Topic: reading file on the SD card (Read 1 time) previous topic - next topic
logger
Hi
i using the mega to log my PV system. I log to a site and also on the SD card.(every 5minutes).  But sometimes the data will not be accepted by the site , reason ...because of internetproblems  to serverbusy etc..  ???.. but the data is always on the SD card..  now i remove the SD card once a month , to added the mising data to the site ..  but is there a easier way to read the data from the SD card
by sending the CSV file through mail ... or??
is it easy to attach a csv file to a mail  and will it be fast enough, because im saving data every 5minutes to SD card
does somewone has experiance in this case
greetings
OllyR
Im a complete noob, so my language wont be technical
One of the examples has a section where by it only writes to the SD card periodically. it buffers the data inbetween onboard the arduino. This is used because it uses a lot of a battery power to  write to the card.  on the flip side if the power dies you loose what was saved to the buffer in that period.
perhaps you could use that function, make the writes to SD card occur only once every half hour or so? (or even on the half hour using the RTC, so you know how much time you have to take the card out and do what you need to do?)
also, my SD card breakout board has a pin which can be used to tell when there is a card in the slot (or not)
you could use that function so that when the card is missing, the sketch buffers the data. once the card is returned to the slot, it dumps what it has saved and carries on as normal
I have NO idea what the removal of the card does to the sketch.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
