Topic: fired arduino due board (Read 1 time) previous topic - next topic
m_lab85
Nov 22, 2013, 10:12 pm Last Edit: Nov 23, 2013, 12:38 pm by m_lab85 Reason: 1
hi all,
i am so frustrated with due. TWO arduino boards blow up. they overheated and then stopped working!!!!
i am sending data as below:
Mic>>>amp/offset>>>(<3V)>>> transmitter board (analog input pin to digital pin)>>>>>>>wire>>>>>>board receiver (digital input pin to DAC output pin)>>>>amp >>>>speaker.
what could cause this, could someone help me figure where the issue was,
any help or advice would be greater appreciated,
regards,
M,
m_lab85
hi all,
please could some one tell me what is the ( micro freeze) and how it could damage my arduino board?
thanks
M,
lar3ry
Tell us where you saw that term, please.
There are 10 kinds of people in the world,
those who understand binary, and those who don't.
m_lab85
hi,
well, i am not familiar with the term. i had two arduino due boards were blow up and i was told that it could be the micro freezes issue.
M,
m_lab85
http://forum.arduino.cc/index.php?topic=200557.0
please see the link above. this is what happened
chriskner
A schematic is worth 1000 words.
ASCII art: bytes.
-Chris
AWOL
Who told you this?
From your other post
current nothing is extreme (less than 3 volt , 500mA).
500mA sounds pretty extreme to me.
Robin2
I suspect someone was playing a trick on you.
To me the phrase means that the software gets stuck in an endless loop due to a programming error. That won't break anything, apart from your patience.
Please don't raise the same issue in two different threads.
I had a quick look at the other thread, but I don't have a Due. You would need to provide a wiring diagram so the Due experts can understand what you were doing.
...R
Two or three hours spent thinking and reading documentation solves most programming problems.
AWOL
AWOL
This is like pulling teeth.
What does you friend imagine the "micro freeze" problem is?
I'm in my fourth decade working with microprocessors and micro controllers, but I've never heard this term before.
m_lab85
but it was different topic. i posted in the programming questions section because i thought it was something in programming that i don't know.
thanks, i will get some pics for the setup so things will start to make some sense,
regards,
M,
AWOL
But you didn't post any code.
