Topic: Generating Composite Video (Read 36563 times) previous topic - next topic
benoit
Hello,
 I've read the post. You have the same problems :) of timing.
 Could we try to resolve them together ? My project is working in the loop() function, everything is ok. I try do it with interupt but I don't have an oscilloscope to fine tuning synchro.
Cordialement,
Benoît ROUSSEAU
droolcup
Hi everyone,
I just stumbled on this thread while looking into something else entirely (curse you stream of consciousness browsing).
Some of us did this a few years ago with a pair of PIC 18f452s in CSS C at 40MHz.  One PIC set up the video environment, and on interrupt we used a second one to read inputs and do our "drawing" routines.
As I recall, it was a pretty crude effort, but it worked well enough for our purposes.  You can look at the project notes and code here : http://droolcup.com/pictv
~s
benoit
Hello droolcup,
 Thank's for your post. I've just seen the video of your project. I have the same result with interrupt, one somme image configuration there some lines are "overshooting", it depends of the white surface on screen...
 I think I'll have to write some parts of the code in asm to be sure of timings.
Cordialement,
Benoît ROUSSEAU
Goobers
The best way that I've seen to do this is by using 2 micros- one of them is programmed in ASM and reads the pixel data from a ram chip, which the other micro updates. There would be a sync line between the two to make sure one isn't trying to write while the other is reading. This would eliminate timing problems and also allow for more complex programs to be run.
I'm thinking of giving this approach a try soon- what does everyone think?
jlulian38
Maybe this is just crazy talk, but couldn't you try and generate your sync signal with a bi-stable oscillator, you'd want to watch that with the MCU so that you don't keep sending data as your sync goes off, if not using the oscillator directly, you could use it to keep track of were you are in your output (send the sync with the MCU, but use the oscillator to time everything right.
(Please excuse any tyops I've made, it's late, and it's hard for me to keep up with my high standard of typing when I'm tired.)
benoit
Hello,
 Yes, I'm thinking about soltions with external components. But, at first I want to do it the best without active components. It's a challenge with Arduino Board  :). I will try with some asm code include in  C code...
Cordialement,
Benoît ROUSSEAU
zitron
Hey Benoît ROUSSEAU,
Just want to say good luck! I hope you'll find a way to get it to work eventually, meanwhile I can dream about arduino pong!
-Z-
XNDR
I stumbled upon a site where they sell all kinds of electronic video/audio instruments. There's a lot of interesting information about how these guys managed to get the video output running.. They use a ARM7TDMI Microcontroller in conjunction with an AD725 RGB to PAL/NTSC encoder IC from Analog Devices. They run a crystal at 4 times the video burst frequency to get stable output, it still only handles 256 colors at a 160 x 128 resolution. But it looks like lots of fun to play with, it could also be interfaced with an arduino board. Programming the microcontroller itsself requires C skills and the GNU toolchain, a flash utility and an USB board (i bet the arduino can also be used as an Serial/USB interface to program this board).
http://www.critterandguitari.com/catalog/index.php?main_page=product_info&cPath=1&products_id=13
Golan
Hi All,
Possibly this should be a new thread, but the "generating video bboard" is pretty close to my question:
Has anyone written code to detect the vertical blanking interval in an incoming NTSC composite video signal (RS-170A)?
I'm creating a project in which I need to switch a circuit on and off, precisely in sync with the video fields from an NTSC video source. In order to do this, I would need to sample the video signal fairly frequently and write an analyzer/detector for the vertical blanking interval, which is used to synchronise the video frames.
Any advice would be greatly appreciated before I bore headlong into the oscilloscope.
Thanks,
Golan
Daniel
#39
Jun 17, 2007, 04:00 am Last Edit: Jun 17, 2007, 06:37 am by Daniel Reason: 1
hi
you can get a single-chip solution for that: they're called sync separators. The LM1881 comes to mind. It only needs +5V,  3 capacitors and two resistors. In return, it provides the vertical and horizontal sync, as well as the field (odd/even) and the back porch signal form a composite video signal. It's about $3 US.
D
PS: there is an interesting article at this link, with code and schematics, on using the above chip with an AVR to create a motion detection system.
Daniel
this was just posted via Make Magazine... an AVR based video overlay. Interestingly, it uses the LM1881 to separate sync, and then one pin pulls the video level to generate the overlay.
http://garydion.com/projects/videoverlay/
D
agent_orange
I managed to get the Arduino generating a PAL signal. My TV syncs to this signal without any problems. I followed the specs for a PAL signal as close as possible. It uses asm nops to try and get more precise delay times. Each nop is a 65ns delay (1 instruction at 16 Mhz...it should be 65ns but i don't have a good enough oscilloscope to check). The PAL signal has +- 0.3 microseconds leeway on the sync signals anyway so it works ok.
The code generates a white bar in the middle of the TV. Here is the first half.
Code: [Select]
int pixel = 6;  // Connected to 550ohm resistor (Should be 470ohm)
int sync = 7;   // Connected to 1k ohm resistor
int i;
 pinMode(pixel,OUTPUT); // Switch to output pin
 pinMode(sync,OUTPUT);  // Switch to output pin
 cli();                // Turn off interupts
 // Generate 5 Narrow Equalization pulses
 PORTD = B10000000; // Make the sync high to start with
 for(i=0;i<5;i++)
    PORTD = B00000000; // Sync pulse goes low and delay 2.3 microseconds
    delayMicroseconds(1);
    __asm__("nop\n\t""nop\n\t""nop\n\t""nop\n\t""nop\n\t");
    PORTD = B10000000; // Sync pulse goes high and delay 29.7 microseconds
    delayMicroseconds(29);
    __asm__("nop\n\t""nop\n\t""nop\n\t""nop\n\t""nop\n\t""nop\n\t""nop\n\t""nop\n\t""nop\n\t""nop\n\t""nop\n\t");
 // Generate the 5 Field Sync Pulses
 for(i=0;i<5;i++)
   PORTD = B00000000; // Sync goes low and delay 27.3 microseconds
   delayMicroseconds(27);
   PORTD = B10000000; // Sync goes high and delay 4.7 microseconds
 for(i=0;i<5;i++)
    PORTD = B10000000;
    delayMicroseconds(29); // Sync pulse goes high and delay 29.7 microseconds
 // Generate 18 Blank Frames
 for(i=0;i<18;i++)
   PORTD = B00000000;    // Pull sync pin low -> 0 volts
    delayMicroseconds(4);
   PORTD = B10000000; // Pull sync pin high
   delayMicroseconds(59);
 // Generate half the Image
 for(i=0;i<285;i++)
   // Front Porch
   PORTD = B10000000;
   delayMicroseconds(1); // Front Porch: 1.65 microseconds
   __asm__("nop\n\t""nop\n\t""nop\n\t""nop\n\t""nop\n\t""nop\n\t""nop\n\t""nop\n\t""nop\n\t""nop\n\t");
   // Generate sync pulse
   PORTD = B00000000;    // Sync pulse pulled low: 4.7 microseconds
   // Back Porch
   PORTD = B10000000;    // This is the back porch: 5.6 microseconds.
   delayMicroseconds(5);
   // Drawing starts here: Total time available is 53 microseconds
   PORTD = B10000000;    // Draw black
   delayMicroseconds(20);
   PORTD = B11000000;    // Draw white
   delayMicroseconds(10);
   delayMicroseconds(22);
agent_orange
And the other half....just a copy of the first half  :) Cut and paste both of these into one file and it should be good to go.
Code: [Select]
 for(i=0;i<5;i++)
 for(i=0;i<5;i++)
   __asm__("nop\n\t""nop\n\t""nop\n\t""nop\n\t""nop\n\t"); // 0.3 microseconds
   __asm__("nop\n\t""nop\n\t""nop\n\t""nop\n\t""nop\n\t""nop\n\t""nop\n\t""nop\n\t""nop\n\t""nop\n\t""nop\n\t"); // 0.7 microseconds
 for(i=0;i<5;i++)
    PORTD = B10000000;
 for(i=0;i<18;i++)
   PORTD = B00000000;    //0 volts
   __asm__("nop\n\t""nop\n\t""nop\n\t""nop\n\t""nop\n\t""nop\n\t""nop\n\t""nop\n\t""nop\n\t""nop\n\t""nop\n\t"); //0.7 microseconds
   PORTD = B10000000;
 // Generate the next half of the Image
 for(i=0;i<285;i++)
   // Front Porch
   PORTD = B10000000;
   // Back Porch
Goobers
Nice, I'll have to give this a go in a bit :)
javg
Yet another link, this one is written for Arduino in pure C (not Processing nor assembly)
http://hklab.net/wiki/TV_Video_Signal_Generator_with_Arduino
I'm a fortunate man because I have an oscilloscope and I have seen that
  • delayMicroseconds doesn't work for delays lower than ~5us
  • digitalWrite() is terribly sloooooow so don't use it
  • When the loop() function finishes, there is a 10us extra delay (?)
Conclusion: don't use Processing to accomplish a hard real-time task like this. Use C or assembly.
Sorry for my poor english.
Regards,
Javi
