Topic: Watchdog Timer Interrupt and External Interrupt (Read 20719 times) previous topic - next topic
pauldreed
Aah, that makes sense now!
Nick, just checked the Atmel datasheet (page 71), and it appears that INT0 & INT1 will trigger external interrupts.
Michael, INT0 & INT1 correspond to Digital pins 2 & 3, your memory serves you (us) well!
Paul
pauldreed
Despite my previous message, I still can't get it to wake from D3.
I have added;
const int BTN_PIN = 2; //wire a button from pin 2 to ground
const int BTN_PIN3 = 3; //wire a button from pin 3 to ground
and
pinMode(BTN_PIN, INPUT_PULLUP);
pinMode(BTN_PIN3, INPUT_PULLUP);
but, grounding pin 3 does not trigger a extInterrupt.
Any thoughts?
Paul
nickgammon
Post the complete code please, in code tags.
Please post technical questions on the forum, not by personal message. Thanks!
More info: http://www.gammon.com.au/electronics
nickgammon
Code: [Select]
That's wrong, though. Pin 2 is interrupt 0.
pauldreed
Code: [Select]
Yes, and PIN2 (interrupt 0) does cause a wake up.
It's PIN3 (interrupt 1) that doesn't, and which is causing me difficulties.
The full code is on page 2 of this thread by Jack Christensen.
Paul
nickgammon
That code does not define an ISR for INT1_vect.
nickgammon
This also needs changing:
Code: [Select]
    EICRA = _BV(ISC01);            //configure INT0 to trigger on falling edge
    EIFR = _BV(INTF0);             //ensure interrupt flag cleared
    EIMSK = _BV(INT0);             //enable INT0
Why not use attachInterrupt? That's simpler.
pauldreed
Nick, I'm punching above my weight here!!
I've just had a look at attachInterrupt and that does not seem straightforward either...
From your tone, I suspect that this would not be easy to implement, so maybe I need to take a step back and try and find a solution using just one pin with interrupt.
Paul
nickgammon
#38
Dec 13, 2013, 11:29 pm Last Edit: Dec 13, 2013, 11:47 pm by Nick Gammon Reason: 1
Not at all, it's simpler using that. Here:
Code: [Select]
//Using the watchdog timer, sleep for the given number of intervals,
//then print a message. Prints a dot at each WDT wakeup.
//A button is also connected to provide an external interrupt, print
//a message when the button is pressed.
//Finally, blink an LED after each wake-up regardless of source.
//Using an ATmega328P at 16MHz and 5V, draws ~6.3µA while sleeping, which
//is consistent with only the WDT running.
//Jack Christensen 19Nov2013
//CC BY-SA, see http://creativecommons.org/licenses/by-sa/3.0/
#include <avr/wdt.h>
#include <avr/sleep.h>
#include <util/atomic.h>
#include <Streaming.h>            //http://arduiniana.org/libraries/streaming/
const int BTN_PIN2 = 3;            //wire a button from pin 3 to ground
const int LED_PIN = 13;           //wire an LED from pin 13 to ground through a proper current-limiting resistor
const int WDT_INTERVALS = 50;     //number of WDT timeouts before printing message
const unsigned long LED_ON_TIME = 200;  //turn on LED for this many ms after each wake-up
const long BAUD_RATE = 115200;
volatile boolean extInterrupt;    //external interrupt flag (button)
volatile boolean wdtInterrupt;    //watchdog timer interrupt flag
void wakeOnInterrupt ()
 extInterrupt = true;
 // don't need the external interrupts any more
 detachInterrupt (0);
 detachInterrupt (1);
void setup(void)
   pinMode(BTN_PIN2, INPUT_PULLUP);
   pinMode(LED_PIN, OUTPUT);
   Serial.begin(BAUD_RATE);
   ATOMIC_BLOCK(ATOMIC_RESTORESTATE) {
       wdt_reset();
       MCUSR &= ~bit(WDRF);                            //clear WDRF
       WDTCSR |= bit(WDCE) | bit(WDE);                 //enable WDTCSR change
       WDTCSR =  bit(WDIE) | bit(WDP3) | bit(WDP0);    //~8 sec
   Serial << endl << F("Setup complete");
void loop(void)
   static int wdtCount;
   static int btnCount;
   if (wdtCount == 0 || extInterrupt) Serial << endl << F("Sleep");
   Serial.flush();
   Serial.end();
   gotoSleep();
   digitalWrite(LED_PIN, HIGH);    //blink the LED on each wakeup
   delay(LED_ON_TIME);
   digitalWrite(LED_PIN, LOW);
   if (wdtInterrupt) {
       Serial << '.';
       if (++wdtCount >= WDT_INTERVALS) {
           Serial << endl << F("WDT: ") << wdtCount;
           wdtCount = 0;
   if (extInterrupt) {
       Serial << endl << F("Button: ") << ++btnCount;
void gotoSleep(void)
   byte adcsra = ADCSRA;          //save the ADC Control and Status Register A
   ADCSRA = 0;                    //disable the ADC
   noInterrupts ();     // timed sequences follow
   EIFR = bit (INTF0);  // clear flag for interrupt 0
   EIFR = bit (INTF1);  // clear flag for interrupt 1
   attachInterrupt (0, wakeOnInterrupt, FALLING);
   attachInterrupt (1, wakeOnInterrupt, FALLING);
   set_sleep_mode(SLEEP_MODE_PWR_DOWN);
   wdtInterrupt = false;
   extInterrupt = false;
   sleep_enable();
   byte mcucr1 = MCUCR | bit(BODS) | bit(BODSE); //turn off the brown-out detector while sleeping
   byte mcucr2 = mcucr1 & ~bit(BODSE);
   MCUCR = mcucr1; //timed sequence
   MCUCR = mcucr2; //BODS stays active for 3 cycles, sleep instruction must be executed while it's active
   interrupts ();      // need interrupts now
   sleep_cpu();                   //go to sleep
   sleep_disable();               //wake up here
   ADCSRA = adcsra;               //restore ADCSRA
//handles the Watchdog Time-out Interrupt
ISR(WDT_vect)
   wdtInterrupt = true;
The wakeOnInterrupt function handles waking on both interrupts.
Compiled and tested OK. Some style changes made (sorry, Jack!).
pauldreed
Code: [Select]
const int BTN_PIN2 = 3;            //wire a button from pin 2 to ground
void setup(void)
        wdt_reset();
void loop(void)
    Serial.flush();
    Serial.end();
    gotoSleep();
    delay(LED_ON_TIME);
    if (wdtInterrupt) {
        Serial << '.';
            wdtCount = 0;
    if (extInterrupt) {
    sleep_enable();
ISR(WDT_vect)
That's great Nick, thank you very much!
This project has proved a steep learning curve, so I do appreciate your support.
Paul
JChristensen
#40
Dec 14, 2013, 01:56 am Last Edit: Dec 14, 2013, 01:57 am by Jack Christensen Reason: 1
No worries, to each his own! Thanks for getting my back there.
I suppose attachInterrupt() is simpler, but not much. Guess I just like diddling with the registers -- that way if anything goes South, I only have myself to blame. :D
pauldreed
#41
Dec 18, 2013, 11:28 pm Last Edit: Dec 18, 2013, 11:36 pm by pauldreed Reason: 1
How long, precisely, is each sleep cycle?
My best guess is about 8.7 seconds, but is there a precise figure which could be used to determine reasonably accurate,  longer time periods by repeating the cycle, such as a re-occurring task exactly every 8hrs.
nickgammon
I suggest you add a real-time clock chip (for around $1) if you want more accurate time-keeping.
JChristensen
Some comments about the accuracy of the WDT:
http://forum.arduino.cc/index.php?topic=201460.msg1484665#msg1484665
http://forum.arduino.cc/index.php?topic=201460.msg1484794#msg1484794
pratto
Nick & Jack -
NG reply #38 & JC reply #24
I read this thread with great interest because i have been trying to figure out how to do exactly this for weeks. I have posted threads (questions) on this subject in this forum, and gotten no responses.
And in looking at your codes, I would not have figured it out in this lifetime.  But when i run either code, I get the same error message "in function 'void setup()'  end1 was not declared in this scope".
I am using UNO 1.0.1  I have all of the includes.h
Would either of you take a minute and help me to get your code running . it runs for you, but not for me.
thanks
pat
I
