Topic: Serial SPI - 2.2" TFT LCD - ILI9341 (Read 127247 times) previous topic - next topic
K5CZ
Nov 20, 2013, 05:38 pm Last Edit: Nov 20, 2013, 06:01 pm by K5CZ Reason: 1
I got 2.2' TFT LCD: TFT01-2.2SP, but I am not able find proper wiring for Arduino Mega 2560. Has anyone of you this TFT working?
Code: [Select]
Description:
   Operating Voltage: 5v/3.3v
   material: plastic
   Quantity: 1PC
   Color : as show the picture
   Congroller: ILI9341
   Resolution: QVGA 240*320 Dots
   Package includes:
    1pc X  2.2 Inch SPI TFT LCD Serial Port Module
I tried connect as follows
Code: [Select]
VCC - +5V
GND - GND
#define _cs   53 //SS
#define _rst  42 //RESET
#define _dc   43 //D/C
#define _mosi 51 //SDI(MOSI)
#define _sclk 52 //SCK
LED - +3.3V
#define _miso 50 //SDO(MISO)
Adafruit_ILI9340 tft = Adafruit_ILI9340(_cs, _dc, _mosi, _sclk, _rst, _miso);
K5CZ
Also I tried Seeed Studio library, but I do not understand this
Code: [Select]
#if defined(__AVR_ATmega1280__) || defined(__AVR_ATmega2560__)
#define TFT_CS_LOW  {DDRE |= 0x08;PORTE &=~ 0x08;}
#define TFT_CS_HIGH {DDRE |= 0x08;PORTE |=  0x08;}
#define TFT_DC_LOW  {DDRH |= 0x08;PORTH &=~ 0x08;}
#define TFT_DC_HIGH {DDRH |= 0x08;PORTH |=  0x08;}
#define TFT_BL_OFF  {DDRH |= 0x10;PORTH &=~ 0x10;}
#define TFT_BL_ON   {DDRH |= 0x10;PORTH |=  0x10;}
#define TFT_RST_OFF {DDRD |= 0x10;PORTD |=  0x10;}
#define TFT_RST_ON  {DDRD |= 0x10;PORTD &=~ 0x10;}
#define YP A2   // must be an analog pin, use "An" notation!
#define XM A1   // must be an analog pin, use "An" notation!
#define YM 54   // can be a digital pin, this is A0
#define XP 57   // can be a digital pin, this is A3
#elif defined(__AVR_ATmega32U4__)
#define TFT_CS_LOW  {DDRC |= 0x40;PORTC &=~ 0x40;}
#define TFT_CS_HIGH {DDRC |= 0x40;PORTC |=  0x40;}
#define TFT_DC_LOW  {DDRD |= 0x80;PORTD &=~ 0x80;}
#define TFT_DC_HIGH {DDRD |= 0x80;PORTD |=  0x80;}
#define TFT_BL_OFF  {DDRE |= 0x40;PORTE &=~ 0x40;}
#define TFT_BL_ON   {DDRE |= 0x40;PORTE |=  0x40;}
#define YM 18   // can be a digital pin, this is A0
#define XP 21   // can be a digital pin, this is A3
#else
#define TFT_CS_LOW  {DDRD |= 0x20;PORTD &=~ 0x20;}
#define TFT_CS_HIGH {DDRD |= 0x20;PORTD |=  0x20;}
#define TFT_DC_LOW  {DDRD |= 0x40;PORTD &=~ 0x40;}
#define TFT_DC_HIGH {DDRD |= 0x40;PORTD |=  0x40;}
#define TFT_BL_OFF  {DDRD |= 0x80;PORTD &=~ 0x80;}
#define TFT_BL_ON   {DDRD |= 0x80;PORTD |=  0x80;}
#define YM 14   // can be a digital pin, this is A0
#define XP 17   // can be a digital pin, this is A3
#endif
specifically that part
Code: [Select]
What are these pins?
Trixi
This looks like a kind of pin-mapping for the connection of the TFT.
As i saw in the datasheet you need 2 power sources ?, and the whole thing is driven bei SPI.
Quote
SDO: Serial clock output
LED: 3.4V Power Supply pin
SCL: Serial clock input
SDA / SDI: Serial data input
DC: Data / Command selection
RST: Reset, Low level active
CS: Chip Selection, Low level active
GND: Ground
VDD33: 3.3V Power Supply pin
UTFT Support
GND & Vcc is for the circuit, LED is power for led.
Did you connect RESET and is this HIGH or LOW ?
Dum spiro, spero - if you find my posting helpful, please click my Karma :)
raschemmel
Am I missing something ?
I don't see any SPI transfer commands.
Where is the rest of you code.
All I see is definitions.
Can you please photograph your interface so we can see where all the wires go ?
Arduino UNOs, Pro-Minis, ATMega328, ATtiny85, LCDs, MCP4162, keypads,<br />DS18B20s,74c922,nRF24L01, RS232, SD card, RC fixed wing, quadcopter
K5CZ
#4
Nov 20, 2013, 06:38 pm Last Edit: Nov 23, 2013, 12:12 am by K5CZ Reason: 1
I know, what are functions of the pins on the board, but I'm confused about how they are named in libraries and examples
For example:
UTFT(byte model, int RS, int WR,int CS, int RST, int SER=0);
means what?
RS - ?
WR - ?
CS - CS
RST - RESET
SER - ?
Edit: this was for paralel interface, for serial is syntax obvious:
UTFT(model,SERIAL_DATA_INPUT_MOSI,SERIAL_CLOCK_SCLK,CHIP_SELECT_CS,RESET, REGISTER_SELECT_DC);
K5CZ
#5
Nov 20, 2013, 06:43 pm Last Edit: Nov 20, 2013, 06:45 pm by K5CZ Reason: 1
I use libraries and only modify PINS in the examples to test. So rest of code I do not post deliberately.
https://github.com/adafruit/Adafruit_ILI9340
http://www.seeedstudio.com/wiki/2.8%27%27_TFT_Touch_Shield_V2.0
I'll take some photographs and publish them.
raschemmel
That's fine but we need to know exactly which example you are running. Just telling us you're using
this or that library doesn't tell us which example you are trying to run with that library.
Also, you are forcing us to chase down libraries and examples which takes time.
What we need is the code for the example pasted in (or uploaded) and the library (uploaded)
That gives us everything we need , right here, right now.
Then a statement:
Tried to run "Hello World" from Seeed Studio (see attached)
Here's my definitions and photos.
K5CZ
My latest attempt. I found ili9341 library on github for exactly same display. I investigate pin assignment for MEGA2560 and (may be wrong) here is:
Code: [Select]
{DDRE |= 0x08;PORTE &=~ 0x08;} //D5? CS
{DDRH |= 0x08;PORTH &=~ 0x08;} //D6? DC
{DDRH |= 0x10;PORTH &=~ 0x10;} //D7 backlight
{DDRD |= 0x10;PORTD &=~ 0x10;} //D4? RESET
My actual wiring is now:
SDO(MISO) - MISO
LED - D7
SCK - SCK
SDI(MOSI) - MOSI
D/C - D6
RESET - D4
CS - D5
GND - GND
VCC - +5V
Every example I run, serial monitor shows:
Code: [Select]
Read TFT ID failed, ID should be 0x09341, but read ID = 0x000
so it is obvious that the SPI communication is not working (only turning backlight on/off is working)
Attached ZIP file contains library and examples. I made no modifications.
The photo shows my bowl of spaghetti.
raschemmel
Ok , please bear with me . I need to ask you something just to make sure it is not the issue.
Exactly  how did you install the library?
Did you unzip it somewhere and copy it the library directory
or
did you unzip it DIRECTLY to the My Documents\Arduino\Libraries folder using the winzip explorer window?
Next, exactly how did you launch the program ?
Did you use Files\Open My Documents\Arduino\[library directory]\[filename] ?
or
did you use Sketch\add file\My Documents\Arduino\[library directory]\[filename] ?
or did you use Files\Examples\[select program using drop down mouse menus ?
then click on RUN =>
raschemmel
Read this:
http://arduino.cc/en/Guide/Libraries
K5CZ
Adding libraries and running examples is not problem. During test I have only one library in Arduino folder, because tested libraries may collide. I know about it and it is not my problem. Problem is SPI communication - or display may be faulty.
Trixi
So far everything looks OK (hardware, wiring and sketch) so it COULD be that the tft is damaged/didn't work
Did you see any feedback from the display, i.e. power led, bg light on or something like this ?
K5CZ
Backlight is working. Setting D7 to high or low turns backlight on or off.  The display is a little more heated.
Although PCB contains a voltage regulator 5V -> 3V, I suspect that the 5V I/O data signals coming from Arduino the chip ILI9341 can not handle. The datasheet says:
ILI9341 can operate with 1.65V ~ 3.3V I/O interface voltage.
raschemmel
You might want to try one of these:
OKI-78SR-3.3/1.5-W36-C
4.95W 24Vin 3.3Vout
(That's P(W) = I(A)*V(V) =>  4.95W/3.3V=1.5A
available at Mouser:
Mouser P/N: 580-OKI78SR3.31.536C
http://www.mouser.com/ProductDetail/Murata/OKI-78SR-33-15-W36-C/?qs=%2fha2pyFadug1ZrXHkIky7LtoJCPWCweGXaSSyT98oJvt1QArCaucX9tJYw9tEMiA
MarkT
Firstly that chip is 3.3V logic only, DO NOT connect 5V signals to it or you may fry it.
The LED pin should not be connected directly to 3.3V, it needs about 30 ohms to 5V or about
5 ohms to 3.3V (its directly driving some white LEDs in parallel that need about 60mA)
