - the standard for HTTP
ETHER_28J60 e;
 e.setup(mac, ip, port);
 char* params;
 if (params = e.serviceRequest())
   e.print("<H1>Temperature<br/>");
   e.print(celsius);
   e.print(",");
   e.print(celsiusF);
   e.print(" C</H1>");
   e.print("<br><br>");
   e.print("<H1>LED control</H1>");
   e.print("<A HREF='?cmd=off'>Turn off</A><br>");
   e.print("<A HREF='?cmd=on'>Turn on</A><br><br>");
   if (strcmp(params, "?cmd=on") == 0)
     digitalWrite(outputPin, HIGH);
     e.print("LED is ON");
   else if (strcmp(params, "?cmd=off") == 0)
     digitalWrite(outputPin, LOW);
     e.print("LED is OFF");
   e.respond();
   delay(100);
     byte i;
     byte present = 0;
     byte type_s;
     byte data[12];
     byte addr[8];
     if ( !ds.search(addr)) {
       Serial.println("No more addresses.");
       ds.reset_search();
       delay(250);
       return;
     Serial.print("ROM =");
     for( i = 0; i < 8; i++) {
       Serial.write(' ');
       Serial.print(addr[i], HEX);
     if (OneWire::crc8(addr, 7) != addr[7]) {
       Serial.println("CRC is not valid!");
       return;
     // the first ROM byte indicates which chip
     switch (addr[0]) {
     case 0x10:
       Serial.println("  Chip = DS18S20");  // or old DS1820
       type_s = 1;
     case 0x28:
       Serial.println("  Chip = DS18B20");
       type_s = 0;
     case 0x22:
       Serial.println("  Chip = DS1822");
       type_s = 0;
     default:
       Serial.println("Device is not a DS18x20 family device.");
       return;
     ds.reset();
     ds.select(addr);
     ds.write(0x44,1);         // start conversion, with parasite power on at the end
     delay(10);     // maybe 750ms is enough, maybe not
     // we might do a ds.depower() here, but the reset will take care of it.
     present = ds.reset();
     ds.select(addr);
     ds.write(0xBE);         // Read Scratchpad
     Serial.print("  Data = ");
     Serial.print(present,HEX);
     Serial.print(" ");
     for ( i = 0; i < 9; i++) {           // we need 9 bytes
       data[i] = ds.read();
       Serial.print(data[i], HEX);
       Serial.print(" ");
     Serial.print(" CRC=");
     Serial.print(OneWire::crc8(data, 8), HEX);
     // convert the data to actual temperature
     unsigned int raw = (data[1] << 8) | data[0];
     if (type_s) {
       raw = raw << 3; // 9 bit resolution default
       if (data[7] == 0x10) {
         // count remain gives full 12 bit resolution
         raw = (raw & 0xFFF0) + 12 - data[6];
     else {
       byte cfg = (data[4] & 0x60);
       if (cfg == 0x00) raw = raw << 3;  // 9 bit resolution, 93.75 ms
       else if (cfg == 0x20) raw = raw << 2; // 10 bit res, 187.5 ms
       else if (cfg == 0x40) raw = raw << 1; // 11 bit res, 375 ms
       // default is 12 bit resolution, 750 ms conversion time
     celsius = abs(raw / 16.0);
     celsiusF= (raw / 16.0 - celsius) * 100;
     Serial.print("  Temperature = ");
     Serial.print(celsius);
     Serial.print(",");
     Serial.println(celsiusF);
The .apk file is the app iteslf, the zipped file is a source that can be uploaded into MIT's app inventor for experimenting with it. The source file is an archive and it should be uploaded to app inventor as an archive.
nickgammon
Code: [Select]
Is this intentional?
Or should it be:
Code: [Select]
  if (params == e.serviceRequest())
Please post technical questions on the forum, not by personal message. Thanks!
More info: http://www.gammon.com.au/electronics
kerimil
Yes, that's intentional - the variable params stores the query string
If you type into the address bar of the browser
Quote
192.168.1.15/blahblahblah
and hit enter
the variable params stores 'blahblahblah'
fungus
But very bad programming practice.
Stuff like that isn't clever. ..
No, I don't answer questions sent in private messages (but I do accept thank-you notes...)
kerimil
Now that you pointed it out I realize it might be confusing.
gaurav_sharma132
Kerimil,
Seems old thread, but I was just curious how to upload an image from SD card to web-server using this library ?
if you can guide on that, it would be really helpful.
Thanks
Gaurav
firmanmustofa
how about control for 4 relays? please
Muaadh
Hallo,
first of all than you for this work.
I try to do the same in the video. every thing worked but when I put the IP in the Web-browse, it didnt open any thing. I tried that with different Browsers, but also it dosent work  :~ , can any body help me !!!
homerruma
@kerimil
How to open source code?
appinventor request .aia file.
Tnx
marionaldo
this error appears when i try to upload the code
Arduino: 1.6.11 (Windows 10), Board: "Arduino/Genuino Uno"
In file included from C:\Users\hp\Documents\Arduino\libraries\etherShield/etherShield.h:25:0,
                 from C:\Users\hp\Desktop\ether\ether.ino:3:
C:\Users\hp\Documents\Arduino\libraries\etherShield/ip_arp_udp_tcp.h:32:66: error: 'prog_char' does not name a type
 extern uint16_t fill_tcp_data_p(uint8_t *buf,uint16_t pos, const prog_char *progmem_s);
In file included from C:\Users\hp\Desktop\ether\ether.ino:3:0:
C:\Users\hp\Documents\Arduino\libraries\etherShield/etherShield.h:34:65: error: 'prog_char' does not name a type
    uint16_t ES_fill_tcp_data_p(uint8_t *buf,uint16_t pos, const prog_char *progmem_s);
C:\Users\hp\Desktop\ether\ether.ino: In function 'void loop()':
C:\Users\hp\Desktop\ether\ether.ino:36:34: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
C:\Users\hp\Desktop\ether\ether.ino:38:15: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
    e.print(",");
C:\Users\hp\Desktop\ether\ether.ino:40:21: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
    e.print(" C</H1>");
C:\Users\hp\Desktop\ether\ether.ino:41:22: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
C:\Users\hp\Desktop\ether\ether.ino:42:22: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
C:\Users\hp\Desktop\ether\ether.ino:43:34: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
C:\Users\hp\Desktop\ether\ether.ino:45:49: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
C:\Users\hp\Desktop\ether\ether.ino:46:51: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
C:\Users\hp\Desktop\ether\ether.ino:51:25: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
C:\Users\hp\Desktop\ether\ether.ino:57:26: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
exit status 1
Error compiling for board Arduino/Genuino Uno.
option enabled in File -> Preferences.
Chipakias
kerimil can you upload the app inventor file in .aia format ?
Thank you
