Topic: Settimino : Ethernet library to communicate with S7 Siemens PLC. (Read 25473 times) previous topic - next topic
davenardella
Hi all,
I published on Sourceforge the project of a communication library for the S7 Siemens PLC family.
  • S7 200/300/400/1200/1500 and LOGO 0BA7 are managed.
  • Full PLC memory access (E/A/M/DB/T/Z)
  • Helper functions for data conversion (Big Endian --> Little endian)
  • PDU independence : large data transfer in a single call (limited only on the available memory)
  • Three memory models for footprint optimization.
  • Uses standard Arduino Ethernet library i.e. it can coexist with other clients/servers in the same sketch.
  • 3 ms to read one PDU (240 bytes) into the internal buffer.
  • Detailed documentation.
The project is derived from another my project - Snap7 (a 32/64 bit multi-platform library)
Comments/suggestions are warmly welcomed..
I hope  you like it.. ;)
Davide Nardella
http://settimino.sourceforge.net
(the son of http://snap7.sourceforge.net)
jnogues
Hi Davide. Felititations for this magnific job.
I'm try the example RunStopDemo, and I can' connect to my Logo! OBA7. The logo IP is 192.168.4.50,
and the ethernet shield+UNO  is 192.168.4.11.
Could you say me if the modifications are correct?
Reagards,
Jaume Nogu├ęs
Vall Hebron Tech School
Barcelona
emilio20
Hello I have a Arduino Yun.
Unfortunately I can not connect to the sample project RunStopDemo.
Can you tell me how the project would look at RunStopDemo an Arduino Yun
Llaner
Hey congrats on the job. I have a problem and communicate well read but not to do to a real number eacribir eg 60.50 as I have to turn to writing
emilio20
#4
May 08, 2014, 05:29 pm Last Edit: May 08, 2014, 05:53 pm by emilio20 Reason: 1
Hello
read variables from the PLC works.
How can I write a Florat in the PLC?
This code does not work?
Code: [Select]
float f = 123.45;
   byte* bytes = (byte*)&f;
   Result=Client.WriteArea(S7AreaDB, // We are requesting DB access
                      307,        // DB Number = 1
                        0,        // Start from byte N.0
                        4,     // We need "Size" bytes
                        bytes);  // Put them into our target (Buffer or PDU)
Code: [Select]
Data Read Demo
Created 19 Nov 2013
by Davide Nardella
#include <SPI.h>
#include <Ethernet.h>
#include "Settimino.h"
// Uncomment next line to perform small and fast data access
#define DO_IT_SMALL
// Enter a MAC address and IP address for your controller below.
// The IP address will be dependent on your local network:
byte mac[] = {
 0x90, 0xA2, 0xDA, 0x0F, 0x08, 0xE11 };
IPAddress Local(192,168,178,55); // Local Address
IPAddress PLC(192,168,178,30);   // PLC Address
byte MyBuffer[1024];
byte MyWrite[4];
S7Client Client;
// Setup : Init Ethernet and Serial port
    while (!Serial) {
     ; // wait for serial port to connect. Needed for Leonardo only
   // Start the Ethernet Library
   Ethernet.begin(mac, Local);
   // Setup Time, someone said me to leave 2000 because some
   // rubbish compatible boards are a bit deaf.
   delay(2000);
   Serial.println(Ethernet.localIP());
// Connects to the PLC
bool Connect()
   int Result=Client.ConnectTo(PLC,
                                 0,  // Rack (see the doc.)
                                 2); // Slot (see the doc.)
   Serial.print("Connecting to ");Serial.println(PLC);
   if (Result==0)
     Serial.print("Connected ! PDU Length = ");Serial.println(Client.GetPDULength());
     Serial.println("Connection error");
   return Result==0;
// Main Loop
 int Size, Result;
 float Pressure;
 unsigned long Encoder;
 int Component;
 byte Bytes;
 // Connection
 while (!Client.Connected)
   if (!Connect())
 Serial.print("Reading ");
 Result=Client.ReadArea(S7AreaDB, // We are requesting DB access
                        11,     // We need "Size" bytes
                        &MyBuffer);  // Put them into our target (Buffer or PDU)
 if (Result==0)
   Pressure = S7.FloatAt(&MyBuffer, 0);
   Serial.print("Pressure=");
   Serial.println(Pressure);
   Encoder = S7.DWordAt(&MyBuffer, 4);
   Serial.print("Encoder=");
   Serial.println(Encoder);
   Component = S7.IntegerAt(&MyBuffer, 8);
   Serial.print("Component=");
   Serial.println(Component);
   Bytes = S7.ByteAt(&MyBuffer, 10);
   Serial.print("Bytes=");
   Serial.println(Bytes);
   CheckError(Result);
   float f = 123.45;
// Prints the Error number
void CheckError(int ErrNo)
 Serial.print("Error No. 0x");
 Serial.println(ErrNo, HEX);
 // Checks if it's a Severe Error => we need to disconnect
 if (ErrNo & 0x00FF)
   Serial.println("SEVERE ERROR, disconnecting.");
   Client.Disconnect();
davenardella
Siemens PLC data are Big-Endian, Arduino data are Little-Endian, you need to convert the float to Big-Endian in order to transfer it into the CPU.
Basically, every var greater then a byte needs to be converted..
Regards
Davide Nardella
emilio20
Hello
how can I convert the data? Can you write me an example?
I try to Wandlen Florat in bytes. Sorry, no figures were displayed in the PLC.
Code: [Select]
float f = 123.45;
davenardella
Hi Emilio,
you can use these two functions:
Code: [Select]
// Reverse float/dword/dint
void Reverse4(void *ptr)
  byte *pb;
  byte tmp;
  pb=(byte*)(ptr);
  // Swap byte 4 with byte 1
  tmp=*(pb+3);
  *(pb+3)=*pb;
  *pb=tmp;
  // Swap byte 3 with byte 2
  tmp=*(pb+2);
  *(pb+2)=*(pb+1);
  *(pb+1)=tmp;
// Reverse word/int
void Reverse2(void *ptr)
  byte *pb;
  byte tmp;
  pb=(byte*)(ptr);
  // Swap byte 2 with byte 1
  tmp=*(pb+1);
  *(pb+1)=*pb;
  *pb=tmp;
Reverse4 exchanges (Big<->Little endian) the bytes inside a float/dword/dint (4 bytes variable)
Reverse2 exchanges (Big<->Little endian) the bytes inside a word/int (2 bytes variable)
This is the usage in your case:
Code: [Select]
float f = 123.45;
word w=0x1234;
Reverse4(&f);
Result=Client.WriteArea(S7AreaDB, 307, 0, sizeof(float), &f);
Reverse2(&w);
Result=Client.WriteArea(S7AreaDB, 307, 4, sizeof(word), &w);
Open a VAT (Variable table) into your project and display:
DB307.DBD 0 (change Display format as floating-point)
DB307.DBW 4 (change Display format as Hexadecimal)
It's only an example, I suggest you to fully "adjust" a buffer in order to transfer it rather then transferring single fields.
Regards
Davide
robtillaart
swapping 2 bytes for endianess can be done ~20%  faster -  if you are in a need for speed (or have large arrays)
Code: [Select]
void reverse2(uint16_t *n)
  *n = (*n >> 8 ) | (*n << 8);
void reverse2(int16_t *n)
  *n = ((*n >> 8 ) & 0xFF)| (*n << 8);
No optimization found for the 4 byte swap (yet ;)
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
andrit
#9
Oct 17, 2014, 04:48 pm Last Edit: Oct 18, 2014, 09:09 am by andrit Reason: 1
although I get data in the PLC but not written correctly
what have i done wrong?:
I get displayed  in the PLC positive and negative numbers, but they are not in connection with the variables in the Arduino.
Code: [Select]
DB Get Demo
Created 19 Nov 2013
by Davide Nardella
This demo shows how to upload an entire DB from the PLC without
knowing its size in advance.
A DB1 with not more than 1024 byte into the PLC is needed.
- During the loop, try to disconnect the ethernet cable.
  The system will report the error and will reconnect automatically
  when you re-plug the cable.
- For safety, this demo *doesn't write* data into the PLC, try
  yourself to change ReadArea with WriteArea.
- This demo uses ConnectTo() with Rack=0 and Slot=2 (S7300)
  - If you want to connect to S71200/S71500 change them to Rack=0, Slot=0.
  - If you want to connect to S7400 see your hardware configuration.
  - If you want to work with a LOGO 0BA7 or S7200 please refer to the
    documentation and change
    Client.ConnectTo(<IP>, <Rack>, <Slot>);
    with the couple
    Client.SetConnectionParams(<IP>, <LocalTSAP>, <Remote TSAP>);
    Client.Connect();
#include <SPI.h>
byte mac[] = {
IPAddress Local(192,168,0,70); // Local Address
IPAddress PLC(192,168,0,1);   // PLC Address
byte Buffer[1024];
byte MyWrite[2];
S7Client Client;
unsigned long Elapsed; // To calc the execution time
     while (!Serial) {
    delay(2000);
bool Connect()
    if (Result==0)
    return Result==0;
// Dumps a buffer (a very rough routine)
void Dump(void *Buffer, int Length)
  int i, cnt=0;
  pbyte buf;
  if (Buffer!=NULL)
    buf = pbyte(Buffer);
    buf = pbyte(&PDU.DATA[0]);
  Serial.print("[ Dumping ");Serial.print(Length);
  Serial.println(" bytes ]==========================");
  for (i=0; i<Length; i++)
    cnt++;
    if (buf[i]<0x10)
      Serial.print("0");
    Serial.print(buf[i], HEX);
    Serial.print(" ");
    if (cnt==16)
      cnt=0;
  Serial.println("===============================================");
  if (ErrNo & 0x00FF)
// Profiling routines
void MarkTime()
  Elapsed=millis();
void ShowTime()
  // Calcs the time
  Elapsed=millis()-Elapsed;
  Serial.print("Job time (ms) : ");
  Serial.println(Elapsed);
// Main Loop
  uint16_t Size;
  int Result;
  Size = sizeof(Buffer);
  // Connection
    if (!Connect())
  Serial.println("Uploading DB100");
  // Get the current tick
  MarkTime();
  Result=Client.DBGet(100,       // DB Number = 1
                      &Buffer, // Our Buffer
                      &Size);  // In input contains our buffer size
                               // As output contains the data read
int VAR1 = 32000;
      byte* bytes = (byte*)&VAR1;
                       200,           // DB Number = 1
                         2,           // We need "Size" bytes
  if (Result==0)
    ShowTime();
    Dump(&Buffer, Size);
    CheckError(Result);
Thanks.
davenardella
As just said, Siemens PLC data are Big-Endian, Arduino data are Little-Endian.
You neet to swap the byte order of words and floats before writing them into the PLC.
Use reverse2 (for int/words) and reverse4 (for double word/large int/floats)
manfred-65
Hi
I need help. I'd like to read with my Arduino D18b20 a temperature sensor and the serial number and then Themperaturwert S7 in an example DB1 transferred.
How do I have the SPS parametiereren (via Ethernet) as seen from the program for the Arduino. I'm from the examples that I find not smart in the network. Can any one help me?
thank chine times and L.G. Mani
chg1988
Hello davenardella,
I'm going to transfer a temperature from arduino to S7, too. It would be interesting how that works. The connection between S7 and Arduino already works. Its easy to send and read "byte"-data into/of a DB, but I despair in sending floats/words/ints. An example would be very nice :-).
Thanks in advance.
manfred-65
Hello chg1988
I work with automatic translator, therefore, apologize for bad English.
How did you set up the connection to the S7?
via Ethernet?
I have a 151-8 CPU I can also combine this with the Arduino? If so, how. An example would be good.
L.G. Mani
chg1988
Hallo Manfred,
schau mal in deinen privaten Nachrichten!!;)
