Topic: Advise needed: Trying to achieve lowest power on an attiny13a (Read 3944 times) previous topic - next topic
attiny13a
Hello,
Using the code below 690micro Amp is achieved during sleep mode and 2,500micro Amp when it is awake (LED on).
Is it possible to push down the power consumption lower during sleep mode?
  • attiny13a
  • attiny13 core
  • 3v CR2032
  • LED connected to PB4 and grounded via 1meg resistor
  • Pin 1, Pin 2, Pin 5, Pin 6, Pin 7 not connected anywhere
Thank you for reading!
Code: [Select]
#include <avr/sleep.h>
#include <avr/power.h>
#define  LED PB4
  ISR(WDT_vect) {
   noInterrupts();
   digitalWrite(LED,digitalRead(LED)^1);
   interrupts();
  }//ISR()
void setup(){
  pinMode(LED, OUTPUT);
  WDTCR |= 32; //watchdog set for about 2 seconds
  WDTCR |= 64; //enable watchdog
  _SFR_MEM8(0x30)= 0x03; //disable Brown Out Detector Control Register
  _SFR_MEM8(0x35)&=0x83; //PUD disabled, Sleep enabled,  Power Down mode
  _SFR_MEM8(0x25)=2; //Power reduction timer enable
  interrupts();
}// setup()
void loop(){
  sleep_cpu();
}//void loop()
nickgammon
Code: [Select]
ISR(WDT_vect) {
   noInterrupts();
   interrupts();
  }//ISR()
You don't need to turn interrupts off, or on, in an ISR. So that can be:
Code: [Select]
ISR(WDT_vect) {
  }//ISR()
http://www.gammon.com.au/interrupts
Please post technical questions on the forum, not by personal message. Thanks!
More info: http://www.gammon.com.au/electronics
nickgammon
690 µA sounds far too high to me. You should be able to get it down to 6 µA.
http://www.gammon.com.au/power
Try turning off the ADC.
westfw
Quote
this is a big "don't do that" for low power consumption.  Even though it is common practice in arduino software, it is a bad idea to leave pins configured as inputs AND not connected to anything; they can easily "float" at non-digital signal levels (or even oscillate), causing unexpectedly high current consumption.
I'd be curious to hear if you actually see any change in consumption JUST by changing the pins to outputs.
And... I usually refrain from commenting on issues of programming style, but THIS is really awful:
Code: [Select]
Those registers, and their bits, are defined for you symbolically in avr/io.h (etc), which is included for you by the arduino system (the same place that _SFR_MEM8() is defined.)   You should use them.  (in fact, those registers are all defined as "_SFR_IO8(x)", which is not the same as _SFR_MEM8(), so perhaps those lines are not doing what you think they are doing AT ALL!)
attiny13a
Nick, I appreciate the article! Now I know. Thank you so much! :)
Quote
Code: [Select]
ISR(WDT_vect) {
  }//ISR()
attiny13a
Is there something else I can do to lower the power more?
Modified Code now:
  • 588 micro Amp when LED is off
  • 2,166 micro Amp when LED is on
Other notes:
  • need to modify avrdude.conf (add attiny13a definition, just copy attiny13 and only change ID and Desc
  • iotn13a.h is used (some definitions are not included int attiny13.h)
  • unused pins activated pull-up resistor (Article 10.2.6 of attiny13a datasheet)
Code: [Select]
#define LED PORTB4
ISR(WDT_vect) {
PORTB ^= (1<<LED);
}//ISR()
void setup(){
  pinMode(PORT0,INPUT);      //Article 10.2.6 of attiny13a datasheet
  pinMode(PORT1,INPUT);
  pinMode(PORT2,INPUT);
  pinMode(PORT3,INPUT);
  pinMode(PORT5,INPUT);
  digitalWrite(PORT0,HIGH);
  digitalWrite(PORT1,HIGH);
  digitalWrite(PORT2,HIGH);
  digitalWrite(PORT3,HIGH);
  digitalWrite(PORT5,HIGH);
  WDTCR |= (1<<WDP3) | (1<<WDTIE);      //Watchdog set for about 8 seconds
  ACSR |= (1<<ACD);                    //Analog comparator off
  BODCR |= (1<<BPDSE)|(1<<BPDSE);       //Disable Brown Out Detector Control Register
  MCUCR |= (1<<SM1);                    //Sleep mode to POWER DOWN
  PRR   |= (1<<PRADC)|(1<<PRTIM0);      //Power reduction timer enable , ADC off
  DIDR0 |= (1<<AIN0D)|((1<<AIN1D));     //Digital input disable
}// setup
void loop(){
  sleep_cpu();
}//void loop()
fungus
Try this where you set ACSR:
Code: [Select]
ACSR = ADMUX = ADCSRA = 0;
No, I don't answer questions sent in private messages (but I do accept thank-you notes...)
attiny13a
Hello,
Thank you always for reading and for your kind insights.
Found a good link to reduce amperage during sleep mode  to 4.5µA !.
However, I noticed that placing the code to setup() and loop() instead of main() yeilded different results.
Please see code and Amp reading below. Any thoughts on what is going on?
NOTES:
  • same attiny13a is used (same circuit also)
  • both codes have been uploaded several times
  • both codes show consistency of output after several uploads
  • all unused pin and reset pin are shorted to +3v of the cr2032
LED on =1700.0µA
LED off=       4.5µA
Code: [Select]
#include <avr/interrupt.h>
ISR(WDT_vect) {
 PORTB ^= 1<<PORTB4;
}//ISR
int main(void) {
 DDRB = 1<<DDB4;
 WDTCR |= (1<<WDP3); // (1<<WDP2) | (1<<WDP0);
 WDTCR |= (1<<WDTIE);
 sei(); // Enable global interrupts
 set_sleep_mode(SLEEP_MODE_PWR_DOWN);
for (;;) {
   sleep_mode();   // go to sleep and wait for interrupt...
 }//for
}//main
LED on =1830.0µA
LED off=   190.0µA
Code: [Select]
ISR(WDT_vect){
 PORTB ^= 1<<PORTB4;
}//ISR
void setup(){
DDRB = 1<<DDB4;
}//void setup
for (;;) {
}//for
}//main
westfw
Well, if you use setup() and loop(), you're letting the Arduino main() run, and that will turn on both timer0 and the ADC.
Using your own main(), those peripherals should be "never touched", and thus OFF.
In your initial code, you were explicitly turning things off (or at least attempting to!); what happened to that code in the latest example?
attiny13a
#9
Nov 26, 2013, 07:25 am Last Edit: Nov 26, 2013, 09:53 am by attiny13a Reason: 1
Quote from: westfw link=topic=200430.msg1
Since the latest code is working, there is no strong reason to keep the initial code. But thanks for the insight!
attiny13a
  • 4.5 microAmp was lowest amperage achieved when using the Watchdog Timer
  • it did not really matter if the other pins were shorted NOR ground or +3v  (or not)
  • most efficient coding is to NOT use Arduino's loop() and main() functions
