Topic: Library for saving non-volatile data to flash on Arduino Due (Read 2154 times) previous topic - next topic
sebnil
I needed an replacement for the EEPROM library on Arduni Due since it does not have EEPROM at all. Flash memory can be used in a similar so I created a library with the idea to have a similar syntax as the EEPROM library. More info at http://sebastiannilsson.com/en/blogg/ersattare-for-eeprom-pa-arduino-due/
and code at https://github.com/sebnil/DueFlashStorage
Example:
Code: [Select]
// write the value 123 to address 0
dueFlashStorage.write(0,123);
// read byte at address 0
byte b = dueFlashStorage.read(0);
Perhaphs it will be useful for someone else.
PaulS
What happens to the data when you load a new sketch?
sebnil
It will unfortunately empty the stored data. I have not found a way of not making that happen.
MarkT
I hope they decide to add an EEPROM I2C chip to the next board revision...
